Old 12-11-2012, 07:41 AM   #9526
vlenhoff
Member#: 174113
2010 WRX stage2 sed
Originally Posted by dScooby View Post
I rattlecanned my wheels, duplicolor gold. i like it cause i can just touch up whenever i need to
Pistures, please
vlenhoff is offline   Reply With Quote
Old 12-11-2012, 09:18 AM   #9527
tehknikhal
Member#: 227548
2009 09 WRX Sedan
Obsidian Black Pearl
Powder coat FTMW! Lol.. $300 sounds cheap to me. Maybe I'll spend that money and do it myself haha
tehknikhal is offline   Reply With Quote
Old 12-11-2012, 10:03 AM   #9528
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Originally Posted by subi21 View Post
Yea I'd like to have a 235/35 or something with a nice meat to it. Prolly won't slam it super low just a nice fit. So I could lower it a little and be fine with a 18x8.5 on a 235?
235/35/18 is going to give you a 3.2" sidewall which is on the small side, so be prepared for that; stock is 4" by the way. What size/offset wheels you get is going to depend on whether or not you want to get fender work done. Also, if you're going with 235s, you won't to go with anything wider than a 8.5" wheel unless you don't mind stretched tires. You might be able to run a 235 on a 9" wheel if you get a brand of tire that tends to run wide, like Federals.
SWP n Gold is offline   Reply With Quote
Old 12-11-2012, 10:08 AM   #9529
tehknikhal
Member#: 227548
2009 09 WRX Sedan
225/40 on a 9" wheel doesn't even look stretched. But I mean you can tell there is a slight stretch, but its no going to kill you.
Why not just run 235/40? Am I missing something? LOL
Old 12-11-2012, 11:00 AM   #9530
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
I run 225/40s on an 8.5" wheel right now and they're stretched. I'm switching over to 235/40 Federals in the Spring which measures closer to a 245/40. And yes, I would recommend a 235/40 to him so he doesn't have stretch and so he'd have a decent sidewall, but he said he wanted a 235/35.
Old 12-11-2012, 12:18 PM   #9531
thenick
Member#: 199580
i been hatin'
Hellas since 2012
thenick is offline   Reply With Quote
Old 12-11-2012, 01:09 PM   #9532
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
If you want a nice meat to it, I'd go with the 40 over the 35 but other than that you should be fine with that setup... If you dont mind rolling your fenders you may want to consider the 245/40...
Let's Spool is offline   Reply With Quote
Old 12-11-2012, 02:05 PM   #9533
subyhatch05
Member#: 296700
you want meat but wanna put a 235 on a 18x8.5? i dnt think the fenders will need rolling with a 245 tire
subyhatch05 is offline   Reply With Quote
Old 12-11-2012, 02:13 PM   #9534
subi21
Member#: 338346
2010 Wrx
Yea I'd like a wide tire but not sure if I'd need rolling with a 245/35/18 or if I could get away with a 40?
subi21 is offline   Reply With Quote
Old 12-11-2012, 02:52 PM   #9535
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Let's Spool is on 18x9.5 +40 and 245/35/18s and is running coilovers so I would look into what mods he did to his fenders to make that setup fit. I believe he rolled all four corners. Or a less aggressive setup like mine, which is 18x8.5 +44 and 235/40/18s on Epic springs/Koni shocks and stock fenders.
Old 12-11-2012, 03:58 PM   #9536
subi21
Member#: 338346
2010 Wrx
Ill ask him. I'd like a 18x9.5 but all the offsets are like 30-35mm on the rims I like. Did u roll any of your fenders
Old 12-11-2012, 04:04 PM   #9537
tehknikhal
Member#: 227548
2009 09 WRX Sedan
I would just go ahead and roll the fenders because you're going to need to, IF you're going to lower your ride. Even a slight roll won't hurt, honestly..
I'm running an aggressive set up, ended up having to roll all fenders and slightly pull the rears. I'm going to have to do the same for the fronts soon when I go lower HAHA.
Old 12-11-2012, 04:16 PM   #9538
subi21
Member#: 338346
2010 Wrx
What type of rims and et are you running? Yea I plan on lowering the car on bc coilovers here very shortly
Old 12-11-2012, 04:17 PM   #9539
tehknikhal
Member#: 227548
2009 09 WRX Sedan
18x10 30 offset. About ready to tuck tires. lol
Old 12-11-2012, 04:26 PM   #9540
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
No, my fenders are completely unmodified.
It's not mandatory on all setups, but it will be for an 18x9.5 setup on coilovers. I'm lowered and didn't need to roll, but I'm on 18x8.5s and lowering springs.
Old 12-11-2012, 04:45 PM   #9541
tehknikhal
Member#: 227548
2009 09 WRX Sedan
I guess I should have said it wasn't mandatory. my fault, but its best to be safe ya know?
Because I left the fronts untouched and I was pulling the fenders out instead of in.
Old 12-11-2012, 09:39 PM   #9542
vlenhoff
Member#: 174113
2010 WRX stage2 sed
Soon i'll post some good pictures, but here is a quick one [car still filthy]
Old 12-11-2012, 10:16 PM   #9543
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
^ Kinda like the paint on that front bumper, it's different.
Old 12-11-2012, 11:08 PM   #9544
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Yea stuff around the south is always cheaper though lol. And good luck finding a oven big enough to bake your wheels lol.
Edit: did you mean pay someone I do it for you also or spend the 300 bucks and powder them yourself?
Gregor91 is offline   Reply With Quote
Old 12-12-2012, 12:06 AM   #9545
vlenhoff
Member#: 174113
2010 WRX stage2 sed
Thanks Swap n' Gold, I've always been a fan of your rides. It is a 3m flat black vinyl, and I had to use a heat gun to make it adhere properly to all parts of the air dam. It lasts 5 years and it protects the paint. If i knew it was going to look this good, I would have just painted it flat black.
Old 12-12-2012, 09:50 AM   #9546
tehknikhal
Member#: 227548
2009 09 WRX Sedan
I was saying I can either pay the $300 to get it done from a pro.
OR
Spend that $300 on getting supplies. I wasn't being clear enough. HAHA. Besides I think I can fit my rims into my oven. Just one at a time.
It's hard finding a local hook up out here man.. nobody gives a **** about you unless you're blowing money at their face. (True story) Even the "homies" don't get hooked up even when you know the owner, its bullsh...!!
Old 12-16-2012, 06:33 PM   #9547
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Is this now a 2008-2010 WRX Thread? (Hatches welcome?)
QwaktastiK is offline   Reply With Quote
Old 12-16-2012, 07:39 PM   #9548
tehknikhal
Member#: 227548
2009 09 WRX Sedan
Might as well just start it here.
Old 12-16-2012, 07:47 PM   #9549
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Why don't you just start a 08-10 wrx sedan/hatch thread??
Old 12-16-2012, 07:55 PM   #9550
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
Edited.
WTB: 2008-2010 WRX/Impreza Sedan chrome trunk trim predavore Private 'Wanted' Classifieds 4 05-17-2014 10:00 PM
the BIG 2008-2010 WRX/STI thread bhhamblin Member's Car Gallery 15981 05-20-2010 12:28 PM
SOLD NY 2008-2010 WRX Sedan Rear Spoiler MINT....PICTURES ADDED wrxphantom Exterior/Styling 14 03-18-2010 10:50 AM
