Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 06-15-2009, 03:46 PM   #1
The HACK
Member#: 208707
Default Lots of transmission noises on '09 WRX wagon?
Since this is my first Subaru, I'm not sure if most of the noises are common.
'09 Subaru WRX wagon (01/09 built)
2,100 miles, engine, transmission, and diff oil all changed at 1,500 miles
First of all, there's this sort of weird "grinding" type noise when I lift off of the throttle while in lower gears (1, 2 and 3) and may possibly be present in the higher gears, except when in higher gears the speed and tire noises may be drowning it out. Does not sound like gear grind, more like two pieces of metal sliding past each other as they spin. Noise was present AFTER I installed solid urethane shifter bushings on the carrier. Car came with the SPT short shift kit. Noise has been getting progressively more pronounced. When noise is present you can kinda feel a slight knock on the shift knob.
Then there's a "knock" type rattle upon acceleration, again mostly in lower gears, and mostly right after you engage the gear. Once car is in gear, getting back on throttle does not produce the same noise. Noise is fairly subtle, again, when noise is present I can feel a knock or vibration in the shift knob.
I've taken off the boot and inspected, and I suspect the connection between the selector rod and the stick may need to be re-tightened or at least torqued down to spec and blue-loctited. I did remove the rubber boot underneath and re-installed the plate once and the noise "lessened" for a couple of days. Maybe the bracket and boot needs to be torqued down as well. I had suspect it was the exhaust/header hanger that hung down from the transmission/carrier arm bracket but that's plenty tight.
So I'm asking you guys. Are these noises common after break-in on a relatively new Subaru? My prior cars are all insulated to the hilt and typically all I hear are a muted exhaust tone and MAYBE some tire noise. Could use some "peace of mind" if these are just the common noises you would expect to hear from an '09 Suabru WRX Wagon.
The HACK is offline   Reply With Quote
Old 06-15-2009, 04:25 PM   #2
STidub
Member#: 142031
2005 CGM STi
I think what you are describing is pretty much normal for these cars - especially after replacing bushings. When my STi had about 15K mi I replaced all the shifter bushings and noticed very similar noises I hadn't heard before. I have also replaced the trans mount, rear diff bushings, crossmember bushings, as well as diff lock bolts which have increased the noises up another level. I like it because I can feel and hear what the driveline is doing. If you are still concerned I would do like you said and double check everything to make sure all the nuts, etc are tightened properly and not hitting anything. If they are all good, just hit the gas and enjoy the ride. Subies have all kinds of strange noises which remind you that these cars are different and made to take the abuse.
STidub is offline   Reply With Quote
Old 06-16-2009, 08:37 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
changed to WHAT???
SPECIFICALLY????
...ho...and that was a bad idea, in any event----and almost certainly the cause of your issues
Uncle Scotty is online now   Reply With Quote
Old 06-16-2009, 08:39 PM   #4
greenc51
Member#: 154681
2008 WRX - VF52'd
Dark Gray Metallic
wow you changed all the break-in fluids?
and all these tranny noises you're hearing are normal
greenc51 is offline   Reply With Quote
Old 06-17-2009, 12:31 AM   #5
HyperSl4ck3r
Member#: 179982
2008 Impreza WRX STI
Obsidian Black Pearl
Originally Posted by Uncle Scotty View Post
changed to WHAT???
SPECIFICALLY????
Easy man, I had a factory defect in my transmission and had it rebuilt with new oil at 1,300 miles in my 08. Thing runs like a charm. NOT factory oil, sure it sucks, but it was free and until I have any issues I'm not touching it. It shifts smooth and easy without any grinding or other less than ideal sensations or sounds... Maybe this winter when it starts to suck and not want to shift in the cold I will swap it...
HyperSl4ck3r is offline   Reply With Quote
Old 06-17-2009, 08:22 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by HyperSl4ck3r View Post
Easy man, I had a factory defect in my transmission and had it rebuilt......
totally
100%
irrelevant
to the issues here
Old 06-17-2009, 10:00 AM   #7
HyperSl4ck3r
Member#: 179982
Allow me to bring it back on topic. When they did a rebuild and put different oil in, it did NOT cause any additional noise from my transmission....
