Old 04-25-2002, 12:46 PM   #1
ieatcivics
Member#: 18025
2000 impreza 2.5 rs
pearl ridge blue
Default correct way to launch car?
what is the correct way to launch when runnin a qtr mile?
i hold my clutch down and keep my rpms around 3500 and i jus pop the clutch when it's time to go.
is this right?
i ran a 16.08 in my stock 2.5.
ieatcivics is offline   Reply With Quote
Old 04-25-2002, 01:50 PM   #2
spiralsmurf
Member#: 16085
2005 STi
you should probably slip the clutch rather than just popping it out.
spiralsmurf is offline   Reply With Quote
Old 04-25-2002, 03:44 PM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
with a couple of solid stage booster rockets, that should do ya just fine.
seriously, slipping the clutch will do less wear and tear on the internals of the drivetrain, and will be better in the long run. Do a search as this has been covered numerous times.
AJ711 is offline   Reply With Quote
Old 04-25-2002, 09:18 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
I generally hold the engine at about 3.5 grand, let it slip till it starts moving and then drop it the rest of the way. the car won't bog down and its easier on the tranny.
Brad
STiTuner is offline   Reply With Quote
Old 04-25-2002, 09:58 PM   #5
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Brad
youll get much faster times if you do what he said. dropping the clutch you just bogg to much, which leads to crappy times.
SubyRacer is offline   Reply With Quote
Old 04-26-2002, 08:57 PM   #6
STiTuner
Member#: 5778
09 135i
Jet Black
and an unhappy tranny...
for shifting into higher gears I usually leave my foot on the gass and slip away at the clutch. usually not lifting the clutch too far. its very fast very responsive and very cool the car will pull right away on shifts.
Brad
What is the correct way to attach harnesses to a harness bar? DiscoWagon Newbies & FAQs 2 06-18-2006 08:15 PM
What's the correct way to say "I like to live in a nice neighborhood"?? -=C=- Off-Topic 36 06-20-2003 05:20 PM
Which is the correct way to reset the ECU?? z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-26-2002 07:15 PM
what is the correct way to do a dOnut? byam52 Brakes, Steering & Suspension 15 01-04-2001 12:00 AM
What is the correct way to make a fast corner when dricing a STD car.????? gerardchau Technical Forum Archive 3 09-19-2000 07:46 PM
