Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-12-2009, 03:00 PM   #1
cpturbo
Member#: 49175
2004 STI
Default switching to drive by cable from DBW
HEY Phil, Rooney here. My STI is no longer with us. I now have a wrx and I need to know how to setup a ISC start up map. Please help.
Thanks
cpturbo is offline   Reply With Quote
Old 06-17-2009, 03:56 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
If wired correctly, assign PWM Output 4 to ISCO and then set the max and min ISC duty values under "Settings 1/Idle Speed Control" to 16 and 85%. This will get you started and then I think I will have to give you some new maps for the "idle speed control" maps to handle the learning %.
Element Tuning is offline   Reply With Quote
Old 06-17-2009, 10:41 PM   #3
cpturbo
Member#: 49175
2004 STI
As always, thanks Phil. I have the ISCO selected on PWM4. The ISC valve sounds like popcorn when the key is in the 2 position and when it is trying to idle. The car sounds good otherwise.
Thanks and I look forward to the map.
Rooney
Old 06-22-2009, 10:39 AM   #4
Element Tuning
Member#: 54918
673 WHP Element
As we discussed on the phone the I/O for PWM 4 should be set to high frequency vs. low frequency with your custom wiring. Normally for the STi output 4 is used for the boost control solenoid so that output is set to low frequency but for the ISCO it should be set to high frequency.
Thanks,
Phil
WTB: Throttle body spacer for drive-by-cable WRX jigga Private 'Wanted' Classifieds 7 04-06-2012 05:22 PM
Ver 8 ECU - AVCS and Drive by cable drftsub Engine/Power/Exhaust 0 02-11-2010 11:14 AM
Switching to Drive by Cable throttle body 2006whitesti Built Motor Discussion 1 10-31-2009 10:52 AM
WTB: Cheap Drive by Cable WRX intake manifold STi Hunter Private 'Wanted' Classifieds 1 12-30-2007 12:40 PM
Easy Ecu for Drive by Cable Cars Token-Negro Commercial ECU Reflashes 0 10-29-2006 03:07 PM
