Old 06-15-2009, 04:21 PM   #1
AWDalbert
Member#: 131295
2000 GC8 (v4)
BRP
Default 15mm spacer issue with oem wheels.
just posting this up as a FYI, for those people flushing out OEM wheels.
when using 15mm spacers on OEM wheels (in this case 08sti wheels), u might run into an issue with the stock studs sticking out too far past the spacer and seating on the back indents next to the axle stud holes
if you are planning to run spacers, to be safe id suggest 20mm anything below that you might have a issue
car. 05 sti
to make this work the stock studs would have to be trimmed down 1/4inch
here you can see where the stud hit the back space on wheel mating surface.
thanks for reading hope this helps someone in the future
AWDalbert is offline   Reply With Quote
Old 06-15-2009, 04:24 PM   #2
mosc
Member#: 177401
2015 STi White
*cries* at perfectly good hubs being destroyed for stupidity
mosc is offline   Reply With Quote
Old 06-15-2009, 04:54 PM   #3
blackrod punishment
Member#: 99757
2015 sti
white
i think its a good heads up, thanks AWDalbert
blackrod punishment is offline   Reply With Quote
Old 06-15-2009, 04:55 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Just take a hacksaw and saw your old studs to fit, you're already halfassing the rest of it, might as well go full retard!
rougeben83 is offline   Reply With Quote
Old 06-15-2009, 05:56 PM   #5
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
as long as you are getting 4 full revolution on the lug nut to the stud you should be ok.
there's nothing wrong with running spacers.
But i know many ppl on nasioc would beg to differ so i'll end here.
Kenji815 is offline   Reply With Quote
Old 06-15-2009, 07:18 PM   #6
grippy monkey
Member#: 131067
your "stance"
sucks
I dont like 15mm adapter type spacers. It is on the border of not enough metal to have new studs in. I haven't heard of issues with them though. I've ran 25mm bolt on spacers with no issues for a long time. I would suggest running a slip on spacer and extended studs on anything below 15mm.
grippy monkey is offline   Reply With Quote
Old 06-15-2009, 07:39 PM   #7
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
how is it any different than running a different offset rim? its the same damn thing just using stock rims... the turning scrub radius changes with after market wheels also, the load between after market wheels and spacers if the same offset when all done is EXACTLY the same. BIGGEST and I mean the only large issue with spacers is people forget they need to check the torque every so often. They can and will come loose.
Before you go off and just say im stupid, prove to me why spacers are bad, show me technical data. Otherwise bye.
sheesh those without suspension knowledge should really stay out of suspension threads.
Deserted1 is offline   Reply With Quote
Old 06-15-2009, 07:49 PM   #8
Tredizzle
Member#: 135260
SUPA FRESH SON!!!!
Goodbye Roki
Lmao I love it..... Cory your my effin hero
Tredizzle is offline   Reply With Quote
Old 06-15-2009, 08:17 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
you do realize the generally accepeted thread engagement minimum is twice what you're pulling out of you butt right?
Old 06-15-2009, 09:52 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah...that TOO
Old 06-16-2009, 12:38 PM   #11
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
+12457987654575409876
go corey!
thisisthenewsic is offline   Reply With Quote
Old 06-16-2009, 12:41 PM   #12
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
am I the only one who has seen lots of studs on spacers break because they are crappy quality?
real way to do spacers= ARP stud extenders and a spacer, not an adapter spacer. that is just stupid.
darksc00by is offline   Reply With Quote
Old 06-16-2009, 01:02 PM   #13
r8r4life
Member#: 101464
Looking at the reigon should tell you something.
r8r4life is offline   Reply With Quote
Old 06-16-2009, 01:07 PM   #14
darksc00by
Member#: 102140
2016 Herp Derping
oh yeah.
SCIC
Old 06-16-2009, 11:28 PM   #15
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
is that all you tools have is our area? guess what Spacers are SOLD everywhere... get over it.
Old 06-16-2009, 11:32 PM   #16
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
oh yeah.
SCIC
You know I just looked at your post history, you either just hate life so much that every word you type is negative or you just drink your hatoraide every day... So which is it, did someone poop in your apple jacks or what?
Old 06-17-2009, 07:33 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
but the west coast has more idiots per capita and therefore more idiots use spacers there and it is more likely that the idiots there will use the wrong ones in the wrong ways
logical to a fault, imo
Old 06-17-2009, 03:23 PM   #18
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
^^ great logic ..
Old 06-17-2009, 10:09 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
^^ great logic ..
you wouldnt understand....too close to the issue
clearance issues with wider wheels klorti Brakes, Steering & Suspension 13 11-29-2009 10:20 PM
15mm space issue with oem wheels. AWDalbert Tire & Wheel 0 06-15-2009 04:21 PM
Uknown issue with suspension/wheel Shockey Newbies & FAQs 3 11-28-2008 11:11 PM
"Tuner" stlye lugs with OEM wheels? eatadolfin Tire & Wheel 0 09-23-2003 04:55 PM
What to do with OEM wheels/tires makofoto Brakes, Steering & Suspension 3 09-29-2002 04:25 PM
