![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 195039
So I just got the 07 WRX oem 17x7 wheels and I am awaiting installation, I assume they will fit fine on my 08 2.5i - correct me if I am wrong. But I was wondering what people thought of tire size. Will I be okay with 225/45/17 or do I need to go smaller. Everything is stock except I have pinks (springs), and sway bars (aftermarket). Thanks guys, ps i don't know anything about this stuff. Thank's.
#2 |
Member#: 22928
NESIC
Vehicle:2011 Outback Sport Black |
You'll be fine with 225s.
#3 |
Member#: 195039
Some people say that it will mess up the speedometer, or the suspension is not correct for this size. Any explanation. Thanks
#4 | |
Member#: 22928
NESIC
Ryan |
#5 |
Member#: 195039
so does the lower perch refer to the lowering springs the pinks, thank you for all your help.
#6 |
Member#: 22928
NESIC
The perch is the bottom cup of the strut that the springs sit on. Looks like a funnel. When you stick your finger at the inside top of the tire, that's where the perch is.
#7 |
Member#: 211632
Vehicle:2008 Impreza OBS Ob black/DGM |
At an indicated 65 mph on 205/55/16 stock tires, you will be actually driving 65.25 mph on 225/45/17 tires, hardly a difference to be worried about. Is a 7" width wheel specidified for use with a 225 wide tire, make sure of this. I have not checked. Use this link to play around with various scenarios:
http://www.discounttiredirect.com/di...foTireMath.jsp |
#8 |
Member#: 177401
Vehicle:2004 STi White 16G powered lagless fun |
Spedo difference is misleading. Tires generally have about 11/32 of treadwear top and bottom. The difference between a worn tire and a new tire can be over a half an inch of overall diameter (~2% different than stock). Obviously there's some margin there anyway so don't sweat it. Within 2% is fine.
| Thread Tools | |
| Display Modes | |
| Michelin Primacy tires on 08 Impreza 2.5i | Old_Lady_Driver | Tire & Wheel | 2 | 02-28-2010 12:45 PM |
| Wheel and tires fit on 08 Impreza 2.5i PP | juny102004 | Tire & Wheel | 5 | 05-10-2009 05:59 PM |
| Will a Catback for an 08 WRX fit on an 08 Impreza 2.5i? | StickyBrokeConfused | Newbies & FAQs | 3 | 06-06-2008 04:35 PM |
| 08 Impreza 2.5i or 08 SI? | jtom12 | Impreza Forum | 8 | 02-05-2008 06:03 PM |
| 08 Impreza 2.5i ? | 240c | Normally Aspirated Powertrain | 106 | 01-11-2008 02:10 PM |
