Old 06-13-2009, 05:47 AM   #1
zholden88
Member#: 212798
2007 WRX STI
Default Want to know what you think......
Ok so I just picked up my 2007 STI and I am about to pick up some wheels for it but I know the width of this tire might be to much.
This is what it will look like
The dimensions are 18x9.5 Rota Grid - Flat Black (5x114.3/e38/73)
Will I need coilovers and what size tire will I need to run? Thanks for any help.
zholden88 is offline   Reply With Quote
Old 06-13-2009, 05:55 PM   #2
zholden88
Member#: 212798
2007 WRX STI
Please help guys. I want to order these ASAP so I need some advice.
Old 06-13-2009, 06:02 PM   #3
EdHilario
Member#: 137398
2004 Impreza 2.5RS
EdHilario is offline   Reply With Quote
Old 06-13-2009, 06:02 PM   #4
RIPEVO9
Member#: 185858
2007 Sti "Wingless"
You can always ask the owner of that car. I was told I needed coilovers, negative camber front and rear, and rolled or cut fenders to run those rims. Not sure about tire but they look like 255, 265's?
RIPEVO9 is offline   Reply With Quote
Old 06-13-2009, 06:28 PM   #5
zholden88
Member#: 212798
2007 WRX STI
I guess the main question I have is will I NEED coilovers cus that will bankrupt me lol.
Old 06-13-2009, 06:53 PM   #6
flukewrx
Member#: 75081
2003 WRX
If you want to know, then you should probably call Wheel Dude. They can help you out and let you know what you will need to do to your car to fit those wheels.
http://www.wheeldude.com/wordpress/
http://www.wheeldude.com/wordpress/help/contact-us
flukewrx is offline   Reply With Quote
Old 06-14-2009, 03:40 PM   #7
mosc
Member#: 177401
2015 STi White
If you want 255 wide tires, Rota sells some 18x8.5" +48 rims that can handle those just fine. You won't need coilovers either.
mosc is offline   Reply With Quote
Old 06-14-2009, 07:31 PM   #8
zholden88
Member#: 212798
2007 WRX STI
I guess Im just confused on how tires work cus in the pic thats a 255 tire on a 9.5 rim but yet you say a 255 fits on an 8.5 rim. Its like you can put a small ass tire on a bigger rim or big ass tire on a smaller rim. I want to have that exact rim with a 245 tire. Im just confused. I never knew wheels could be this hard lol.
Old 06-14-2009, 08:17 PM   #9
RIPEVO9
Member#: 185858
2007 Sti "Wingless"
Its not hard. The wider the rim the bigger the tire you use. 245's on that 9.5 rim will be stretched quite a bit depending on tire brand. I have 245's on my 9'' rims and they are slightly stretched.
This is my old evo on 245/40/18 tires Rota 18x9.5 P45R's, same size rim and tire u want. See the sidewall stretch. 255 will be more flush with the edge of the rim. Best bet is to go 255 with 9.5 rim
Old 06-14-2009, 08:50 PM   #10
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Just do some more reading.
Old 06-15-2009, 01:33 AM   #11
04wrxlove
Member#: 202415
2004 wrx
looks sick do it
04wrxlove is offline   Reply With Quote
Old 06-15-2009, 04:58 AM   #12
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
18x9.5 +38 with a 255/35 tire... I'd say the least you'd need in terms of suspension are camber plates.
Body work would be a rear fender pull and maybe a front fender roll.
With the stock suspension it might rub on hard corners since it's quite soft.
I have 18x9 +29 with 265/35 tires. It fits with camber and body work but you'll need some stiff ass springs for it not to rub.
alcoolaid is offline   Reply With Quote
Old 06-15-2009, 12:01 PM   #13
mosc
Member#: 177401
2015 STi White
sigh...
255/35/18 fits 8.5" to 10.0" width
9.5" rim fits 245/35/18 to 285/30/18
These things have ranges. Ideal is a relative term. If you want a 245 or 255 wide tire, there's no reason to buy a low offset 9.5" rim. If you want to put a 275 or 285 wide tire, you are in for some serious serious modification to the car. Something's got to give here. Do you want a superfluously wide and far out rim for looks? If so, stick to 245. Do you want 255 tire width without serious work? If so, buy a reasonable width/offset rim. Do you want to fit massive tire widths? If so, your rim is fine but your car needs work.
Just want to know what you think brokenfingerdesigns North West Impreza Club Forum -- NWIC 37 07-13-2008 09:29 PM
WorldOne wants to know what YOU want in a group buy! WorldOne Vendor 'Group Buy' Classifieds 55 11-09-2006 08:01 PM
need to know what you think about my rims DaFastOne Member's Car Gallery 40 05-20-2006 11:43 AM
Check this out! I want to know what you think! ~what?~ Bay Area Impreza Club Forum -- BAIC 7 04-18-2001 12:11 AM
