Old 06-11-2009, 07:51 PM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default Omori Boost Gauge Installed, 09 WRX (pics)
Just in case anyone cares....nothing all that special.
(the red blotch on the gauge is the reflection of my night flash)
irish44j is offline   Reply With Quote
Old 06-12-2009, 01:39 AM   #2
impressions
Member#: 190815
1994 EJ22E, T225
Honda Blue
Looks neat and clean i have to say,
impressions is offline   Reply With Quote
Old 06-12-2009, 09:13 AM   #3
haku
Member#: 168840
2008 WRX Sedan
Satin White Pearl
Wow, yours is actually red! Mine doesn't match =[ It has a slight pink to it.
haku is offline   Reply With Quote
Old 06-12-2009, 07:09 PM   #4
irish44j
Member#: 191290
09 OPB SM WRXsedan
mine looks pinkish in the daytime, but at night it's a dead-on match to the gauges. I also got the "dimmer" on it, which is basically a resistor that dims the LEDs about 30% so they're not blinding at night.
Old 12-27-2009, 03:27 PM   #5
jamie007
Member#: 43738
Hey I just picked up the same gauge with the dimmer, where did you wire the "Green" wire too? Did you have to tap into the wires on the back of the dimmer switch itself? I tapped into the "illumination" fuse #16 but all that did was make it so it turns on and off with the headlights.
jamie007 is offline   Reply With Quote
Old 12-27-2009, 03:31 PM   #6
mowgli29
Member#: 203438
Looks good, nice and clean! I've always thought Omori had the best looking "factory match" gauges.
mowgli29 is offline   Reply With Quote
Old 01-05-2010, 10:04 PM   #7
rex.rated
Member#: 206428
2009 WRX Premium 4dr
Lightning Red
OP - where did you end up purchasing the boost gauge and how much? does it come with the pod for the steering column also? was it an easy install?
rex.rated is offline   Reply With Quote
Old 01-05-2010, 10:40 PM   #8
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I prefer the Maddad ones, but regardless, nice install OP!
XanRules is offline   Reply With Quote
Old 01-06-2010, 01:17 AM   #9
Subarist
Member#: 166
2008 STi
I thought Omori went out of business for screwing a lot of people/businesses.
Subarist is offline   Reply With Quote
Old 01-06-2010, 12:00 PM   #10
jamie007
Member#: 43738
I bought mine from J-Spec tuning, I think it was $120 including the pod. I really like the guage! I have it mounted on top of the guage cluster. I bought the optional dimmer which kicks down the brightness a bit, but is not adjustable. Even with the dimmer it's about as bright as the guage cluster at the highest or second highest setting. I put a 1k Ohm linear taper potentiometer between the dimmer and the white wire on the guage to dim it further. The only problem is if you dim it too much the needle disappears. I would post some pics but can't figure out how.. I guess you can't post any pics on here unless it's a url?
Old 01-28-2010, 01:02 PM   #11
rex.rated
Member#: 206428
Lightning Red
ohh, alright. nice install regardless. i am going to look into that for my 09 wrx. the only downfall is that you can't adjust the dimming option.
as for posting up pics - you have you have an account with flickr or photobucket, etc.. (any pic hosting site) in order to post them on a forum. you would upload/resize the pic from your computer to the site, then you can copy/paste the URL to the forum.
Old 02-02-2010, 11:18 PM   #12
irish44j
Member#: 191290
09 OPB SM WRXsedan
Mine has the same illumination all the time....it has a wired-in resistor from the vendor so it's not super-bright at night, but can still be seen in the daytime. I wired it per their instructions, I forget which wire went where...I'll look around later this week and see if I can find the instructions.
honestly, don't recall. I'll try to look thorugh my receipts. Install was easy except for routing the sensor wiring through the firewall under the TMIC....hard to get to it behind the dash!
no idea...didn't screw me.
I think that's where I got mine too....
Old 07-22-2012, 11:21 PM   #13
Mrfrugalson
Member#: 312477
For the guys who have the Omori boost gauge, do your gauges read accurately? I like how the Maddad gauges match up with the oem gauges exact, but ive read customers complaiants of how it reads the peak boost a little higher than what the actual peak boost is.
Mrfrugalson is offline   Reply With Quote
Maddad Boost gauge install 09 wrx midwestmonster Electrical & Lighting 1 12-05-2009 12:29 AM
Omori boost gauge install options - anything steering wheel housing based? STiMUL8 Electrical & Lighting 1 06-11-2005 10:28 PM
omori boost gauge install heavyDOODIE Electrical & Lighting 25 08-11-2004 12:28 AM
Omori Boost Gauge Install Pic BrysImpreza Forester Forum 13 09-11-2003 08:59 PM
Omori Boost Gauge Install volley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-22-2002 09:36 AM
