Old 06-11-2009, 08:36 PM   #1
eraser_rx
Member#: 199287
Default Different look: Steel wheel vs Stock WRX wheel
I have searched the forum....and most of the topic are about mags/rim offset...but not about Steel wheels
i'm the second owner of my car....and when i got the car from the dealer....they put winter steelies for me....the 195/65R15 steelies looks more "sticking out" (closer to the fender/smaller offset) then stock WRX 205/55R16....
i couldn't really find the offset value on the steelies...looks like 15x6 et50mm or less....and stock wrx is 16x6.5 et55mm
so definitely, the track width with the steelies are longer apart....might result in more stress in the bearings? what else could wear out quicker?....
how long does subaru's bearing usually last?
anyways...it's only for a winter...but would appreciate if someone can answer my concern
man, the stock WRX mags just look plain ugly...6.5 wide 55mm offset really makes the wheels look "pushed in" if you know what i mean....
eraser_rx is offline   Reply With Quote
Old 06-11-2009, 11:43 PM   #2
grippy monkey
Member#: 131067
your "stance"
sucks
steel wheels are typically very heavy so people don't really mess with them
You can get custom steels made from Diamond Racing in any size and offset you want. If you wanted to make some 16x8 steels in 5x100 with a decent offset that would be completely doable and not very pricey.
as far as running stock steels instead of OEM wheels... NO
grippy monkey is offline   Reply With Quote
Old 06-12-2009, 01:32 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i'm the second owner of my car....and when i got the car from the dealer....they put winter steelies for me....the 195/65R15 steelies looks more "sticking out" (closer to the fender/smaller offset) then stock WRX 205/55R16....will those steelies affect the suspension geometry???
d0000000000d....there are gazillions of subaru wheels that fit your car
all would be better than steelies
Old 06-12-2009, 01:52 AM   #4
stanjk3
Member#: 125224
2005 Legacy GT Wagon
Post
What he said^
You should be able to find some stock 17" Legacy wheels for not a whole lot. The 5 spoke wheels (05-06 LGT, 06-09 L 2.5i) are 20-21 lbs, not too bad for OEM.
IMO even the 16" 10-spoke wheels used on the 05 WRX, 03-04 LGT and 05 L 2.5i would look better.
stanjk3 is offline   Reply With Quote
Old 06-12-2009, 07:30 AM   #5
eraser_rx
Member#: 199287
3 replies and question still not answered...
the winter tires that came with the car are brand new....i'm not selling them either....
tires on the wrx rims will still last for 2 more summers...not doing anything until then...
what i'm saying is, the steelies look more "sticking out"...which look a lot better than the stock WRX "pushed in" look.....
Old 06-12-2009, 09:12 AM   #6
fliz
Member#: 30342
Where's the question?
They are probably low offset steel wheels meant for a VW or something. The offset will be stamped in the wheel.
As far as the effects of low offset wheels, the material makes no difference.
My steelies are +53, I believe.
fliz is offline   Reply With Quote
Old 06-12-2009, 12:06 PM   #7
eraser_rx
Member#: 199287
there is the question
ok...maybe i didn't provide the offset of the steelies....but i couldn't really find the offset value on the wheels...looks like 15x6 et50mm or less
Old 06-12-2009, 04:16 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....you can determine the offset by manually measuring it. As for the suspension geometry, take what appears to be a lower offset wheel that may be 1/2 inch narrower in width than stock and of course it's going to change. ....I think it's more of a "how much" question than "if it will".
Kean is offline   Reply With Quote
Old 06-12-2009, 04:35 PM   #9
fliz
Member#: 30342
Like Kean said. Anything that moves the centerline of the wheel relative to the hub is going to change the geometry.
If a narrower wheel is noticeably further out, I'd bet the offset is closer to 30 than 50. The sticky on offsets gives good info on the acceptable ranges.
Old 06-12-2009, 07:02 PM   #10
eraser_rx
Member#: 199287
thx....so definitely, the track width with the steelies are longer apart....might result in more stress in the bearings....
FS: stock wrx wheels & 16" steel rims bugeye829 NESIC Private Classifieds 9 03-24-2008 02:03 PM
Stock GC8 6-Spoke wheels and Stock wrx wheels 4 sale JessesTalon Private 'For Sale' Classifieds 5 11-23-2005 09:47 PM
What 1/4 mile time difference on 17" wheels vs stock 16" wheels and RE-92s? rex n effect Proven Power Bragging 11 02-12-2004 06:49 PM
WTB - 4 15" steels and stock WRX wheels w/ tires marcus12 New England Impreza Club Forum -- NESIC 3 11-25-2003 04:31 PM
Weight of stock WRX wheels, P7's, and how much difference does it make? WR-REX Brakes, Steering & Suspension 4 09-21-2001 12:05 PM
