Old 06-11-2009, 01:06 AM   #1
impressions
Member#: 190815
1994 EJ22E, T225
Honda Blue
Default Any ideas on this? my reverse light is on when in gear.
Hi guys, i have a 93 impreza it is a manual gear box, but i just noticed that my reverse light is on whenever i am in gear, so everytime i switch gears my reverse light goes on. What could be the problem? any advice to check? a dirty connector? greatly appreciated.
impressions is offline   Reply With Quote
Old 06-11-2009, 01:59 AM   #2
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Pull out the bulbs, problem solved.
trueno16v is offline   Reply With Quote
Old 06-11-2009, 07:23 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not the correct answer.
If both reverse lights are on, most likely the reverse switch has failed. The switch is located on the transmission.
If only one side stays on and the other side operates normally, the problem is in the light assembly (bad connection, wrong bulb type or bulb installed incorrectly).
Old 06-12-2009, 01:26 AM   #4
impressions
Member#: 190815
1994 EJ22E, T225
Honda Blue
Thanks i really don't want people to be scared to follow my car, the reverse switch is on the transmission so does that mean it would be always on? because it does turn off during neutral, only when i am in any gear, is there a ground that connects on the shifter?
Old 06-12-2009, 01:14 PM   #5
Wires
Member#: 36677
2003 WRX Wagon
Sedona Red
Has any work been done to the transmission? That sounds like the reverse light wires are connected to the neutral switch. (off in neutral, on in an gear, provided your car has one that operates in this way, closed in gear)
Otherwise, it would be some sort of strange linkage problem that activated the reverse light switch in any gear, instead of reverse.
Wires is offline   Reply With Quote
Old 06-14-2009, 02:12 AM   #6
mowgli29
Member#: 203438
I'm having the same problem. I just dropped the tranny to replace the clutch, and while it was out, my dad replaced the 1st and 2nd gear synchros.
Did I do something when re-installing the tranny, or did he do something when re-assembling it?
EDIT: I've got an 02 WRX.
mowgli29 is offline   Reply With Quote
Old 06-27-2009, 10:04 AM   #7
rbimdxe
Member#: 214102
2000 WRX Evo 4
Yellow
Bit late I know, but check the plugs on the Gearbox are correctly conencted.
Mate of mine had to replace his input shaft and afterwards his reverse lights stayed on. Dropped the tranny twice to try and figure it out. Then the idea hit us to swap the connections over.
Worked normally. You can swap them around with the car on jack stands without dropping the box to check.
rbimdxe is offline   Reply With Quote
Old 06-27-2009, 10:40 AM   #8
mowgli29
Member#: 203438
Yup, turns out my switches were put in the tranny backwards, so I swapped them. Took all of about 10 minutes. Not hard at all.
My Airbag light is on??? Mike7 Newbies & FAQs 7 03-04-2010 02:40 AM
Sti reverse lights staying on in every gear stoner Electrical & Lighting 9 06-17-2009 12:50 AM
did 6mt swap now my abs light is on akcel Brakes, Steering & Suspension 6 05-20-2007 02:23 PM
Got caught in the snow in lake tahoe..... now my abs light is on birenroy Service & Maintenance 4 03-01-2007 03:24 AM
No horn, Cruise control's bad and my Airbag light is on? Paxtonb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-04-2004 12:22 PM
