Old 06-11-2009, 01:14 AM   #1
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Default Feeler: Android bluetooth logging app
I was looking around at some obd2 to bluetooth adapters.
http://www.easy-motorcycle.com/bluet...f8a41c86ed951d
That adapter supposedly works with all protocols including CAN. I was considering starting an open source logger for Android. Basically it would allow your android based cell phone (or other device) to read live ecu data for logging and digital gauges and such via bluetooth. I dont know that I would trust it for flashing the ecu but it could be a possibility, especially if we can figure out an infrastructure like COBB's where they flash a base map to rom and then other tables to ram. We could flash the basemaps to rom with a pc but possibly do live tuning via the android device.
Post here if you have any ideas or are interested. I would also like to see how many people might be interested in hopping on board for dev help, etc...
Ryan
D0nets is offline   Reply With Quote
Old 06-11-2009, 07:35 AM   #2
Tgui
Member#: 44771
I hope your SN doesn't imply ".Net"
There is a not so lively discussion on realtime tuning on RR that I tried to resurrect some time ago. I think we got to the bitching about how to implement it and arguing over the XML def extensions needed to support it. Your best bet would to pick it up over there.
http://www.romraider.com/forum/topic3881.html
Tgui is offline   Reply With Quote
Old 06-11-2009, 12:02 PM   #3
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Well the ramtune addition would come later. As of now I really just want logging of learned data (learningview), and logging of live data. I dont mind whipping out the laptop to flash , but I get annoyed with having to whip it out to log and such.
Old 06-11-2009, 01:41 PM   #4
Tgui
Member#: 44771
I have my own logger working to some extent written in Java. Its not all that hard.
Code:
package com.example.helloandroid;
import android.app.Activity;
import android.os.Bundle;
public class HelloAndroid extends Activity {
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
It looks and smells like Java. Their VM is proprietary and the bytecode generated is NOT compatible with Suns VM. Then you have Googles subset of typical Java classes supported.
Here is a little code to get you started. Of course the gnu.io package is NOT available for Android as I've read, they have their own RfcommSocket class to negotiate BlueTooth Comm access. Serial is serial though really. If you can tie in the analogous RfcommSocket methods to this code, you should get some meaningful data back. Hope this helps.
Code:
import gnu.io.CommPortIdentifier;
import gnu.io.NoSuchPortException;
import gnu.io.PortInUseException;
import gnu.io.SerialPort;
import gnu.io.SerialPortEvent;
import gnu.io.SerialPortEventListener;
import gnu.io.UnsupportedCommOperationException;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.nio.ByteBuffer;
import java.util.Enumeration;
import java.util.Iterator;
import java.util.LinkedList;
import java.util.TooManyListenersException;
 * Eric Morgan, AKA Tgui from SimpleTune.
 * Open Source, release changes to public as you make them!
 * Reference GPLv3 for full details.
 * This header must stay complete with this code.
public class SSMQueryExampleRPM {
    // Data from ECU
    private static OutputStream outputECUStream;
    // Data to ECU
    private static InputStream inputFromECUStream;
    // Defines named comm port
    private static CommPortIdentifier commPortIdentifier;
    // Serial port being accessed
    private static SerialPort serialPort;
    // Define state of defined comm port, open or closed.
    private static boolean open = false;
    // Set to whatever is your comm port as printed out by the comm port listing method
    private static String commPortChoice = "/dev/tty.usbserial-TX45b7tf";
    // Pause between byte reads
    private static int BYTE_READ_PAUSE = 0;
    private static int INITIAL_PAUSE = 10;
    // Define comm port connection attributes
    private static int BAUD = 4800;
    private static int DATABITS = SerialPort.DATABITS_8;
    private static int STOPBITS = SerialPort.STOPBITS_1;
    private static int PARITY = SerialPort.PARITY_NONE;
    private static int FLOWCONTROL = SerialPort.FLOWCONTROL_NONE;
    private static boolean RTS = false;
    public static void main(String[] args){
    	// What ports are available?
    	printOutCommPortList();
    	// Make our comm port selection based on the list printed out.
    	boolean success = bindCommPort(commPortChoice);
    	// If comm port binding failed, exit.
