Old 06-13-2009, 11:43 PM   #1
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Default lets talk about fuel rails
I have seen people discussing fuel rails in other thread (it wasnt on this topic), there isnt a thread specificly about this so I made one.
some of the things that would be nice to cover.
When? and Why is this needed?
What is the benefit of them?
What brands/models are good/bad?
Also could talk about other fuel components
slava from goshen is offline   Reply With Quote
Old 06-14-2009, 03:27 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by Maxwell Power View Post
Paralleling fuel lines can be troublesome. If the fuel rails are not designed properly, a parallel system can create air pockets [....]
Agency Power's original side feed fuel rails had this problem. Let's continue this in another thread.
Do their current side feed rails have this problem?
Old 06-14-2009, 09:19 AM   #3
Greg B.(blue 06 WRX)
Member#: 211290
APS or Perrin???
Greg B.(blue 06 WRX) is offline   Reply With Quote
Old 06-14-2009, 09:31 AM   #4
avi1777
Member#: 147652
02 sti
white
the stock rails dont spread fuel evenly,a.market rails are for safe fuel delivery first.
perrin,turbo xs both make great rails.
avi1777 is offline   Reply With Quote
Old 06-14-2009, 12:27 PM   #5
slava from goshen
Member#: 152176
BRP/SRP
At what point are they beneficial and whats the gain from them?
what does everyone think about perrin top feed rails? or what top feed are reccomended (has to be affordable)
Old 06-14-2009, 12:56 PM   #6
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
I have the Perrin's and I love them. Install was easy and fit and finish was awesome.
2.5iSTI is offline   Reply With Quote
Old 06-14-2009, 01:16 PM   #7
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
I'd also like to know at what point the stock fuel rails become a problem. I'm running 565cc DW injectors just for reference.
GodSquadMandrake is offline   Reply With Quote
Old 06-14-2009, 01:36 PM   #8
avi1777
Member#: 147652
02 sti
white
for some reason the fuel delivery is not even on the stock rails,
if you are runing 300whp and up change rails,mind you the rubber hoses that comes with those kits usually cracks after some time(not a lot of time),you will need metal hoses for reliability.
Old 06-14-2009, 01:43 PM   #9
pisymbol
Member#: 174448
300whp? What!? I've only known folks to swap out their rails for over 500whp, never heard anyone needing rails for 300whp.
pisymbol is offline   Reply With Quote
Old 06-14-2009, 01:51 PM   #10
STiAlain
Member#: 134565
Chapter/Region: HIIC
2006 STi
lol i run 850cc with a 255 pump on the stock fuel rails...talk to your tuner first before you spend money on something you might not need.
STiAlain is offline   Reply With Quote
Old 06-14-2009, 01:53 PM   #11
slava from goshen
Member#: 152176
BRP/SRP
well perrin rail kit comes with ss lines.
lets say I put 680cc with perrin top feed, walbaro 255 (on 07 sti engine, vf43) would the rails be beneficial or over kill? what gains would be made?
I know that if I run them on top of intake mani i will get colder fuel wich means more hp.
Old 06-14-2009, 02:32 PM   #12
jason miller
Member#: 158313
2003 WRX
The benefit is more even fueling from cylinder to cylinder. With more even fueling, you no longer have to worry that one cylinder might not be getting as much fuel as the others. This means that the car can be tuned leaner for a little extra power.
Less heat into the fuel lines is a nice little perk too.
jason miller is offline   Reply With Quote
Old 06-15-2009, 12:27 PM   #13
Maxwell Power
Member#: 190729
not that I am aware of.
However, I can't be certain. I have a friend close to AP that said they redesigned them after having issues. For all I know, he could have been making it up.
I do know for certain that the first gen rails had issues with repeated misfires due to vapor pockets. For the first gen rails, I just convert them to series feed instead of parallel and they work great. It's really easy and you only need to get 2 1/4" NPT plugs to do the job. Even in the series config, they are still better than the factory rails.
Maxwell Power is offline   Reply With Quote
Old 06-15-2009, 01:16 PM   #14
STIBungy
Member#: 51684
I too have found this on one of my customer's car. It was an 02 WRX with the 1st gen rails. The car was getting misfires on 1,3 and 4 along with a bad tune. After retuning the car, the misfires were still happening so I switched out the rails back to stock and misfires went away.
Now, with my car, I have the 2nd gen AP topfeeds and am having some issues with occasional random misfires and the car going lean upon tip-in. I've tried various tip-in settings as well as played around with the injector settings. Several ID injector owners have gotten pm's from me asking what their settings are so I'm at the point of replacing the rails rather than mess around anymore with tuning changes.
STIBungy is offline   Reply With Quote
Old 06-15-2009, 01:27 PM   #15
06njsti
Member#: 150986
06 #001 LSB STi
to my knowledge sti's (sidefeed) rails will fuel up to around 450whp, around 400 they start to starve cyl #3 if i remember correctly.
personally I would NEVER run perrin parts on my car, I ordered the APS fuel rails and should have them installed hopefully this summer along with my new turbo setup.
