Old 03-23-2012, 06:53 PM   #8026
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Originally Posted by .clipse View Post
<3 <3
For some reason I wasn't really feeling the wheels at first (maybe cause I saw the other pic on my phone) but after this pic I'm really liking them!! Nice pick up!!
How flat are your rears rolled?? I got mine done today and he gave me a good probably 1/2"+ in space but he was hesistant to do it completely flat and crack the paint... curious how far you went??
Let's Spool is offline   Reply With Quote
Old 03-23-2012, 07:22 PM   #8027
.clipse
Member#: 212265
2013 Legacy
thanks bro! heh, i actually rolled the front and rears FLAT to a pinch, with a slight pull in the front.
did the guy do them with a heatgun? paint cracking shouldn't be too big of an issue if done right with a heatgun.
what wheels/specs are you planning on picking up?
.clipse is offline   Reply With Quote
Old 03-23-2012, 07:38 PM   #8028
Jakubgt
Member#: 233051
I should have the latest version of TXS newest CBE exhaust sometime in April.
I was told that the tips are going to be bigger, less noise while cruising, a quieter idle, and about the same decibels at WOT. No more banging after two years of suffering.
Jakubgt is offline   Reply With Quote
Old 03-23-2012, 07:42 PM   #8029
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
+ another 1 for the TSWs love everything about mien.
And yes I know it's a wagon but you can pretend it as sedan
RoidRage is offline   Reply With Quote
Old 03-23-2012, 07:49 PM   #8030
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Aight ima have to go look and see how much more can be done... Yea he was and the the paint wasnt cracking but he was worried about a seam?? I think he said
18x9.5+40 nto3m w/ 245/35... The fronts are rolled pretty flat and have a slight pull... The rears are my main concern
Old 03-23-2012, 09:24 PM   #8031
.clipse
Member#: 212265
2013 Legacy
ohhhh... alrite ya the fitment should be roughly the same as the 18x9 +30. you shouldn't have too much of an issue unless you're pretty low. also the 35 sidewall (w/ 245 stretched) on the tires should help with clearance.
if you dont plan on tucking tire, you should be fine. but on the safe side, i'd go back and try and get the rears rolled pretty flat so you can go pretty low
Old 03-23-2012, 09:51 PM   #8032
GoSloTurbo
Member#: 195743
08 wrx built ej25
lots of e85
Originally Posted by 1slow wrx View Post
Crappy cell pic of my freshly coated wheels...
To each his own!
i love it!!
GoSloTurbo is offline   Reply With Quote
Old 03-23-2012, 10:05 PM   #8033
GoSloTurbo
Member#: 195743
08 wrx built ej25
lots of e85
she is diirty, just took the snows off for the year!!!
Old 03-24-2012, 12:01 AM   #8034
TrueToForm
Member#: 233486
2013 FR-S
Oh snap, narrow bodies back in business.
TrueToForm is offline   Reply With Quote
Old 03-24-2012, 01:14 AM   #8035
anthony12052
Member#: 178973
2000 2.5RS
gray/silver
added the racks a few days ago
anthony12052 is offline   Reply With Quote
Old 03-24-2012, 10:32 AM   #8036
riceh8r0512
Member#: 216206
2009 WRX
Dark Gray
Nothing nearly as special as some of the other wheels in this thread, but it's my first set of after markets. 18x8.5 +48 going to be wrapped in 235/40R18 star specs as soon as my valve stems get in (freaking next Thursday).
riceh8r0512 is offline   Reply With Quote
Old 03-24-2012, 11:47 AM   #8037
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Aight kool.. thanks for your help!!
Old 03-24-2012, 05:49 PM   #8038
08BlackWRXCT
Member#: 225296
2015 WRX Premium
Crystal White Pearl
Just got these.... i have them on but wheel gap is soooo bad to post pics, will post some once i drop it...
08BlackWRXCT is offline   Reply With Quote
Old 03-24-2012, 10:08 PM   #8039
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
They look really sharp.
How is the weight and price?
Breezio is offline   Reply With Quote
Old 03-24-2012, 10:36 PM   #8040
JayBoogs
Member#: 285290
2008 Impreza WRX 4dr
Lightning Red Pearl (LRP)
A few shots from this past weekend with my fellow 3g sedan brothers
Check my Flickr for more
http://www.flickr.com/photos/jaywesp...7629289285564/
JayBoogs is offline   Reply With Quote
Old 03-24-2012, 11:21 PM   #8041
jdwatermann
Member#: 260655
2008 WRX
Grey
Default Fitment Question
Hey guys I have done some searching but seems to get me more confused. I am totally lost when it comes to wheels and tires. I have read about offset making sure I get the correct ratio to not affect suspension parts.
