Old 04-25-2002, 12:19 PM   #1
SnortWagon
Member#: 14124
2002 WRX Wagon
Default Improve factory boost solenoid for $2.88
First off - credit to Kris and the folks at BoostMonkey because they discovered this: Replace the restrictive hose coupling that is in-line between the wastegate 'T' and the factory boost solenoid with a much less RESTRICTIVE 3/16" coupling available at any auto parts store - I bought two at NAPA for $2.88 each.
Here's what you'll notice due to improved airflow to the factory solenoid:
Faster boost build and very slightly higher boost levels as the solenoid now has a better physical connection to what's going on under the hood.
Boost will build a bit earlier and last a bit longer as well.
I believe all this occurs because the solenoid sees more air more quickly than stock, allowing the solenoid to work more quickly to prevent dumping boost through the wastegate (which opens at 8 pounds)
Prior to this mod, I NEVER saw second gear boost approaching 14 pounds (maybe 10-11 at best) - Now my car peaks momentarily at 14 pounds plus, and settles between 12 and 13 pounds in second gear - plus it holds boost a bit longer.
Subjectively, this feels comparable to running a stock WRX on 93 octane vs. 91. BTW, my WRX is stock except for the grounding mod. If you want pictures of what and where this piece is, look at the BoostMonkey website under 'install'.
Again, thanks to Kris for figuring out something we can all benefit from.
SnortWagon is offline   Reply With Quote
Old 04-25-2002, 01:11 PM   #2
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
You have got to be kidding? This really makes a difference? Hmm. my as well try it.
Now to ask all the stupid usualy questions that havnt been asked yet. hehehe.
Will this void my warranty?
Is it possible that the aftermarket piece will melt because of the heat of the engine and somehow cause my turbo to blow up?
What is the best way to install this?
How long does this take to install? Should I maybe have my mechanic do it for me?
having too much fun here.. thanks for the info.
Evaider is offline   Reply With Quote
Old 04-25-2002, 01:43 PM   #3
mlambert
Member#: 13831
interesting, being that boost is still controlled by the stock EBC..you shouldnt get any overboosting, right?
mlambert is offline   Reply With Quote
Old 04-25-2002, 02:04 PM   #4
SnortWagon
Member#: 14124
2002 WRX Wagon
Correct - no overboosting. The plastic piece I removed looked identical to the one I installed - only it was smaller. Think about how this works: the solenoid controls boost by managing boost(controlled electronically) pressure before the wastegate. The factory wastegate opens mechanically when it sees 8 pounds of pressure. By allowing the solenoid to 'see' and adjust to boost pressure more quickly (because the pressure passing to it is LESS restricted due to the larger coupling), the stock solenoid can prevent the wastegate from opening when it shouldn't. The stock 'restrictor' coupling causes the solenoid to behave more slowly, resulting in the wastegate momentarily/partially opening before the solenoid responds and gets the situation corrected.
The result of this modifcation means that precious boost (especially when the turbo first spools up) is saved at lower RPM, and that the solenoid does a better job of controlling boost at high RPM because it is more immediately tied to boost levels.
The part itself only takes about 10 minutes to switch (when the hoses are warm). Why not try it? You can always switch back if you don't feel a difference.
Old 04-25-2002, 02:07 PM   #5
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I asked this in the Boost Monkey thread, but didn't get a response. If you performed this mod with an EBC installed, would the EBC be better able to control boost and eliminate some of the weird problems I've read about?
Mike Robinson
2002 WRX Sport Wagon
bluescoobywagon is offline   Reply With Quote
Old 04-25-2002, 02:14 PM   #6
6Pack
Member#: 13901
2002 WRX Sedan
If you read some of the first threads some people say it initially boosted slightly above the max of 17 then it quickly learned and now only go to 17. So that's going to be the max with everything else stock. If you're talking about using an extra EBC like the AVC-R or something then you're basically doing the same thing as the boostmonkey. No need to have both.
6Pack is offline   Reply With Quote
Old 04-25-2002, 02:44 PM   #8
cvp71
Member#: 12697
cvp71 is offline   Reply With Quote
Old 04-25-2002, 02:54 PM   #9
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Default Two questions...
1. Any effect on boost in 3rd, 4th or 5th on a stock car?
2. Is it reasonable (safe) to do this if you don't have a boost guage?
Kevin
Red Rocket is offline   Reply With Quote
Old 04-25-2002, 02:59 PM   #10
VetteVert
Member#: 5961
2005 STi
CGM
Default Re: Two questions...
If I can find one this evening, I'm going to try it. I have a boost guage and I'll try and document the changes as best I can. I'll post when I get it put in. If it doesn't raise peak boost that much, I think you would be OK
VV
Kevin
VetteVert is offline   Reply With Quote
Old 04-25-2002, 03:17 PM   #11
Brad B.
Member#: 10292
2002 WRX Sedan
Can this be done on a stock setup? Or do you need a MBC?
Brad B. is offline   Reply With Quote
Old 04-25-2002, 03:39 PM   #12
VetteVert
Member#: 5961
2005 STi
CGM
That's what this thread is about....
I'll try and post my results as soon as I find a connector (or whatever it's called...not real sure what to ask for)
VV
Old 04-25-2002, 04:58 PM   #13
GM991
Member#: 14257
SILVER
SnortWagon
I just put one in and went for a ride. I have a stock wrx with just the ground strap mod scoop spliter and boost gauge.
