View Poll Results: Interested in running no head gasket for the Subaru 2.5L engine?
Yes 2 40.00%
No 3 60.00%
Voters: 5. You may not vote on this poll
Old 06-11-2009, 04:29 AM   #1
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Default No head gasket engine, anyone interested for the 2.5L engine?
Like the title says, no head gasket for the engine. It's possible and it's done already by Roger Clark Motor Sports, and their race car is very successful and reliable and running for 3 years already without trouble.
However there is a catch to this, the existing cylinder head o-ring of RCM is for 2.0L Ver 3 to 4 STi heads only. And it needs a close deck block to make it work.
Here are the parts needed
http://www.rogerclarkmotorsport.co.u...?productID=281
http://www.rogerclarkmotorsport.co.u...?productID=279
http://www.rogerclarkmotorsport.co.u...?productID=280
There are a few companies that offers to convert a semi close deck to full close deck, as an example
http://www.outfrontmotorsports.com/engine_blocks.htm
other sleeved engines look almost closed deck, it's very hard to decide based on the picture alone if this can be considered a close deck.
I can't remember where I got that pic and I don't know what sleeve was used.
Now will RCM make those products for 2.5L engine? Maybe if there is enough volume/demand for it, maybe they will consider making it.
Now why am I interested with this stuffs?
1. because I hate the idea of blown head gaskets
2. I'm whp greedy . the more power the engine is making, the more chance the head gasket will blow. Please don't tell me it's all about tuning, I read that so many times already and I believe that at extreme whp level, it's only a matter of time and the head gasket will blow
3. Same goes for the parts used and the engine builder. Even if you use " the "best billet crank", "best rods and pistons" and "best bearings" and you got the "best engine builder", head gasket is at risk of blowing up at certain power level.
I know that there are sleeves that dropped, but this thread is not about dropped sleeves. If you like to discuss/debate about sleeves dropping, please post it here or make your own thread about sleeves dropping
http://forums.nasioc.com/forums/show....php?t=1637890
I called AEBS the other week and was asking for their sleeves, the guy told me the biggest problem would be the head lifting and the head studs don't have enough clamping force. I'm hoping the RCM 14mm head stud can take care of that. btw bertune is putting that on his build and I'm really excited to see the results
http://forums.nasioc.com/forums/show...1611860&page=7
and I wish he can break that 800whp level with the help of the RCM 14mm head studs
I know there are other guys that are interested at this, I'm really interested at doing this if I can have a close deck 2.5L block and if RCM will make it for 2.5L engine.
berdugo is offline   Reply With Quote
Old 06-11-2009, 04:45 AM   #2
jamal
Member#: 71875
98 2.5GT
my wheels fit
well, it's a nice idea, but how many people are actually going to buy something like this? A dozen at most?
Then remember that RCM didn't come up with or produce any of this. Prodrive did, and that's why it only exists for the v3/4 2.0, as even the 08 wrc car still uses a variation of that motor. All they're really doing as far as I can tell is selling and using WRC parts. I'm not trying to detract from RCM in anyway because it's a really badass shop, but I really don't see them coming up with a setup like that on their own.
In my opinion it would be much easier to cut a groove into the top of the sleeve for a stainless steel o-ring. It's common on drag cars and I think dynoflash did it recently on a subaru.
jamal is offline   Reply With Quote
Old 06-11-2009, 05:11 AM   #3
berdugo
Member#: 163108
07 EuroDM STi 2.5L
If those stuffs RCM is selling are indeed made by prodrive, maybe with enough demand/volume they can convince Prodrive to do it for 2.5L engine? The potential can be huge as long as it works as designed.
We will never know if we don't ask, honestly I was surprised that this kind of products exists the first time I heard it. I was mind blowing info for me.
Old 06-11-2009, 04:50 PM   #4
gold rush
Member#: 90110
2004 wrx wagon
I doubt Prodrive is that interested in Subaru's right now.
gold rush is offline   Reply With Quote
Old 06-11-2009, 06:07 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Didn't Cobb used to do something like this... o-ring the heads. I thought there was apost on here a while a go about replacing the o-rings.
Cobb AccessPORT 2.0 for the 2.5L motors Robson TXIC Private Classifieds 3 02-24-2009 01:00 PM
WHO MAKES RECESSED TIP SPARKPLUGS FOR THE 2.5L Turbo engine?? WRXINTX Service & Maintenance 8 02-22-2006 10:39 AM
Crankshaft Pulley Restraint Tool for SOHC 2.5L Engine TexasForester Service & Maintenance 4 07-20-2005 09:27 AM
swapping out DOHC 2.5L engine for SOHC 2.5L engine 2.5GT Normally Aspirated Powertrain 2 11-14-2001 04:58 PM
More questions on the 2.5L engine kappa652 Legacy Forum 2 10-19-2000 08:51 AM