06njsti is offline   Reply With Quote
Old 06-15-2009, 01:32 PM   #16
SharpShifter
Member#: 101484
2002 jdm sti {gt35r}
sti blue
aps ftw
SharpShifter is offline   Reply With Quote
Old 06-15-2009, 01:46 PM   #17
Maxwell Power
Member#: 190729
try plumbing them in series and see if the problem goes away first. It would be great data for all of us (and yourself).
Old 06-15-2009, 02:25 PM   #18
STIBungy
Member#: 51684
Will do! That's less work than swapping them out.
Old 06-15-2009, 07:07 PM   #19
RR02wrx
Member#: 99614
12 STi Limited
Why would you never install any perrin parts on your car? Please explain..
RR02wrx is offline   Reply With Quote
Old 06-15-2009, 07:34 PM   #20
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
http://www.aeromotiveinc.com/products.php?prod=144
http://www.aeromotiveinc.com/products.php?prod=282
These can be found on Ebay for 160ish. If your somewhat smart you can see how the fuel runs through the system. Fab your own lines and you have the best of both worlds. Cheap (compared to other options), lots-o-fuel, metal braided, and sexy with anodized fittings.
nosmo is offline   Reply With Quote
Old 06-18-2009, 08:39 AM   #21
RR02wrx
Member#: 99614
12 STi Limited
I'm waiting for some actual information in this thread... we have one guy saying to keep the rails in line while everything I read otherwise up to this point said that a parallel system would be safer for the engine. Have any of the OP questions been answered? And why wouldn't you use Perrin products 06njsti? I just bought v2 perrin sidefeeds for my build and would like any information about them you can provide for me. It's just that i've been refreshing this thread for 2-3 days now and people have seem to forgotten about it....
Old 06-18-2009, 11:40 AM   #22
Maxwell Power
Member#: 190729
it's all about the supply and the load. If the rails are large enough and you have sufficient supply, it doesn't matter if they are parallel or series. Series helps prevent any issues with vapor pockets if fuel temp and rail temp get high enough to vaporize the fuel at the base pressure of 43psi.
The boiling point of fuel varies from 100 - 400 degrees (based on the kind of fuel and additives in it) at atmospheric pressure. Pressurizing the fuel raises the boiling point. This is why carburetor engines are usually the only ones you hear about having issues with vapor lock as they run a very low fuel pressure (6-8 psi in the lines and atmospheric in the fuel bowls).
there are also other factors that will affect the performance of a fuel rail. Did the V1 AP rails cause misfires from vapor lock? I don't know. However, the problem was surely there. The other factor could easily be the pressure pulse in the fuel rail from an injector opening and shutting. If the fuel rail diameter isn't right, the pressure pulse in the rail could cause a low pressure at the same time the next injector opened. My guess is that this is the real cause the original rails had issues. Larger injectors cause a larger momentary drop in fuel pressure in the rail followed by a subsequent rise in pressure. Similar to "water hammer".
This is the same reason we have BOV/BPVs on our turbo engines. My guess would be that if the V1 rails were used with a larger fuel pressure regulator (like an aeromotive) they might not have had any issues at all. The larger control surface and diameter of the diaphragm in the controller would likely stabilize fuel pressure faster and more efficiently than the small factory regulator.
So, the reason you don't feel like you've had "any real answers" is because the real answer is: It depends.
Old 06-18-2009, 11:56 AM   #23
slava from goshen
Member#: 152176
BRP/SRP
i'm a newb to this so. can i just get perrin v2 fuel rail kit and then upgrade my injectors/pump and call it a day? (07 sti engine with vf43) or do i need to get a better fpr? if so what pressure should i set it to? what is the range of good fuel pressure? or does it solely depend on injector size?
i'm just afraid of getting a performance fpr and putting in the wrong settings
Old 06-18-2009, 12:02 PM   #24
Maxwell Power
Member#: 190729
I'm running factory fuel rails and regulator with 1000cc injectors and a GT35R on my 07STi. Is this a good idea? Probably not. Am I going to upgrade my rails? absolutely. I'm just waiting for us to finish our rails so I can run our own brand.
I think factory top feed fuel rails and a walbro fuel pump will do you just fine up to an FPGreen and 800cc injectors.
Old 06-18-2009, 02:19 PM   #25
slava from goshen
Member#: 152176
BRP/SRP
^ thanks for making me feel good about my set up
i'll send you a pm about something off topic
Lets talk STI fuel system Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-07-2003 01:45 PM
Lets Talk About Sway Bars SillyAssKilby Brakes, Steering & Suspension 4 04-16-2002 02:49 PM
Ok lets talk about TEC III or II WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-04-2002 12:10 PM
Lets talk about brakes JaMa Brakes, Steering & Suspension 44 01-15-2002 08:40 AM