    	if(!success){
    		System.out.println("Issues during execution, exiting.");
    		System.exit(0);
    	// Open the serial port connection.
    	openConnection();
		// Build up command byte
		byte[] bytesToSend = new byte[13];
		bytesToSend[0] = (byte)0x80; // Every SSM command starts with this
		bytesToSend[1] = (byte)0x10; // Destination subaru ecu
		bytesToSend[2] = (byte)0xF0; // Source diagnostic tool
		bytesToSend[3] = (byte)0x08; // Size
		bytesToSend[4] = (byte)0xA8; // SSM command to send, read memory
		bytesToSend[5] = (byte)0x00; // Padding
		bytesToSend[6] = (byte)0x00; // Start First RPM tuple
		bytesToSend[7] = (byte)0x00;
		bytesToSend[8] = (byte)0x0E; // End First RPM tuple
		bytesToSend[9] = (byte)0x00; // Start Second tuple
		bytesToSend[10] = (byte)0x00;
		bytesToSend[11] = (byte)0x0F; // End Second RPM tuple
		// Build up checksum and print out (data <> running sum <> HEX rep)
		System.out.println("\n----------------------\nDATA BEING SENT TO ECU\n----------------------");
		long sumValue = 0;
		for(int i = 0; i < bytesToSend.length - 1; i++){
			sumValue += (int)bytesToSend[i]&0xFF;
			System.out.println("##### :"+(bytesToSend[i]&0xFF)+" <> "+sumValue + " <> " + Integer.toHexString((int)bytesToSend[i]&0xFF));
		bytesToSend[12] = (byte)(sumValue&0xFF);
		System.out.println("##### :CKSUM <>"+((int)bytesToSend[12]&0xFF) + " <> " + Integer.toHexString((int)bytesToSend[12]&0xFF));
    	// Sleep a little to ensure the port is really ready.
		try {
			Thread.sleep(INITIAL_PAUSE);
		} catch (InterruptedException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		// Finally send compiled ECU query
		try {
			sendECUCommand(bytesToSend);
			Thread.currentThread().sleep(60);
			//sendECUCommand(bytesToSend);
			//Thread.currentThread().sleep(60);
    public static void printOutCommPortList(){
    	Enumeration<CommPortIdentifier> en = CommPortIdentifier.getPortIdentifiers();
		if (!en.hasMoreElements()) {
			System.out.println("No Valid ports found, check Java installation");
			System.out.println("Exiting now.");
		//Iterate through the ports
		while (en.hasMoreElements()) {
			CommPortIdentifier chosenCommPort = en.nextElement();
			System.out.println("Serial found on system :"+chosenCommPort.getName());
    public static boolean bindCommPort(String commPortName){
    	try {
			commPortIdentifier = CommPortIdentifier.getPortIdentifier(commPortName);
		} catch (NoSuchPortException e) {
			System.out.println("No port available by passed name :"+commPortName);
			return false;
		return true;
    public static void sendECUCommand(byte[] charValue) {
        if (serialPort == null) {
            System.err.println("No Port Selected, therefore no interraction with ECU happening.");
            return;
        try {
            outputECUStream.write(charValue);
            System.out.println("Sending query to the ECU:" + charValue);
        } catch (IOException e) {
            System.err.println("Can't send char command to ECU: " + charValue);
            e.getMessage();
    public static void openConnection() {
        System.out.println("Opening connection now.");
        // Set the parameters of the connection.
   		try {
			serialPort = (SerialPort) commPortIdentifier.open("SSM_DEMO", 2000);
			serialPort.disableReceiveTimeout();
			serialPort.setRTS(RTS);
			serialPort.setFlowControlMode(FLOWCONTROL);
			serialPort.setSerialPortParams(BAUD, DATABITS, STOPBITS, PARITY);
		} catch (PortInUseException e) {
		} catch (UnsupportedCommOperationException e) {
        // Open the input and output streams for the connection. If they won't
        // open, close the port before throwing an exception.
        try {
            outputECUStream = serialPort.getOutputStream();
            inputFromECUStream = serialPort.getInputStream();
            System.err.println("Error opening IO streams");
            serialPort.close();
        // Add this object as an event listener for the serial port.
