Old 06-09-2009, 11:13 AM   #1
Juiced05WRX
Member#: 202813
2005 WRX Sedan
black/orange kandy mblzr
Default Tire Width Options
I've decided to go with the Advan RGII's 18X8.5.
What would be the ideal tire width for these if I stayed with a 40 series? 245? 255?
I don't want the tires to be stretched on and I don't want any rubbing either. I want the sidewall to be straight up and down.
Btw, the car is an 05 wrx sedan.
- or -
Should I just stick with a 235 on an 18X8 rim?
Thanks,
-Jake
Juiced05WRX is offline   Reply With Quote
Old 06-09-2009, 02:36 PM   #2
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
I would go with a 245/40. Depending on your offset and ride height you may have to mess with your fenders but nothing extreme.
blahhblahh is offline   Reply With Quote
Old 06-09-2009, 07:53 PM   #3
Craig-STi/GTI/944
Member#: 148817
2007 STi, 85 944
95 Range Rover, 92 F-150
Craig-STi/GTI/944 is offline   Reply With Quote
Old 06-09-2009, 08:17 PM   #4
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Originally Posted by Craig-STi/GTI/944 View Post
245-40-18
+2 Its the only width I would go with, if I was sticking with a 40 series tire.
cpunlamd is offline   Reply With Quote
Old 06-09-2009, 10:28 PM   #5
grippy monkey
Member#: 131067
your "stance"
sucks
I wouldn't go with 245/40... especially on a WRX
It's just too tall. You will have more rotation to work with which will change your gearing. I prefer a 235/40, 255/35, or 245/35 for 18" wheels. Those tires have less rubbing issues also than a tall tire like a 245/40.
grippy monkey is offline   Reply With Quote
Old 06-09-2009, 11:42 PM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
- or -
Thanks,
-Jake
225/40 is the correct size
245/40 is way too tall
Old 06-10-2009, 01:05 PM   #7
Juiced05WRX
Member#: 202813
2005 WRX Sedan
225 is going to be stretched a bit much. I'm trying to avoid that so my rims don't get curbed in case the wife wants to drive the car.
235 on an 18X8 is perfect. Will the 235 be too stretched with the 18X8.5 rim?
Do you guys think it would be more practical to just go with the 18X8 rim?
Old 06-11-2009, 04:02 PM   #8
mosc
Member#: 177401
2015 STi White
There's nothing wrong with 225/40/18 on an 18x8.5" rim. Probably .5" more than you need but certainly not a fitment problem. If you want more width, I'd go 35 sidewall (expensive). 235/35 or 245/35. Mattering on offset, those could be fitment problems for you though.
mosc is offline   Reply With Quote
Old 06-11-2009, 09:36 PM   #9
minizmaster
Member#: 179667
06 sti
black
I am wondering the same thing. I have an 06 sti with h-tech springs. Wheels are advan rgII's 18x8.5, et50. I was running 235/40/18's with the tire stretched
I felt that it affected the handling a little. As luck would have it, I destroyed one of my tires sunday, I picked up a 1/2'' u-bolt driving down the road. the tire could not be repaired. I just picked up a set of Falcon azenis rt615's in 245/40/18. I have not fit them, but wondering if I am going to rub.
minizmaster is offline   Reply With Quote
Old 06-11-2009, 10:23 PM   #10
mosc
Member#: 177401
2015 STi White
I've used those springs. There's no way 245/40/18 fits under there without rubbing a ton. Especially with somebody in the back seat.
Old 06-12-2009, 10:40 PM   #11
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
235 won't look too stretched depending on the brand of the tires. I have the RE01-R on my 18x8.5. I didn't want the stretch looked either. But as far as protecting them from curbage? I don't think any size tire will help if your wifey curbs it the right way...lol
Magnum626 is offline   Reply With Quote
Old 06-12-2009, 10:54 PM   #12
Subi_Boy06
Member#: 208979
2006 STI
Here's mine. I have an 06 STI though. I'm running an 18x8.5 with 48+ offset and 255/35 18 tires. I just lowered it and no rubbing.
Subi_Boy06 is offline   Reply With Quote
Old 06-13-2009, 01:22 AM   #13
mosc
Member#: 177401
2015 STi White
Subi_Boy06, I have a very similar setup except on 17"s. I rub in the rear slightly. Try hitting some bumps with two or three friends in the back, you'll want to roll up those rear fender lips slightly at some point.
Old 06-13-2009, 05:17 PM   #14
minizmaster
Member#: 179667
06 sti
black
here was my current set-up. these were toyo proxy 4's 235/40/18....the advans are 18/8.5 et 50. had a little bit of stretch going. I hope the 245's fit
[IMG][/IMG]
Tire Width Options Juiced05WRX Rocky Mountains Impreza Club Forum -- RMIC 15 06-10-2009 01:55 PM
Tire width vs. Wheel width? yamahito Tire & Wheel 8 01-28-2007 05:21 PM
Upsizing: Matching wheel width to tire width and adjusting offset sonicblue Tire & Wheel 14 08-16-2004 02:28 PM
wheel width and tire width BlueScooby New England Impreza Club Forum -- NESIC 1 07-29-2002 05:03 PM
Tire width and rim width numbers? Any resources? ciper Brakes, Steering & Suspension 5 07-23-2002 10:43 PM
