Mid Atlantic Impreza Club
Old 06-12-2009, 12:12 PM   #1
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow Anyone let me borrow their spring compressor tool? Herndon, VA
My rce comp camber plate cracked, so I am replacing them with the STI group n ones.... Can I borrow someone's spring compressor tool for a day or two so that I can install the new top mounts?
Thanks much,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 06-12-2009, 01:50 PM   #2
Tut4u2
Member#: 40424
05 STi
You can borrow one from Advance for free and keep it for 90 days if I remember correctly.
Also, the group n top hats are more compliant than the RCE tops so things will get a little less harsh for you if that matters.
Tut4u2 is offline   Reply With Quote
Old 06-12-2009, 06:46 PM   #3
RabidSTi
Member#: 60576
11 335xi
The advance auto near me had a spring compressor that would probably only work on a 4x4, it needed to mounted inside the spring. Tried to use it. Then went and bought the cheap version at harbor freight. For I believe $12 I got the set of two compressors that mount on the outside and work well for strut based suspensions.
RabidSTi is offline   Reply With Quote
Old 06-12-2009, 07:02 PM   #4
Tut4u2
Member#: 40424
05 STi
They have two different types of spring compressors...just make sure you get the correct kind for our cars.
Also depending on the springs you're running you might not even need a compressor; just a couple of friends.
Old 06-13-2009, 03:20 AM   #5
NewShockerGuy
Member#: 40736
2005 WRX STI
Awesome thanks guys!
tut4u2: I am just pissed it's cracked... lol My ride is already stiff/harsh but I've used to it..
So when I am at advance auto I need to ask for the spring compressors that clamp on the outside right.
Thanks,
-Nigel
Old 06-13-2009, 05:44 AM   #6
Tut4u2
Member#: 40424
05 STi
Yes...the ones that clamps on the outside. It should look like this:
Just clamp one on either side of the spring and have at it.
If they don't have it, then they can check the stores in the surrounding area for you as well so keep that in mind.
I'm surprised the RCE plates cracked truth be told. I have used them before and beat the living hell out of them and they have responded well. Maybe try calling RCE and maybe they can work something out with you? Unless you already got the Group N ones.
Old 06-13-2009, 07:58 PM   #7
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Excellent, thats what I was picturing in my head.
Yea ditto on the crack... that's why I bought them but from what I have been told now they are really just meant for the Tarmac and no D/D setup...
Here are two pics.
Got the Group N top hats today, they look identical so it's safe to say it doesn't matter which strut they go on right?
Thanks,
-Nigel
Old 06-13-2009, 08:00 PM   #8
Un0RiGiNaL
Member#: 189748
advance auto charges 50$ per compressor, assuming you need 2 compressors, you need to LOAN them 100$. when you return it they give you the money back. so its not COMPLETELY free but you get the point
but on most springs you dont need a compressor you can use bear strength
Un0RiGiNaL is offline   Reply With Quote
Old 06-13-2009, 09:58 PM   #9
Dadowhip
Member#: 212195
2007 WRX STI
my step brother used shoe strings lol......
Dadowhip is offline   Reply With Quote
Old 06-14-2009, 05:06 AM   #10
Tut4u2
Member#: 40424
05 STi
Thanks,
-Nigel
That's correct. Doesn't matter which side they go on.
Sucks about the crack...I'm sure you can still see them for some $$$ though lol
Old 06-14-2009, 05:20 AM   #11
madcatz
Member#: 187530
Fuk UrSelf
madcatz is offline   Reply With Quote
Old 06-14-2009, 07:43 AM   #12
Tut4u2
Member#: 40424
05 STi
Also pay attention to the position of your camber adjustment bolt when you're taking the strut out of the car, unless you're getting an alignment after then it doesn't matter
Old 06-14-2009, 12:04 PM   #13
Turbo Sushi
Member#: 164342
2006 chevy colorado
what the..... how the..... but then again i didn't need a compressor on my lowering springs to get my strut cap back on
Turbo Sushi is offline   Reply With Quote
Old 06-14-2009, 12:32 PM   #14
Matt_H
Member#: 107000
2015 BMW X1
Why would you ever use 2 compressors (4 clamps) at the same time...
Matt_H is offline   Reply With Quote
Old 06-14-2009, 03:46 PM   #15
speedblind
Member#: 42202
I have two sets of spring compressors you can borrow. I'm in Herndon.
speedblind is offline   Reply With Quote
Old 06-14-2009, 04:07 PM   #16
mla163
Member#: 104922
2013 BRZ
Not true. $50 deposit for the 2 of them. You get $50 back when you return it.
mla163 is online now   Reply With Quote
Old 06-15-2009, 10:56 AM   #17
eduSti
Member#: 136503
08 STI
^^^^agree...its a little over $50 but you get every penny back, I have borrowed it from advanced in at least 5 ocasions so I know from personal exp
eduSti is offline   Reply With Quote
Old 06-15-2009, 09:59 PM   #18
NewShockerGuy
Member#: 40736
2005 WRX STI
Got the Group N's installed... I had the NON lowering version of the RCE camber plates and now with the Group N's it looks the front end of my car is higher?
It's still a 2finger gap in the front fender from tire... which I believe is what it was with my rce plates, but it just seems to me that it's higher up?
-Nigel
Old 06-15-2009, 10:24 PM   #19
madcatz
Member#: 187530
Fuk UrSelf
everything is already all setteled out right?
Old 06-16-2009, 12:11 AM   #20
NewShockerGuy
Member#: 40736
2005 WRX STI
Yea, I replaced the camber plates with group n mounts. But from what I read even though the car was up for a couple hours it still might need to settle again, plus the new rubber on the group N's need to settle in I guess too..lol
Well wait a couple days and see what happens.
-Nigel
Old 06-16-2009, 07:07 AM   #21
Tut4u2
Member#: 40424
05 STi
Springs need to settle again...Give it a day.
I have never heard of top hats needing to settle but shrug...learn something new everyday
Anyone wanna let me borrow their engine hoist? OGspartan SCIC Private Classifieds 1 05-07-2010 05:07 PM
Anyone available that could let me borrow their MAF? AcquaCow Mid Atlantic Impreza Club -- MAIC 11 02-12-2009 09:43 AM
will anyone let me borrow their MAF? natoli4 Southern California Impreza Club Forum -- SCIC 2 01-11-2005 11:47 PM
i am borrowing a spring compressor, anyone want to lower thier car while i have it STEALTH-WRX Southern California Impreza Club Forum -- SCIC 21 05-24-2003 01:19 AM
Will anyone let me borrow an RE-92 for a week? Judah Rocky Mountains Impreza Club Forum -- RMIC 3 07-11-2002 05:32 PM
