Old 06-12-2009, 11:10 AM   #1
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Default What Fluids would you recoment to use in 07 sti swap
I did a search but mostly everything end up being opposite. one person said get this another said get that instead.
A brief history.
I did a full 07 sti swap in a 2 door subaru so will need ALL the fluids, filters, spark plugs, etc. Car will be abused alot (mostly for track use)
I know that 07 has different rear diff so not sure if it needs different type of fluid.
as far as trans/diff
I am down to few choices
Amsoil severe gear 75-90
Motul 300 (75-90)
subaru extra-s
What should be used for engine?
I was thinking purolator filter (yellow kind)
amsoil 10w-40
castrol gtx 10w-40
brake fluid/clutch cylinder
not sure...
coolant
subaru coolant/distilled water 50/50
i will apreciate any help i could get, i'm still new to this and trying to learn
slava from goshen is offline   Reply With Quote
Old 06-12-2009, 11:17 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You are overthinking the issues. Read http://forums.nasioc.com/forums/showthread.php?t=995498 and follow the links therein. Buy what you need, not what you think you need. If you used products hand made by Moses himself, it would net you zero over what you could pick up at Pep Boys. Seriously. My hands are still oily from changing the oil in my car and I used Quaker State Q synthetic oil. Why? It was the cheapest synthetic at Walmart...I paid like $17 for a 5 of it, though I did go baller (like an idiot) and bought the $6.50 PuroOne filter. Go cheap or go home say I. The only place you might want to go premium is your tranny fluid choice, that's it.
Old 06-12-2009, 11:24 AM   #3
slava from goshen
Member#: 152176
BRP/SRP
I just want to be on the safe side because i plan onto abusing the car alot and dont want to brake anything because of bad lubricants. I'm poor but dont want to take short cuts on this as its important. plus the car wont be a daily.
i know some people use 0w30 for engine and others use shell rottela 15w40......completly opposite.
Old 06-12-2009, 11:40 AM   #4
mikercp
Member#: 166465
1994 Civic Cx
Frost White
Try Rotella-T 5w-40 Synthetic. I hear good things about it from what I have read and people who have used it and done blackstone oil analysis. It stands up to wear pretty good.
I just bought me some at my local autozone, and I hear its cheaper at walmart , Im getting ready to put it in next oil change so ill let u know how it goes.
mikercp is offline   Reply With Quote
Old 06-12-2009, 02:15 PM   #5
slava from goshen
Member#: 152176
BRP/SRP
sweet. thanks. yes my dad gets15 40 rottella in cases. i hear that walmart in texas is the cheapest lol.
Old 06-12-2009, 08:20 PM   #6
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
I recommend:
Amsoil Severe Gear 75w90 for the trans/diffs
Amsoil SSO 0w30 or ASL 5w30 for the engine
I've been running that for 66k miles now, very pleased.
RonJitsu is offline   Reply With Quote
Old 06-12-2009, 08:52 PM   #7
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
If you're serious about the track use, then get some of the racing fluids from Renewable Lubricants. Their street stuff is demonstrably better than everyone else's, but their racing stuff is even further ahead of everyone else's racing stuff.
OTOH, if you mean you'll be attending lots of races as a spectator and will be street-type dragging 'a lot' (meaning sometimes), then listen to Unabomber's advice.
bulwnkl is offline   Reply With Quote
Old 06-13-2009, 02:07 AM   #8
slava from goshen
Member#: 152176
BRP/SRP
would that work with 07 sti rear diff? because they are different than other years.
Originally Posted by RonJitsu View Post
I recommend:
Old 06-13-2009, 02:09 AM   #9
slava from goshen
Member#: 152176
BRP/SRP
If you are talking about street racing...........I wont be doing any of that. I do plan on going to a track/s every weekend. that will be ranging from drag strips, auto-x and road courses.
Old 06-13-2009, 01:27 PM   #10
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
OK. What I was saying was that if you're serious about real racing (i.e. road racing, maybe drag racing, and not street racing), then look at the lubes I mentioned. Sounds like you may be, so I'll stick with my recommendation.
BTW, auto-x doesn't need anything special at all in terms of lubes for a stock/production-type vehicle.
Old 06-13-2009, 05:42 PM   #11
slava from goshen
Member#: 152176
BRP/SRP
thanks
now i just need to finish my engine
Old 06-13-2009, 05:47 PM   #12
nxttruck2002
Member#: 90879
tranny: subaru extra-s
rear lsd: subaru extra-s
oil: depends on where you're at. i use redline 10w30
nxttruck2002 is offline   Reply With Quote
Old 06-13-2009, 11:38 PM   #13
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Yes it will.
Amsoil Severe Gear 75w90 or 75w110 is good for that rear.
Old 06-14-2009, 12:53 AM   #14
MyScoobie28
Member#: 59185
2014 Impreza WRX
go with motul for all fluids. if you're building a track car and putting blood and sweat into it, you might as well treat it well with good oil and fluids.
motul ftw, wouldn't go with anything else.
--arthur
MyScoobie28 is offline   Reply With Quote
Old 06-14-2009, 12:17 PM   #15
slava from goshen
Member#: 152176
BRP/SRP
I have Amsoil distributor really close to my house. I'm thinking of going motul 300 (75-90) for trans just want to know if its safe for torsen rear diff as well or if the rear diff needs different fluid. I probably will change all the fluids frequintly.
Old 06-16-2009, 03:14 PM   #16
Button
Member#: 20620
2006 Outback 2.5 i
Willow Green Opal
I've had good luck w/ Amsoil Products too!
Button is offline   Reply With Quote
Is Lightweight ShockProof GL-5? Will it damage STI tranny? Fluids to use in 07 STI. Aleksey Transmission (AT/MT) & Driveline 43 08-30-2011 12:30 AM
What would you like to see in a new FMIC kit?? CSS Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 04-01-2008 09:00 AM
What electoral reforms would you like to see in the US? proletariandan Political Playground 35 03-23-2008 02:48 PM
what fluids would you recomend?? all-trubo [STi] Transmission (AT/MT) & Driveline 5 01-31-2004 09:20 PM
What famous band would you want to be in? AC Lerok Off-Topic 46 06-07-2003 12:54 AM
