Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-10-2009, 07:57 PM   #1
Alaskan_awd
Member#: 117002
2010 >40psi, oh yes!
POWERSTROKE
Default 06 Wagon setup with Epic springs?
Did allot of searching but not allot of setup with Epic springs.
Could you guys give me an idea if I will have any rubbing issues. It will be on Epic springs (supposed to be 25mm lower in the front and a little less in the rear) no fender rolling.
Rota G-Force 17x8 +48
Yokohama S.drive 245/40/17
or
Rota Tarmac 2 17x7.5 +48
Will either of these rub, or do I need to go with 225/45/17's? No auto x'ing or racing just DD.
Alaskan_awd is offline   Reply With Quote
Old 06-11-2009, 04:36 PM   #2
mosc
Member#: 177401
2015 STi White
Not a wagon expert by any means but a lot of wagon guys have rubbing problems even with 225/45/17 on a +48 rim. 245 on a wagon is much more challenging than on a sedan, especially on stock spring rates. I feel pretty comfortable in telling you that 245/40/17 +48 on a wagon without fender rolling is NOT GOING TO HAPPEN!
BTW, 245/40/17 requires a 17x8.5" to 17x9.5" wide rim. 17x7.5" really doesn't cut it and 17x8" is still slightly too narrow (although many will say that's fine)
mosc is offline   Reply With Quote
Old 06-11-2009, 05:34 PM   #3
kilfarsnar
Member#: 106116
2016 VW Golf R
Limestone Grey
With either setup you will likely have rubbing issues. 245 is really wide for a wagon. I am running Goodyear Eagle F1 235/40/17 on a 17x8 +48 wheel with Wagon pink springs. I haven't rubbed yet, but I expect to roll the fenders at some point. Looking at the position of the tire relative to the fender, it is clear that it will rub with enough spring compression.
kilfarsnar is offline   Reply With Quote
Old 06-14-2009, 03:13 PM   #4
Alaskan_awd
Member#: 117002
POWERSTROKE
So if I went with a 225 what offset should I shoot for on the rims?
Old 06-14-2009, 03:39 PM   #5
mosc
Member#: 177401
2015 STi White
As much as possible. Hopefully over 50
Anyone using dspecs with epic springs? somaguchi Brakes, Steering & Suspension 4 01-12-2010 09:17 PM
06 Wagon struts with Pink Springs plmrass MWSOC Private Classifieds 2 04-11-2009 08:32 PM
FS: 04 wagon struts with Prodrive springs madspecvman Suspension/Brakes/Handling 9 01-07-2007 10:06 PM
STi replica rear aprons on 06 wagon (NOW with more pics!) wrxpunk Interior & Exterior Modification 6 06-01-2006 09:36 AM
wagon owners with Prodrive springs please read randolph-rs Brakes, Steering & Suspension 8 04-21-2003 04:48 PM
