Old 04-25-2002, 01:50 AM   #1
cruzito
Member#: 11159
2000 ImprezaRS
Unhappy Idle problem
Hi guys, I have situation going on with my RS. Three days ago, the CEL on MY00 RS came up, and it was a EVAC code cause my wife forgot or the gas cap was loose. After getting it back from the dealer, it started to display a weird problem. Everytime you start the engine it will stall first, start it again then it would run fine after that.
Is this normal? Have any of you fellows encountered this problem?
An input is greatly appreciated.
cruzito is offline   Reply With Quote
Old 04-25-2002, 02:49 AM   #2
spiralsmurf
Member#: 16085
2005 STi
dude my car did that like 3-4 times yesterday. it starts for a second then shuts off. i start it again and its fine. i had a cel but i got it cleared and the light hasn't come up since.
spiralsmurf is offline   Reply With Quote
Old 04-25-2002, 03:26 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
odd mine did it yesterday as wellll...what the hell is going on...started was running fine and died...i figured it just slightly missed..
jeremy
Old 04-25-2002, 06:38 PM   #4
cruzito
Member#: 11159
2000 ImprezaRS
Question Hmmm...
Should I worry, even if the CEL is off? Or should reset the ECU and see if that's the fix? By the way, how do you reset the ECU without a diagnostic tool? Thanks.
Weird idling problem - Very high idle Oodles-of-Noodles Mid Atlantic Impreza Club -- MAIC 21 02-04-2010 10:25 PM
Crap Idle Problem, Can't hold idle, sometimes dies when I push clutch in TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-02-2008 09:40 PM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
Update on my idle problem Warp3 South East Region Forum 0 01-06-2001 09:47 AM
idle problem - with A/C on svxxx-26 SVX Forum Archive 7 11-21-2000 06:43 AM