        try {
            serialPort.addEventListener(new ECUDataListener(inputFromECUStream));
        } catch (TooManyListenersException e) {
            System.err.println("Too Many listeners");
            serialPort.close();
        // Set notifyOnDataAvailable to true to allow event driven input.
        serialPort.notifyOnDataAvailable(true);
        // Set notifyOnBreakInterrup to allow event driven break handling.
        serialPort.notifyOnBreakInterrupt(true);
        // Set receive timeout to allow breaking out of polling loop during
        // input handling.
        try {
            serialPort.enableReceiveTimeout(30);
            System.err.println("Time Out");
        open = true;
        System.out.println("Port opened with success.");
    public static void closeConnection() {
        // If port is already closed just return.
        if (!open) {
            System.err.println("Attempting to close an already closed port.");
            return;
        System.out.println("Closing connection to the currently targeted port");
        // Check to make sure sPort has reference to avoid a NPE.
        if (serialPort != null) {
            try {
                // close the i/o streams.
                outputECUStream.close();
                inputFromECUStream.close();
                System.err.println(e);
            // Close the port.
            serialPort.close();
        open = false;
     * Private class to listen for responses from the ECU.
     * @author emorgan
    private static class ECUDataListener  implements SerialPortEventListener{
    	private LinkedList<Byte> commands = new LinkedList<Byte>();
    	private InputStream in = null;
    	// Pass in the input stream used to get data from the ECU
    	public ECUDataListener(InputStream in){
    		this.in = in;
    	 * Part of the SerialPortEventListener set of methods.
    	public void serialEvent(SerialPortEvent e) {
    		System.out.println("Got Data, Event type :"+e.getEventType());
    		System.out.println("Wanted data tpye :"+SerialPortEvent.DATA_AVAILABLE);
    		int newData = 1;
    		switch (e.getEventType()) {
    		case SerialPortEvent.DATA_AVAILABLE:
    			while (newData != -1) {
    				// Pause between pulls, yes dirty
    				try {
						Thread.currentThread().sleep(BYTE_READ_PAUSE);
					} catch (InterruptedException e1) {
						e1.printStackTrace();
    				// You can read a block of bytes if needed, this implementation
					// reads a byte one at a time from the inputstream
    				try {
    					newData = in.read();
    					if(newData != -1){
    						commands.add((byte)newData);
    				} catch (IOException ex) {
    					System.err.println(ex);
    					return;
    			System.out.println("\n----------------------\nDATA RECEIVED FROM ECU\n----------------------");
    			Iterator<Byte> iterator = commands.iterator();
    			System.out.println("Printing out this many bytes :"+commands.size());
    			while(iterator.hasNext()){
    				Byte next = iterator.next();
    				System.out.println("--->"+((int)next&0xFF)+" <> "+Integer.toHexString((int)next&0xFF));
    			// Extract the RPM data
    			byte firstByte = commands.get(commands.size() - 3);
    			byte secondByte = commands.get(commands.size() - 2);
    			System.out.println("First Byte :"+Integer.toHexString((int)firstByte&0xFF));
    			System.out.println("Second Byte :"+Integer.toHexString((int)secondByte&0xFF));
    			// Combine 2 result bytes into a short value
    			ByteBuffer bb = ByteBuffer.allocate(2);
    			byte[] bytes = new byte[2];
    			bytes[0] = firstByte;
    			bytes[1] = secondByte;
    			bb.put(bytes);
    			short rpmShort = bb.getShort(0);
    			System.out.println("Raw short value :"+ rpmShort);
    			System.out.println("\n\nRPM VALUE FOUND:"+rpmShort/4);
    			// Clean up now
    			SSMQueryExampleRPM.closeConnection();
Old 06-11-2009, 02:07 PM   #5
Tgui
Member#: 44771
Also, look here for other hardware.
http://devtoaster.com/products/rev/index.html
Old 06-11-2009, 04:39 PM   #6
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
This sounds like a good idea. I have the Tactrix 2.0 cable, but I'm still waiting on the log to SD card support. Once that becomes available, I probably wouldn't use this for logging, but it would still be cool to have the ability to display info on my phone.