Sorry to go off topic.
Old 06-17-2009, 12:13 PM   #8
Obsessive
Member#: 77302
damn well better
bail me out of this ****
Mine (09' hatch) does it too. It has since new.
The noises (I assume) are from gear rattle as you decellerate, they will ride on either side of the gear face in an alternating fashion.
The 'rattle' you hear on takeoff is likely to be the clutch springs. Mine did it as well (it was noticable in the garage when letting the clutch out to back up with the windows down).
And for the record, it's a hatchback
Obsessive is offline   Reply With Quote
Old 06-17-2009, 08:25 PM   #9
thenewcraze
Member#: 190754
2010 Evolution X
2009 WRX Sedan
The clicking noise happens on my 09 sedan as well. It's been driving me nuts lately - seems like it's getting louder but probably just my imagination.
I have the Kartboy STS/bushings done as well.
thenewcraze is offline   Reply With Quote
Old 06-17-2009, 08:54 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
Allow me to bring it back on topic. .
bloody wanker n000b
this is, AGAIN....100% ****ing irrelevant to what happened to the OP
the OP may have put the WRONG ****ing lube in the trans and maybe the blokes who did YOUS put the RIGHTY **** in it
THAT is ****ing RELEVANT
maybe you should just stay OUT of things that may not concern you and YOUR condition....and learn something in the process
which is the bloody reason I asked what I did in post #3
bloody wanker n00bs
Old 06-17-2009, 11:10 PM   #11
Obsessive
Member#: 77302
damn well better
Someone go poopy in your Cheerios?
bloody wanker n000b
bloody wanker n00bs
Old 06-18-2009, 08:59 AM   #12
HyperSl4ck3r
Member#: 179982
changed to WHAT???
SPECIFICALLY????
I am not even entirely sure what was put into mine, but yet you are making a huge assumption they put the right stuff in mine and wrong stuff in his. Not only that it is a HUGE leap to assume he put the wrong stuff in and that is the EXACT cause of his issue. What if it was the EXACT SAME OIL...
Relax man, we are all on this thread to try and help him out. Nobody wants to make enemy's here. I'm not trying to start a fight, would appreciate it if you would ease up and be a little more considerate of the OP by providing constructive comments instead of flaming me.
Old 06-18-2009, 05:46 PM   #13
The HACK
Member#: 208707
changed to WHAT???
SPECIFICALLY????
Noise was present prior to the change. Post change the noise actually lessened.
As to what fluid, I'm not about to get into THAT discussion again. Based on what I know, I'll just leave it at the fact that 90% of the fluid available on the market today, comes from 3-5 different "companies" that make them, and it will come from whatever "company" running the best deal at the time. They're just packaged differently and with different color added to differentiate. Formulation is IDENTICAL if they're the same weight. Anyone else telling you otherwise, probably doesn't work in an industry where they had to actually buy AND sell lubricant.
Old 06-18-2009, 05:51 PM   #14
The HACK
Member#: 208707
THIS is a hatchback (my other mode of transportation):
Compared to that, THIS is a freakin' wagon.
Sorry, couldn't resist. Compared to what I'm used to, the WRX "Wagon" is down-right cargo van like in terms of size and utility. That, plus the fact that it's got more usable room than most of the typical small sized SUV without the weight and the ride-height qualifies it as a wagon in my book.
Or "touring" in a parlance I'm more familiar with.
Progress Technology anti-roll bars installed on '09 WRX Wagon... The HACK Brakes, Steering & Suspension 6 09-03-2009 12:02 AM
Very worrying noise on '09 WRX (Not Spun Rod Related) Saj5DJ General Community 5 06-24-2009 01:25 PM
FS. Lots of suspension goodies off 2002 wrx wagon. (Oem and aftermarket) mywaganiswhite SCIC Private Classifieds 32 10-28-2008 04:19 AM
Pics of OZ SLs on a wrx wagon? Hokie-wrx wagon Tire & Wheel 4 05-18-2005 12:29 AM
Lots of brake dust on '02 wrx! NEWAGEWRX Brakes, Steering & Suspension 5 08-01-2001 12:06 PM
