Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-13-2009, 07:07 AM   #1
seanr2
Member#: 62697
2003 BAJA
Garnet Red
Angry Check Engine Light... Off Switch
Does anyone no how to turn off a check engine light. It came on last night and I want it off. Car is running fine and its just a reminder to me that I probably have to shell out $700 bucks for an Pennsylvania emission sticker. It went on twice before and each time its a catalitic converter... the last time was less then 2 years ago.
seanr2 is offline   Reply With Quote
Old 06-13-2009, 07:43 AM   #2
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
go to autozone get their scanner and clear it.
holland_patrick is offline   Reply With Quote
Old 06-13-2009, 12:01 PM   #3
Guzzler
Member#: 79616
I'm not sure if this still works, but the old "shade tree" way is to disconnect the battery for a few minutes.
This used to require the follow after reconnecting battery: Turn on ignition, but don't start engine. Pump the accelerator 3-5 times, slowly. Turn off ignition. Then start engine. Pumping the accelerator was required to get the ECU to "re-learn" the full range of the throttle body potentiometer. Again, I'm not sure this is required on Subaru's.
Or if all else fails, a piece of tape over the lamp will work
Guzzler is offline   Reply With Quote
Old 06-14-2009, 12:42 AM   #4
subeman90
Member#: 65681
13 XV Limited
gray
you can turn the light off (switch or clear codes even) all you want but when they plug into your Baja to do the test you will instantly fail. (either due to not being ready to do the test or having your light out) You can get a fix it exemption but they aren't cheap.
Also, I do have a PA inspection license
subeman90 is offline   Reply With Quote
Old 06-14-2009, 09:29 AM   #5
seanr2
Member#: 62697
2003 BAJA
Garnet Red
I took a different approach to getting that light out... I tightened my gas cap. My bad, for the first time in 6 years I had an easy fix.
Old 06-14-2009, 08:32 PM   #6
subeman90
Member#: 65681
13 XV Limited
gray
hahahahaha I hate when that happens
Old 06-15-2009, 12:52 AM   #7
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
On a friend's 200k mile Forrester running a tank of premium got the light to go out long enough to pass the test for antother year.
Bottom line, you can't just shut it off though, you need to make whatever condition is causing it go away.
EDIT - oops, should have read the whole thread, for once someone got the elevator instead of the shaft... cool
kev m is offline   Reply With Quote
Check-Engine light -- 1st gear drop off eclip5e New England Impreza Club Forum -- NESIC 8 09-22-2003 05:53 PM
How do I turn off check engine light STI808 STi Forum Archive 8 09-14-2003 12:59 AM
help check engine light wont go off halflip22 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-10-2003 04:33 PM
Check engine light coming on and off, seemingly randomly GusS Legacy Forum 8 12-07-2001 01:50 PM
Check engine lights off! Crashton Forester Forum 0 03-26-2001 05:55 PM