I am looking to get some 18" Grids, but i was wondering how wide? I was hoping to get 8.5 or 9.5 but dont know if i will have rubbing issues or if they will clear struts. Also i cant find the proper offset for a wheel that wide, what is the acceptable range for those widths?
I am running stock struts, and stock suspension. Hoping to get coilovers soon so wanting to know these questions and understand if I will be able to fit them, and if when i get coilovers and go a little lower will i run into problems.
Thanks for any help, sorry for the noob-ness.
jdwatermann is offline   Reply With Quote
Old 03-24-2012, 11:47 PM   #8042
.clipse
Member#: 212265
2013 Legacy
^ typically... if you want a 'safer' setup meaning not worry about rubbing issues or suspension clearance, go with the 18x8.5 +44...
but the wheels will kinda look flat, less concaved and meh
18x8.5 +44
but since you have plans for coilovers, might as well go big or go home. you won't be disappointed in the future when you want to run a wider setup and had already made the mistake of already buying a narrow, 'safer' setup. just take the necessary steps in making sure they'll fit without issues (aka rolling you fenders). but then again if you really don't care about looks and are more concerned about running a safer setup, stick to widths 7.5" - 8.5" with atleast a +40 offset.
but dont they look that much better
18x9.5 +38
Old 03-25-2012, 02:12 AM   #8043
jdwatermann
Member#: 260655
2008 WRX
Grey
18x8.5 +44
18x9.5 +38
Thanks alot for the info, I think i may go with the 9.5" and just get the fenders rolled.
Think i will have to do any pulling? And no camber correct?
Old 03-25-2012, 01:51 PM   #8044
Breezio
Member#: 234357
2009 WRX
Depending on the tire size you plan to run, your going to need camber and flat rolling (if not more) to run the 9.5 +38 grids on a narrow body, with an 'appropriate' size tire for that width (255 or wider). You could always stretch some 225's on them and make it take alot less work. There are plenty of guys that have run those exact wheels on the narrow body sedan. Maybe search for them and ask them directly about them.
Did you ever run that setup .clipse?
Me personally, I'd get the 8.5 +44 grids with either 235/40R18 tires or 245/40R18.
The 235's shouldn't need any work to fit, and the 245's would possibly need some. But that's just my own personal tastes
Old 03-25-2012, 02:28 PM   #8045
.clipse
Member#: 212265
2013 Legacy
^ i ran 18x9.5 +30 with 235/40 and i'm currently on 18x9 +30 with 225/40. on my BC coils, the fronts are almost maxed (struts almost on CV boot) and the rears are just as low. i rubbed slightly on 18x9.5 +30 with 235/40's, but i've had zero rub with the 18x9 with the 225/40's.
it all depends on how you want to go really. my fenders are rolled flat but only my front fenders are slightly pulled (helps with full lock turning ). as far as camber correction, i don't have a camber kit, LCA's or what have you. just your basic natural camber. have a good reputable alignment shop dial in your alignment numbers.
Old 03-25-2012, 03:02 PM   #8046
jdwatermann
Member#: 260655
2008 WRX
Grey
@Breezio @.clipse
I want to thank you guys for all the info! I am gonna go with the "safer set up"
I am gonna go with 18 x 8.5 +44 and wrap them in Hankook Ventus Evo k1100 235/40/18.
I will also be getting BC coilovers over summer so hopefully new look coming soon.
Old 03-25-2012, 10:12 PM   #8047
djburn1200
Member#: 54081
2003 WRX
MBP
Figured I would get in on this, here is my addition
djburn1200 is offline   Reply With Quote
Old 03-25-2012, 10:55 PM   #8048
Breezio
Member#: 234357
2009 WRX
I thought I remembered you having a pretty 'extreme' setup..
I'm sure you are darn happy with it.
Old 03-25-2012, 10:56 PM   #8049
Breezio
Member#: 234357
2009 WRX
Originally Posted by jdwatermann View Post
@Breezio @.clipse
Get it done and get the pics up!
Old 03-26-2012, 12:32 AM   #8050
.clipse
Member#: 212265
2013 Legacy
if i could turn back the hands of time, i would've gotten the 'extreme low' BC coils. but then again, my bumper wouldn't be too happy with me, seeing as i already scrape with regular BC BR's going up my driveway
WTB: 2008-2010 WRX/Impreza Sedan chrome trunk trim predavore Private 'Wanted' Classifieds 4 05-17-2014 10:00 PM
the BIG 2008-2010 WRX/STI thread bhhamblin Member's Car Gallery 15981 05-20-2010 12:28 PM
SOLD NY 2008-2010 WRX Sedan Rear Spoiler MINT....PICTURES ADDED wrxphantom Exterior/Styling 14 03-18-2010 10:50 AM
