Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 06-11-2009, 11:03 PM   #1
dubstar
Member#: 184049
02 wrx
Default oil temp acting up
ok, hopefully i can get a little direction here. was driving the other day and my oil temp gauge (apex'i) started going crazy and the needle was bouncing all over the place. turned the car off and restarted, started reading normal rest of the way home. then started doing it again tonight then went back to normal. does it sound like just a bad sensor? if so, where/how do i check it? the gauges were installed in the car when i bought it and not sure where to start looking. any advice would be appreciated. thanks
dubstar is offline   Reply With Quote
Old 06-12-2009, 12:42 AM   #2
FunkRider
Member#: 195055
Check the electrical connections for the gauge (power, ground and signal) then suspect the sensor.
FunkRider is offline   Reply With Quote
Old 06-12-2009, 01:30 AM   #3
impressions
Member#: 190815
1994 EJ22E, T225
Honda Blue
I ran into the same situtation on a autometer electrical gauge, it could be that the sensor signal is loose or that the sensor isn't grounded properly to the body of the car.
impressions is offline   Reply With Quote
Old 06-14-2009, 12:29 PM   #4
Subie Steve
Member#: 214006
1997 Legacy Outback
I had the same thing happen with an electrical gauge when the sensor connector wires got corroded. I put dielectric grease on them now to keep the corrosion off - seems to be working a lot better. But it could be a short anywhere in the line or in the gauge.
Subie Steve is offline   Reply With Quote
Old 07-19-2009, 10:06 PM   #5
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
I'm getting this too!!! lol. Lemmy know what you guy's find?
Rallly2000 is offline   Reply With Quote
Coolant temp up but oil temp is the same? ogboot Newbies & FAQs 5 04-15-2009 10:57 PM
Defi oil pressure gauge acting up... Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-24-2006 06:39 PM
Oil Temp gauge acting strange EdSaj1228 Electrical & Lighting 1 11-26-2003 07:56 PM
('93-'01) oil temp up w/ chip mofoporn Impreza Forum 0 10-10-2001 09:43 PM
Those w/ oil temp gauges: how long to warm up? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-11-2001 02:04 PM
