Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 06-11-2009, 12:35 PM   #1
absaynes
Member#: 180535
2004 wrx
JBP
Default wheel bore question
i have been looking around online for some new wheels. i found some rota g forces online. they are 17x8 et48 with a 56.1 mm bore. i was unsure what the bore means so i started looking on here. now i couldnt find what that meant but i found that a 56.1mm bore would be a correct fitting one for my04 wrx. but i am still wanting to know what the wheel bore is. could some1 please explaing what it is.
absaynes is offline   Reply With Quote
Old 06-11-2009, 01:04 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
Bore refers to the size of the hole in the very center of the wheel.
The center of the Hub (On the car) has a raised lip...The wheel has to have a large enough hole in the center to clear this lip.
Ideally the center bore of the wheel should match the size of the hub (As it does in your case, with the Rotas) to aid in centering the wheel on the hub. Some wheels have a Larger bore..so you use a hubcentric ring to help center the wheel.
Crawdads is offline   Reply With Quote
Old 06-11-2009, 01:10 PM   #3
absaynes
Member#: 180535
2004 wrx
JBP
^thanks
the diagram helps also
Old 06-11-2009, 01:14 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
The WRX has a 56.1 hub bore, so they will fit perfectly.
Old 06-11-2009, 01:51 PM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
The centerbore of a wheel is the machined opening on the back of the wheel that centers the wheel properly on the hub of a vehicle. This hole is machined to exactly match the hub so the wheels are precisely positioned as the lug hardware is torqued down. Keeping the wheel precisely centered on the hub when it is mounted will minimize the chance of a vibration. Some wheels are vehicle model specific and will come from the factory with a bore machined to match that vehicle. Some wheels are designed to fit multiple vehicle models and will use a centering ring system to reduce the bore size to match the hubs of different vehicles. These rings keep the wheel precisely positioned as the lug hardware is torqued down.
Some wheels are non-hubcentric by design. These are known as lug-centric wheels. With these wheels it is critical to torque the lug hardware with the vehicle on jack stands, off the ground. This allows the nuts or bolts to center the wheel and torque down without the weight of the vehicle pushing them off center.
Wheel Bore of Prodrive GC-010E VRREX Tire & Wheel 8 04-03-2008 11:32 AM
17x8 MB weapons (A-tech erasers) wheel bore turbo_h4 Tire & Wheel 0 03-05-2007 01:43 PM
SSR Wheels Bore size antiks Tire & Wheel 4 02-25-2007 11:27 AM
Wheel bore and hubcentric ring help please! litlechina Tire & Wheel 3 03-08-2005 11:25 PM
