Old 06-09-2009, 08:18 PM   #1
turbored02
Member#: 119471
2002 Impreza
Sedona Red Pearl
Default So I have searched for days.(seriously) Hi Idle after 2.5 swap
So my problem is I have an idle of 2k when the car is warm. When the car is cold it idles at 1.5k. My mods are the 05 STi LB with the WRX intake manifold wiring and ecu. I also have a DBB Garrett GT3071r. STi pink 565(i think) injectors, 255 fuel pump. GReddy FMIC. Perrin Divorced Dp. And Tanabe Medalion exhaust. When I had the 2.0, all the supporting mods where tuned. Only things I have changed are the turbo and the TGV deletes. Back then I had a GReddy 18g. So when I got this new engine. I have been having little problems. 1 being the high idle. I got the cosworth BCS installed but no change. I have checked all of the vacuum lines but all are plumb. All hoses are new or not cracked/torn. I am waiting for the EMS to come in the mail. Maybe it's in the ECU and not a mechanical problem ? If anyone is in the Azusa/Glendora/Covina area that can help ? I could use a fresh set of eyes. Mine are burnt.
turbored02 is offline   Reply With Quote
Old 06-10-2009, 10:00 PM   #2
norexyet
Member#: 39149
11 elantra
yea i said elantra
I would still do a smoke test to check for leaks. You could have a bad idle air control also
norexyet is offline   Reply With Quote
Old 06-11-2009, 05:41 PM   #3
turbored02
Member#: 119471
2002 Impreza
Sedona Red Pearl
I shall check that tonight.
Old 06-11-2009, 07:46 PM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Have you checked the vacuum line under the front passenger side of the manifold? I had that one come off and it caused the same problems.
Another thing to check is the adjustment of the throttle cable. Just the slightest extra tension will cause a high idle.
speedyHAM is offline   Reply With Quote
Old 06-16-2009, 07:05 AM   #5
turbored02
Member#: 119471
2002 Impreza
Sedona Red Pearl
I have checked all of the vacuum lines. Nothing is out of place. Is there a way I can test the IAC ? voltage ? or OHMs? something ?
Problem after 2.5 replacement swap, ej25 experts needed! shadymilkman129 Subaru Conversions 6 07-31-2007 02:26 PM
Problem after 2.5 replacement swap.. shadymilkman129 Normally Aspirated Powertrain 6 07-30-2007 07:12 PM
Hacking the 1.8 ecu after the 2.5 swap EcksJay Normally Aspirated Powertrain 7 06-16-2005 02:03 AM
Bouncing at 4500 rpms after 2.5 sti block swap DJIMPREZA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-01-2004 10:56 PM
i cant find a job. i have searched for about 5 weeks now. STEALTH-WRX Off-Topic 52 05-14-2004 04:55 PM
