Old 06-10-2009, 01:39 AM   #1
e[tx]
Member#: 182437
04 STi
Wrb
Default 4g63 vs the EJ
Horsepower, dyno queens, roll racers. Everything is bias. I want to talk pure mechanics and if someone can inform me why an inline four motor can easily make 1000whp and our EJ's cannot that would be awseome. As a probably wrong guess Im going to say it has something to due with our cylinders being spread apart and the crank and cams and engine having to work more. Thats probably wrong but hey, educate me thanks .
e[tx] is offline   Reply With Quote
Old 06-10-2009, 01:42 AM   #2
Got Boost?
Member#: 113096
06 sti
there are so many reasons....this could get ugly
Got Boost? is offline   Reply With Quote
Old 06-10-2009, 01:44 AM   #3
e[tx]
Member#: 182437
04 STi
Wrb
Oh ****, what the hell am I supposed to search for to find such threads?
Old 06-10-2009, 01:46 AM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if you search you can see there are some references in regards to 4g63t's
mxpunk is offline   Reply With Quote
Old 06-10-2009, 01:47 AM   #5
SlverEJ20
Member#: 157158
05 WRX stage 2
I'm popping my popcorn before the show starts.
SlverEJ20 is offline   Reply With Quote
Old 06-10-2009, 01:48 AM   #6
brocksdad
Member#: 107352
Not Respectable
I'll start the list:
1) Cast block.
2) Flow of head. (Look at the size of the ports)
3)
brocksdad is offline   Reply With Quote
Old 06-10-2009, 01:51 AM   #7
Got Boost?
Member#: 113096
06 sti
1) Cast block.
3)
subaru motor is fairly new in comparison to the 4g63, turbo manifol has shorter runners on the 4g63, blah blah blah
Old 06-10-2009, 02:02 AM   #8
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i am no sure the cast block has so much to do with it, i have seen 4g63's that are sleeved as well, flow of heads is alot, dont have the dog leg. can spool a bigger turbos easier because of shorter runners, bore, rod length, stroke, all different. and like they have said 4g63 has be around alot longer, if you notice subarus are making good power 800whp+ ,and running great times in the 1320. and if you look at 1320 times the first evo to make it sube 8 sec has a solid axel from a toyota under it. also evos do not make 1000whp easy.
seanathanq83 is offline   Reply With Quote
Old 06-10-2009, 02:46 AM   #9
sku81
Member#: 143283
2001 bugeye wrx
white
[quote=seanathanq83;27024390]
1] flow of heads is alot,
2]dont have the dog leg.
3]can spool a bigger turbos easier because of shorter runners,
and like they have said 4g63 has be around alot longer, quote]
I agree with the 3 points above ...but
Ej20T started in 1989..when was the first 4g made?
Kris
sku81 is offline   Reply With Quote
Old 06-10-2009, 02:58 AM   #10
seanathanq83
Member#: 173241
1983 in the mitsubishi chariot, but from what i have seen it looks like it started as a 1.5 liter 4g61
Old 06-10-2009, 09:39 AM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
they are apples and oranges put simply...I can't think of one common variable between the two.
I will largely say the taller deck they have allows more stroke and smaller bore with a decent rod ratio.
Cylinder head flow isn't so much of an issue but I'd say more of 'balance'.
Our blocks (more importanly mains) join with two pieces allowing for lots of flex and wobble.
Exhaust manifold design limitations for us, likewise intake manifold limitations.
Our goofy firing order which also correlates with the above comment.
I'll also look at valve lift differences (we lose).
etc....
This thread has been done before several years ago.
Regardless of US not playing with the EJ25 platform for long, their 4G63 platform has largely stayed the same. The rest of world has had DOHC EJ's to play with for a long time. We didn't get the EJ25 (build motor of choice for U.S. Tuners and TRP) until the 2004 STi.
Old 06-10-2009, 09:49 AM   #12
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Yep
etc....
/thread
domestic_abuser is offline   Reply With Quote
Old 06-10-2009, 12:34 PM   #13
CatfaceType-R
Member#: 81102
shorter exhaust path, higher ve, better turbo placement(exhaust path), stronger and can take more knock counts before going bye bye
CatfaceType-R is offline   Reply With Quote
Old 06-10-2009, 01:18 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If you build up a Subaru engine for 1000whp, you can do it if you know how. The EVO's that do it are not anywhere near stock components at all.
Sleeve the block, balance the rotating assembly, choose a decent CR for the turbo to be used, good cam specs for revs, good flowing heads to allow it to breath, good fuel injectors/system and good pumps, then good oiling... a few others.
There are just not many 1000whp builders. You work the engine hard.
FuJi K is offline   Reply With Quote
Old 06-10-2009, 02:36 PM   #15
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
NOt saying it can't be done. Just WAY easier with the 4g63. Leave motors bone stock and add a 20g... the differences in the motors will be magnified. 4g63 will make significantly more power.. sooner... and with a broader powerband. If you're only goal is to make 1000whp out of a import motor... you don't choose a Subaru to mod on. People that go to lengths with these cars just love them for one reason or another. Not to mention.. our community is way better IMO.
japslapr is offline   Reply With Quote
Old 06-10-2009, 04:28 PM   #16
3MI Racing
Member#: 200987
+1 to that..no doubt it an be done but vastly different communities...Evo boys also spend more.
3MI Racing is offline   Reply With Quote
What does the EJ mean with our engines Kevin Thomas Normally Aspirated Powertrain 33 03-14-2011 09:54 AM
What's the combustion sequence of the ej series engines? The Enemy Factory 2.0L Turbo Powertrain 26 03-13-2003 07:07 PM
Part number For the EJ 20 99 or newer chrisww2 Newbies & FAQs 8 10-19-2000 03:01 AM
stroking the EJ engine for more displacement chyisan Technical Forum Archive 31 09-06-2000 01:53 PM
Message Board Statistics All times are GMT -4. The time now is 02:35 AM.