573 is offline   Reply With Quote
Old 06-15-2009, 01:22 AM   #7
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Well... bad news. I spoke with San Mehat at google. (He worked on the volume daemon and the wirless manager for android). He has informed me that there is not a bluetooth API yet I will keep you guys posted.
Old 06-15-2009, 01:32 AM   #8
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
http://www.obdkey.com/obd_orders.asp
The wifi one could work but I dont think it is worth the $200+.
Old 06-21-2009, 11:28 AM   #9
bfidalgo
Member#: 138002
2009 Legacy
Ruby Red Pearl
this would be amazing! the power of android!!! i love open source. it is gonna revolutionize the world! id definitely pay for this!
bfidalgo is offline   Reply With Quote
Old 09-14-2009, 11:28 PM   #10
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
This is true... Android is picking up steam rather rapidly. I think once there are more android devices on more carriers, dev. momentum will also pickup. Anyone interested in helping with this logger project once the bluetooth API is avail?
Tgui: Thanks lots for that code. I am sure it will come in handy.
Old 09-15-2009, 02:55 AM   #11
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Update: (unofficial) Bluetooth API v. 0.2
http://groups.google.com/group/andro...1d4fc?lnk=raot
Old 10-22-2010, 08:52 AM   #12
HTM WRX
Member#: 44463
2007 Impreza STi
World Rally Blue
I found this thread from a google search and thought I'd bring it back for an update: There is a program in the market place called torque that will pretty much do this with a Bluetooth OBD2 tool.
Just thought I'd share. I didn't search to see if there was more info.
HTM WRX is offline   Reply With Quote
Old 10-22-2010, 09:23 AM   #13
Chevarian113
Member#: 148415
1991 MR2 turbo
05 Outback XT
I've been researching much of this information, and as someone posted above, Devtoaster.com is a good website to look into. It is a program called Rev. I work on iPhone, so not sure if it is available for Android or not, but worth looking into.
Also, from my research, Kiwi wifi seems to be the way to go on hardware. Apparently there is a bluetooth option as well. A quick search on google will bring up ways to purchase one.
Chevarian113 is offline   Reply With Quote
Old 12-31-2010, 02:14 PM   #14
cprincipe
Member#: 201222
2007 Impreza 2.5i
Grey
Hope you guys don't mind me bumping this thread. Anyone had any luck with the Kiwi Bluetooth device?
http://www.plxkiwi.com/kiwibluetooth/
I'm mainly thinking of getting it for an ODBII scanner, although that's probably not the cheapest solution out there.
cprincipe is offline   Reply With Quote
Old 07-05-2013, 10:30 PM   #15
dcormier
Member#: 336380
2013 WRX 5-door
In case anyone else find this thread in the future, Android has a Bluetooth API now. However, there's currently a hiccup in being able to connect to some serial Bluetooth devices (like the cheap OBDII Bluetooth devices). They seems to have been introduced when they changed Android's Bluetooth stack recently. I suspect it will be fixed in the next update (not sure if I should qualify that with minor or major, but I think it'll be very soon).
dcormier is offline   Reply With Quote
Old 07-06-2013, 11:19 AM   #16
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Can someone explain how this is different that what we do with Torque today? Would it allow logging/reading of custom PIDs with autodection similar to RomRaider? You can add PIDs in Torque but it's not user friendly.
mechatricity is offline   Reply With Quote
Old 07-06-2013, 12:25 PM   #17
SharpTuning
Member#: 333363
I'm not familiar with torque, but it appears to be OBD only. A custom app would be able to use SSM to log more parameters (like RR) faster (also like RR). However, iirc there is a hardware limitation with the ELM bluetooth chips that breaks SSM packets.
SharpTuning is offline   Reply With Quote
FS : Pioneer AVIC D3 nav w/ Bluetooth and iPod cable DrnknZag Interior/Dressup/Audio & Security 25 08-22-2010 07:51 PM
Feeler: 06' STi BBS's with Bridgestone Potenza RE960's k3nj11 NWIC Private Classifieds 2 06-06-2010 08:20 PM
OpenECU timing problem check out logs vwjettavr67 Open Source Reflashes 7 06-05-2010 08:27 PM
QIK app for iphone and android = :banana: -=C=- Off-Topic 8 02-24-2010 09:58 AM
