Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 06-12-2009, 09:40 PM   #1
tora
Member#: 5851
09 Forester XT
+ NA Miata
Default '09 FXT - Misfire Cyl.4
Anyone else get this? Second time now for me. First time I just wiggled number 3 (back left if facing the engine at the front of the car). Cleared code with my AP and shazzam smooth idle again. Then last night as I'm on my way out for a date (already late) I get it again. My underground has ****ty lighting, wiggled it again, no luck. F....went on date with three cylinders..not far, 2 minute drive both ways, took it ease. This morning get a flashlight and the wire was OUT. Plugged it back in, cleared code and shazzzam..back to normal. Anyone else getting this? I'm not sure how the wire is loosening out as it clips in. Well, got it down pat now, happens again and it is a quick fix.
tora is offline   Reply With Quote
Old 06-15-2009, 01:57 PM   #2
WRX11
Member#: 26638
I doubt you've changed your plugs being a 09. Worked in that area under the hood lately? Isn't it a ignition pack on the 09FXT? How can it just worked itself loose?
WRX11 is online now   Reply With Quote
Old 06-15-2009, 02:23 PM   #3
pleiad7
Member#: 71056
MY04 Forester XT
Wait, I'm confuzzled. Are you saying the 09 XT has spark plug wires? All XT's to date are coil-on-plug... or are you talking about something else?
pleiad7 is offline   Reply With Quote
Old 06-15-2009, 09:19 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
The wire going to the coil-pack was unplugged. Completely loose, dangling like my willy in boxers. The first time it must have just been slightly loose but still plugged in because I just jiggled the coil-pack and all was well. This time the wire was FULLY out so I clipped it back in. I have not worked on the engine. I did have a DP put in but it was ages before the issue. I suppose it is possible it could have been slightly loosened then and just got more so but it seems odd that it would take so long.
Anyhoo, all fixed and no issue since.
Old 06-16-2009, 03:33 AM   #5
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Originally Posted by tora View Post
. Completely loose, dangling like my willy in boxers. .
V6TurboTA is offline   Reply With Quote
Old 06-16-2009, 01:36 PM   #6
WRX11
Member#: 26638
DP install shouldn't come close to messing around with your coil packs. But I suppose anything is possible.
There might be lesbians / women in here, don't be so sexist.
Old 06-16-2009, 02:50 PM   #7
tora
Member#: 5851
09 Forester XT
+ NA Miata
My thoughts exactly which is why I am not attributing it to the install and wondering if anyone else has had theirs loosen off at all. Luckily it was #3 which is the most accessible.
Old 06-16-2009, 03:39 PM   #8
WRX11
Member#: 26638
I abused my FXT when I had it and nothing electrical ever came loose. Actually, nothing mechanical ever came loose either from all the work on it.
2.0 Misfire Cyl 4 03WRX-WRB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-01-2008 10:47 PM
Cyl 4 misfire simpreza2 Normally Aspirated Powertrain 3 03-18-2005 12:48 AM
CEL P0304 - cyl 4 misfire, want people's thoughts edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2004 04:44 PM
Cyl 4 misfire, no drivability concerns... munkis Normally Aspirated Powertrain 11 03-28-2004 10:48 PM
Cyl 4 misfire only with borla headers munkis Normally Aspirated Powertrain 9 02-17-2004 11:10 PM
