Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-13-2009, 06:28 PM   #1
thedivascloset
Member#: 204453
2003 Baja
regatta red/two tone
Default Baja tail lights needs to be replaced..WHOLE THING
Hey y'all. Cause I'm an idiot, I actually busted out my rear tail gate tail light (the red part). Nice. How much do you all think this will cost me? I'm such an A$%#@!
thedivascloset is offline   Reply With Quote
Old 06-13-2009, 11:51 PM   #2
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
renik subaru in or sells parts for just over cost..
http://www.renickmotorsports.com/
holland_patrick is offline   Reply With Quote
Old 06-14-2009, 01:43 AM   #3
subeman90
Member#: 65681
13 XV Limited
gray
I've seen them on ebay once or twice...take a look maybe?
subeman90 is offline   Reply With Quote
Old 06-14-2009, 10:24 AM   #4
seanr2
Member#: 62697
2003 BAJA
Garnet Red
You're not an idiot. I had to replace a tail light and nearly broke the same part you did. Subaru put a double sided tape tabs on under the painted part of the light housing that is just a step under crazy glue. It took me nearly 2 hours to screw in a light bulb that day!
seanr2 is offline   Reply With Quote
Old 06-16-2009, 11:12 AM   #5
thedivascloset
Member#: 204453
2003 Baja
Thanks guys! Seanr2...that makes me feel better!
Old 06-16-2009, 02:11 PM   #6
Benhart21
Member#: 149617
I replaced one of mine after some tool backed into it and cracked the lens maybe a week after I got the car, and it cost me about $75 bucks @ wholesale cost since I worked at a dealership at the time. The trim around them comes painted from the factory, so you need to order the specific one for your color, FYI
Benhart21 is offline   Reply With Quote
OT: How do you know when your laptop battery needs to be replaced? annointed Tri-State Area Forum 11 04-03-2004 12:30 PM
Help. '97 GT w/auto trans. Clutch packs need to be replaced? Dave G Legacy Forum 4 05-19-2003 09:34 PM
ECU needs to be replaced SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-31-2001 09:38 PM
new tire needs to be replaced 2002 2.5 RS, 900 miles bahboy20 Brakes, Steering & Suspension 7 07-18-2001 03:10 PM
What stock internals need to be replaced to run 10 PSI safely and reliably? (EJ25) wrxman555 Normally Aspirated Powertrain 5 02-23-2001 01:23 AM
