Old 06-11-2009, 03:21 PM   #1
comptoncam
Member#: 161398
04 STI
Default work meister 19x9 22 offset question
anyone ever fit 19x9 22 offset on their 04 sti? might get some meisters in that size and offset. would really appreciate if someone could tell me. i looked on the fitment threat, it was not there.
comptoncam is offline   Reply With Quote
Old 06-11-2009, 03:43 PM   #2
mosc
Member#: 177401
2015 STi White
9" wide and +22 is way way way past the fender. You'll need a lot more than fender rolling. Stock is 7.5" and +53 so you're 50mm further out than stock. Probably a good 20mm past the actual fender.
mosc is offline   Reply With Quote
Old 06-11-2009, 04:03 PM   #3
comptoncam
Member#: 161398
04 STI
cool thanks for your your response! i think i can deal with being 20mm past the fender if i stretch a little.. maybe 245? has anyone had experience running 19x9??
Old 06-11-2009, 04:04 PM   #4
comptoncam
Member#: 161398
04 STI
also, does anyone know if it will clear brembos?
Old 06-11-2009, 04:06 PM   #5
mosc
Member#: 177401
2015 STi White
It's not being 20mm past the fender that's the problem, it's having a fender that goes down smack in the middle of your tire that's a problem. It needs to be completely cut away at that point (widebody kit). Hell, at that offset, you're going to have to modify the front fender well quite a bit just to be able to turn the wheel decently.
Old 06-11-2009, 04:08 PM   #6
comptoncam
Member#: 161398
04 STI
u have a good point.. thanks for your input. i dont think im going to run it anymore unless ive seen it done.
Old 06-11-2009, 04:11 PM   #7
grippy monkey
Member#: 131067
your "stance"
sucks
You don't have to find the exact wheel you want to know whether the specs will work or not.
I ran 18x9.5 +22 on stock but highly modified fenders for a short time. I ran -3 camber all around. The fenders were rolled and pulled to the maximum that stock can go without folding the fender upwards and causing bodywork.
You can make it work, but you can go with a less aggressive offset (something in the 30's) and less fender work and it will turn out being just as flush. Since you are going with 19's I'm guessing your goal is more for looks. So if you must go +22 you can make it work, but you will have to do all sorts of little extras to get rid of all of the rubbing. I have 9" +30 offset wheels right now, and with all the fender work and camber I did for the 9.5" +22 wheels previously I could fit a much lower offset on the 9"... but my goal is to have driveability, be low, and still kind of flush...
grippy monkey is offline   Reply With Quote
Old 06-11-2009, 04:22 PM   #8
comptoncam
Member#: 161398
04 STI
seems like a big hassle... i think you guys officially talked me out of this. im down to get the fenders rolled, but not pulled.. thanks a lot for the advice and experience.
Old 06-11-2009, 04:28 PM   #9
mosc
Member#: 177401
2015 STi White
Are you trying to maximize tire width, rim width, or overall track? It's hard to tell you where the limit is without knowing which of those you want to push.
Old 06-11-2009, 04:29 PM   #10
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
The other option, if you're hooked on these wheels is to have the offset altered by a wheel repair company. I've done this before to fit VW wheels on my old civic. They were a +35, and I had 10mm removed from the hub to effectively create a +45 offset.
Just like spacers add offset, a good machinist, and/or wheel shop could remove some too.
Imho, a 19x9 + 35 would be awesome. If they still cleared the Brembos.
But like you said, it's a pretty big hassle and you will be out of pocket for the modifications.
It would look killer, that is, if it even worked.
steve is offline   Reply With Quote
Old 06-11-2009, 05:56 PM   #11
comptoncam
Member#: 161398
04 STI
im trying to make it look nice and handle decent. ide say 60% aggressive and 40% handling. i know im going the wrong route with 19"s but i want a little more looks than handling.
i currently have 18x8.5 47 offset ssr professors.. dont think they are aggressive enough. i might just go from 245 to 235 to stretch a little and maybe add some spacers.
Old 06-11-2009, 05:58 PM   #12
comptoncam
Member#: 161398
04 STI
im not too hooked because these are 2 piece and i really ideally wanted 18" 3 piece 9-9.5" wide.. u are right it would cost a lot to make this possibly work. thanks for your advice on the option of taking it to a wheel shop!
FS: Work Meister S1 Gloss Black 19x9 +48 [and] 19x8 +38 lippstuh Wheels/Tires 2 06-02-2009 06:48 PM
Work Meisters - 18x10 +9 offset with T1R's Scoo Bee Wheels/Tires 15 04-06-2009 11:42 PM
WORK Meister S1 3P 5x114: gold w/ low offset VincenzoL Wheels/Tires 8 12-26-2008 02:01 PM
My 17X7 work meisters might be recalled might consider the 18x7.5 with a 45 offset. scootr Brakes, Steering & Suspension 1 04-23-2001 11:58 PM
225/50/16 Yokohama A032R work with stock suspension? Offset questions too... JayP Brakes, Steering & Suspension 0 12-29-2000 11:00 PM
