Old 06-09-2009, 10:03 PM   #1
floridaWRX11
Member#: 206692
2009 WRX hatch blue
2004 SRT-4 silver
Default 09 wrx will these fit?
I am looking the Enkei RPF1 wheels 18x8. 45mm offset. would a 245/35/18 tire fit on those wheels? also, would I experience any rubbing? thanks in advance.
floridaWRX11 is offline   Reply With Quote
Old 06-09-2009, 10:25 PM   #2
grippy monkey
Member#: 131067
your "stance"
sucks
is your suspension stock? what's your camber like? stock? fenders rolled?
You should include all the details so there is no guess work.
18x8 in that offset with those tires should be a pretty easy fit any way you look at it on a 09 WRX. You may need to slightly roll your rear fenders or dial in a bit of camber if there is any rubbing under hard turns.
grippy monkey is offline   Reply With Quote
Old 06-10-2009, 09:59 AM   #3
floridaWRX11
Member#: 206692
2009 WRX hatch blue
2004 SRT-4 silver
hey man... sorry for leaving all that out. this car is bone stock it only has 3000k on it. the overall diameter is actually smaller than the 225/45/17's it comes with stock according to the tire calculator, i was mostly concerned with the change in width (from 225 to 245). i just really love the meatier/fatter/wider rubber look (as does everyone else), but I didn't want to overdo it, ya know.
Old 06-10-2009, 05:18 PM   #4
homer_atl
Member#: 210965
2009 WRX
i'd be interested in seeing your setup. i have an 09 wrx hatch also. will look into wheels when my tires go. post some pics if you get
homer_atl is offline   Reply With Quote
Old 06-10-2009, 06:06 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
You should fit fine with that size and offset.
tuskenraider is offline   Reply With Quote
Old 06-10-2009, 07:49 PM   #6
UbieDriver
Member#: 212957
Platinum Silver Metalic
Default stock kicks fit?
would the be any fitment issues if i we to put my stock dunlops(225/45r17s) on 17x8 rota g forces +48mm offset? my 09 wrx hatch has the stock suspension.
UbieDriver is offline   Reply With Quote
Old 06-14-2009, 07:10 PM   #7
SoLo OnE
Member#: 9941
www.djforums.com
what is the widest rim you can run without rubbing issues if you have coilovers. I want to run 18x9 +35 anyone else have this setup ?
SoLo OnE is offline   Reply With Quote
Old 06-15-2009, 12:14 AM   #8
08WhiteRex
Member#: 187453
2012 Mulletmobile
^^^You're going to have to camber and roll your rear fenders with that setup. Given your talking about a wrx...
08WhiteRex is offline   Reply With Quote
Old 06-15-2009, 11:52 AM   #9
mosc
Member#: 177401
2015 STi White
245/35/18 needs an 18x8.5" rim if not wider.
mosc is offline   Reply With Quote
Old 06-15-2009, 12:33 PM   #10
tuskenraider
Member#: 65699
15 WRX
WR Blue
Not at all.
Will 09 WRX/STI parts fit on a 2.5i nevets89 Interior & Exterior Modification 3 04-27-2010 11:37 AM
Will these fit my 06 WRX??? DigglerD Tire & Wheel 3 06-25-2007 08:57 AM
will these fit my 2005 WRX?? I have no idea ned4spd04wrx Tire & Wheel 4 11-28-2005 10:12 PM
will these fit my WRX wagon? 010111 Brakes, Steering & Suspension 4 12-15-2001 12:20 AM
Will these fit on my WRX? IMPREZIV Brakes, Steering & Suspension 2 04-19-2001 10:29 AM
