Old 06-10-2009, 01:14 PM   #1
Azxster
Member#: 185659
Default How to rewire DRL to fog lights?
I tried searching but couldn't find anything.
Does anyone know how to rewire such that the fog lights acts as the DRL?
Car: 2008 Impreza
Azxster is offline   Reply With Quote
Old 06-11-2009, 02:05 AM   #2
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Ummm, maybe use the foglight mod to make the foglights come on with acc power?
trueno16v is offline   Reply With Quote
Old 06-11-2009, 04:16 AM   #3
aboothby
Member#: 111994
2006 STI
WR Blue Pearl
That would take quite a bit of re-wiring but it can be done and with a small ammount of pre-design.
The first problem is that the DRL function and the regular headlights are controlled by the same wire on the same bulb. The DRL is simply the product of a relay switch placing a resistor in series with the bulb to lower the voltage, thus reducing the luminous output.
The best way to go would be to set it up so that when the relay - which normally switches to apply the resistance - will instead divert the voltage to the fog bulbs. If you want to have control over the fog lights when the lights are on, you will need to incorporate diodes into the design.
The only true way to start and have it done right is to examine the electrical schematic in the service manual and re-draw the circuit so that it will do what you want, then re-wire the car accordingly.
It is not a hard thing to do, but it is an important step if you want to do it right and have it be electrically sound.
aboothby is offline   Reply With Quote
Old 06-22-2009, 09:27 PM   #4
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Default DRL fog lights
There are a few ways and options in doing this. First, what do you want it to do? Do you want them to behave exactly as the OEM highbeam drl (dims on and off when the car goes form Part to drive and/or when the handbrake is pulled)? Or do you want them to be fully on when your car is on?
1) If you want the OEM-dimmed way, you need to do some wiring behind the front bumper (a bumper cover removal will make it much easier).
2) If you want the simple on off way (only on when key is turned to ON position) then the wiring will be under the dash. That has actually been addressed in another thread:
http://forums.nasioc.com/forums/show....php?t=1706871
I'd opt out for the second method. Its easier and you dont have to go fishing around for the DRL module. Furthermore, the second mod only needs like one short 22gauge wire as opposed to several longer lower gauge wires for lamp illumination.
Henry H is offline   Reply With Quote
Old 06-22-2009, 09:59 PM   #5
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Good point aboothby, but I am worried about the diodes. I assume that the diodes will positioned after the DRL resistor in the right bumper to prevent the voltage going back towards the DRL module when you supply the full 12V to light the fogs, but that type of amperage will sure burn up most diodes, unless you dont mind paying a lot of money for a high amp diode.
I only assume that's the location you anticipate for the diode to be because I don't forsee how you can break the circuit of the drl relay (or module) when you turn on the fog lamps. Unless there is a relay that will break a circuit when a current is passed through the relay's switch.
I know, I know, if the highbeams are able to do it then why can't the fogs do it? Well I suspect that is what the DRL module is doing (btw, I can't find that damn module anywhere on my 08). You can swap the connection of the wires after the hi-beam\fog switches before the DRL module, that would be one solution (that's like re-allocating the DRL module to sit on the fog light circuitry). Or we can just swap the the wires just before the lamps and after the DRL module. But you don't wanna look stupid when you try to flash someone and wind up turning on your fog lamps. Those options will be a serious PITA and not worth the trouble at all.
But, as I stated in my last post in option 2, the easier way is to just do a simple wiring under the dash and be done with it. Just leave your fog lamp in the on position and the fogs will switch on and off whenever your key is turned in the appropriate position.
Cheers!
Henry
Old 06-22-2009, 10:53 PM   #6
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
AZXSTAR!!!
I just realized you already asked this question on the forum I showed you.
There is a much easier solution IF you still plan on having HID fogs!!
First, a couple things to address.
1) Don't allow the fogs to dim. That does not work for HIDs. Ballasts must get a constant 12 volts. The dimming that you see is caused by the DRL resistor. 12 volts come in hit the resistor and a lower voltage goes out to the bulbs. If ballasts gets less than 12 volts for the HIDs you'll get flickering (not good)
2) There are many that advocate against HID fogs...mainly because of the brightness it puts out that can blind others. I myself have HID fogs but I aimed them real low so the beam will only catch the road.
3) The wires that sends 12 volts to turn on the DRLs goes to the resistor, the voltage drops and turns the hi-beams "haflway." We want to BE SURE the wires going TO THE RESISTOR is able to sustain 30 amps. This we dont know for sure. If it can, your mod is easy, if not then we need to add a relay circuitry.
On to the mod (the easy, not-really-preferred way):
***DISCLOSURE: The steps for this kind of modification assumes that the wires coming from the positive terminal of the battery to the Daytime Running Lamp (DRL) Resistor have a proper guage to operate two halogen bulbs without the consequence of overheating and/or electrical fire.***
*Disconnect neg terminal of battery
-Remove the bumper cover
-Locate the DRL Reisistor (a ribbed aluminum casing surrounding a ceramic block with a wire coming out of both ends) approximately the size of a boxed soap bar. It should be near the other horn speaker.
-Unplug and remove resistor
-At each fog lamp identifiy the 12volt wire and cut it near a couple inches from the harness. Cap off the cut wire on the 12 volt feed side. Don't do anything to the ground wire.
-Run a wire (approx 10 guage) from the wire at the removed DRL resistor to each of the wires you just cut at the fog lamp harnesses (harness side only)
Final notes: By removing the resistor we effectively have a full 12 volt source that acts like the OEM DRL (always on when car is on/not in park/parking brake down and turned off otherwise). However we now do not have ANY control over the fog lamps (neither did we with the highbeam DRL).
Personally, if I really wanted my HID fog lamps to act like the OEM DRLs I would add another relay circuitry to prevent a possible electrical fire. The relay addition method would require a bit more work. But since you want an easy way, there you are. I cannot find a fuse for the DRL so I cannot assume whether or not those wires are safe for this kind of application.
Henry
how to remove 06 wrx fog light covers. asherbo Interior & Exterior Modification 15 12-16-2009 07:22 PM
How to enable DRL daytime running lights on JDM GC8 WRX? stigc8 Interior & Exterior Modification 12 04-18-2008 09:20 AM
how to swap DRL to small parking light on 07?? cowboysuby Electrical & Lighting 4 01-15-2008 12:25 AM
How to pop out the fog light compartment cover on non-fog light STis (06) magnumeagle Newbies & FAQs 5 03-28-2007 07:39 PM
Can someone please post directions or url on how to mod a MY00's fog lights s-one Interior & Exterior Modification 0 06-23-2001 09:23 PM
