Old 06-11-2009, 09:17 PM   #1
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Default Coincidence? HIDs & DRLs & parking brake
Hi All,
I think this is just coincidence, but wanted to ask in case I am missing something.
I installed Morettes with HIDs a few days ago. There was an intermittent problem with the wiring and they would only work half the time. When I fixed the wiring, I also disconnected the DRLs by just unplugging the connector behind the glovebox.
Now, a couple days later, my parking brake light will not go out. It's on whenever the ignition is on. Could these events be somehow related or is it total coincidence? BTW I don't use my parking brake very often.
Thanks for any insight.
wobbletop is online now   Reply With Quote
Old 06-11-2009, 09:27 PM   #2
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Check the connector under the center console for corrosion or failure.
jay25RS is offline   Reply With Quote
Old 06-11-2009, 10:43 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check your brake fluid level. The light will also go on when the fluid is low, which is usually the result of worn brake pads (most likely) or a leak (less likely).
Old 06-12-2009, 11:53 AM   #4
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Cool!
Parking brake switch is pristine (not much is on this 220K km car).
But the brake fluid was a little on the low side. (I'll need to keep an eye on that). Topped up the fluid and the light is now out!
Thanks!
STi HID & DRL brewster Electrical & Lighting 5 01-15-2011 11:39 AM
Must have on parking brake to turn HIDs on? wrx609 Electrical & Lighting 6 11-25-2009 10:20 PM
coincidence? HID question Red_Wrx Newbies & FAQs 11 12-19-2007 06:43 PM
Removed DRLs back in the day...installed HIDs...now DRLs are back? IMPREZive 02 WRX Electrical & Lighting 2 01-10-2005 03:06 PM
Day Time Lights & Parking brake Orville Cote Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-23-2004 05:29 PM