I did not go up on the highway, but the short ride I did take
it seemed to spool up faster and my boost gauge did read 15psi at the top end of 2nd.
Normally in 2nd it goes up to 14-14.5psi.
Is that normal??? ANYONE
I guess what I'm saying is that it seemed more responsive on the low end and of cource 15 psi on the top end...
I'm going out later on the highway and I will let you guy's know if there is anymore differents
Snortwagon is this what you experenced???
Thanks
GM991
GM991 is offline   Reply With Quote
Old 04-25-2002, 05:06 PM   #14
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Yeah, where in the store do you find some connector like this?
bemani is offline   Reply With Quote
Old 04-25-2002, 05:12 PM   #15
VetteVert
Member#: 5961
2005 STi
CGM
I just did the swap. Not a huge difference. Boost does jump faster, and peaks to a higher point (the most significant difference). It peaks right at .1 bar higher. It only holds around .05 bar higher. Definitely a worthwhile mod, though, for the $1.79 it cost me. (Advance Auto, btw) Here are some pics of both pieces, and a clearer picture of the installation area. I took the picture after installation so the white piece would make it more clear (hopefully).
VV
Old 04-25-2002, 06:28 PM   #16
Brad B.
Member#: 10292
2002 WRX Sedan
Who's going to be the first to offer pink annodized ones with STi logos on them?
Old 04-25-2002, 06:39 PM   #17
cvp71
Member#: 12697
What about changing the T also? It looks like it may also be restricting flow.
Cody
Old 04-25-2002, 07:11 PM   #18
Brad B.
Member#: 10292
2002 WRX Sedan
cvp: See this thread: http://i-club.com/forums/showthread....hreadid=176548
Basically, "Removing just #2 [the T fitting] and replacing it with a much larger 3/16" fitting causes the max boost to drop 2-3psi. " Not sure what the T + this mod will do however...
Old 04-25-2002, 07:16 PM   #19
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Anyone try this with TurboXS stage 2?
djerickd is offline   Reply With Quote
Old 04-25-2002, 07:19 PM   #20
Mykl
Member#: 14311
2010 GTI
Okay, this is the first I've heard of this, and I'm about to read the other thread posted. If someone could be so polite as to post links to other threads on this subject or give me a keyword or two to search with it would be greatly appreciated.
Anyway, despite not having my boost guage installed I went and spend the $1.61 (I WIN!!!) at Autozone for a pair of connectors. Installed it in the parking lot in all of 2 minutes in a hot engine bay.
Butt dyno says "HOLY ****", but we all know how accurate the butt dyno is since it's controlled by the brain. Noticed a good improvement in 2nd gear, and spoolup in third seemed to be a bit quicker. 1st has always felt pretty quick so I can't really tell, and I haven't gotten on the highway to test 4th.
When I get my boost guage installed I'll swap the connector back out for the stock one, leave it in for a while, and pay attention to how it reacts. Then I'll install the larger one and see what I get.
One thing I did notice is that the 3/16th connector is closer to the actual size of the hose, while the stocker looks tiny in comparison.
Mykl is offline   Reply With Quote
Old 04-25-2002, 07:31 PM   #21
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
I keep looking at that picture and it looks like there's only one of those connectors, why do you guys buy a pair? Is there another one that isn't on the picture?
Old 04-25-2002, 07:37 PM   #22
GOT_WRX
Member#: 7241
Any EGT comparison before and after the mod?
GOT_WRX is offline   Reply With Quote
Old 04-25-2002, 07:49 PM   #23
WRXVII
Member#: 15854
VF34'd...
Got mine installed today and it seems like turbo spools up faster and reaches max boost quicker. Oh, it only comes in pairs for $1.69 if you are wondering why everyone's getting a pair
WRXVII is offline   Reply With Quote
Old 04-25-2002, 07:57 PM   #24
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Thumbs up my 2 cents
Read the thread, went to Autozone ($1.57, and I win!!), popped it in, and took off. Butt dyno does not lie, and I got that funny feelig in my belly (from surprise). No boost gage, and it is very good turbo weather here right now (cool and dry) so maybe it's that. But I have the Cobb Club Spec kit, and I know I felt a stronger response off the line, plus, nailing it in 2nd feels a bit better too. I hope this won't conflict with the tuning on my Unichip. If not, my hearty thanks to you, Snort!
later all,
Darryl
Ps I'd have bought just one, but they came two per pack.
Ps(2x) When I said it felt stronger off the line, I meant it felt like the boost came on earlier, and that slight lag seems nicely diminished.
Darryl is offline   Reply With Quote
Old 04-25-2002, 08:13 PM   #25
BamBooI
Member#: 10945
2006 Evolution IX
Will there be a higer egt as a result of this mod? Any part throttle problems or will this not occur because the wrx is still using the factory boost control solenoid.
BamBooI is offline   Reply With Quote
Scooby mods- improve factory boost solenoid mod M3toWRXin3seconds Car Part Reviews 18 03-02-2008 11:51 PM
improving factory boost avellbe Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-23-2004 05:38 PM
Improving Factory Boost Solenoid Hokie Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-19-2004 01:41 AM
Improve factory boost solenoid additional mod saleen90181 Newbies & FAQs 7 10-16-2002 03:08 PM
Improving the factory boost solenoid - part 2 SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-16-2002 12:56 AM
