Old 06-10-2009, 08:35 PM   #1
Rwolf
Member#: 210768
2009 Impreza Hatch
Default 205/55R16 on 16x8?
Should I run into any problems with this setup? I bought some Gramlights, but can't afford new tires for awhile and figure I would just swap my 2009 OEM tires.
Just not sure if 205 is too narrow for 16x8"
Rwolf is offline   Reply With Quote
Old 06-11-2009, 12:27 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d00000d...the tires suck...and are too narrow for an 8" wheel
that will be stretched all to helll
Old 06-11-2009, 02:13 AM   #3
Rwolf
Member#: 210768
2009 Impreza Hatch
Yeah I may have bit more than I can chew. Really wish they were 7.5
Should've q'ed the local tire shop before I plunked down the cash.
Also Test fitted and looks like rear clearance is fine, not so much on the front.
Old 06-11-2009, 12:47 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
it isnt the size...it is the offset
an 8" wheel on that car is fine....but not with a low offset
see if you can swap for a higher offset wheel
Old 06-11-2009, 12:51 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
those wheels---in higher offset.... and a 245/45 tire would be great
Old 06-11-2009, 02:41 PM   #6
Rwolf
Member#: 210768
2009 Impreza Hatch
Hmm the offset is +45. I was also abit concerned since their was about less than a inch touching the struts in the front. I wonder if I would rub anything using 225's and stock susp.
I know the previous owner said he ran 245's but with coil overs and rolled fenders on his wagon.
Old 06-11-2009, 02:44 PM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
205/55-16 Rim Width Range...... 5.50 to 7.50
Old 06-11-2009, 03:47 PM   #8
mosc
Member#: 177401
2015 STi White
205/55/16 is a mere 0.88% wider than an 8.0" rim. Spec is >5% for a 55 sidewall. People mount further from spec than that around here but definitely a bad stretch.
mosc is offline   Reply With Quote
Old 06-11-2009, 04:07 PM   #9
Rwolf
Member#: 210768
2009 Impreza Hatch
Thanks for the advice so far. Decided to wait out till I can afford proper tires.
Although the local tire shop said it should be fine, but risk having tire leaks.
Old 06-11-2009, 04:10 PM   #10
mosc
Member#: 177401
2015 STi White
I'd be looking at 235/45/16 tires for those rims btw assuming they are indeed +45. Not ideal but not bad. How light? That's the real thing to brag about.
Old 06-11-2009, 04:54 PM   #11
Rwolf
Member#: 210768
2009 Impreza Hatch
15.6 lbs?
Trying to get wider tires. Replacing 205/55R16 with 225/55R16? bushwahkhan Tire & Wheel 28 01-13-2010 06:07 PM
FS NJ 205/55R16 Blizzak LM-25's on OEM 16s Sno-Bound Wheels/Tires 7 12-19-2007 10:21 PM
WTT or FS:My Dunlop M3's 205/55R16 on 16" steels for comparable 15" snow tire pacakge paultg New England Impreza Club Forum -- NESIC 13 01-05-2006 12:23 PM
205/55R16 on an L? jester409 Tire & Wheel 4 09-20-2005 11:39 AM
Gas consumption difference on 205/55R16 VS 225/50R16? dcwrx2 Tire & Wheel 4 05-23-2005 04:51 PM
