Old 06-16-2009, 01:20 PM   #1
ForestRanger
Member#: 205781
Default What's holding me back?
Just upgraded from a dying TD05 16g to a Blouch TD05(6) 18g 8CM. Torque builds really well to 360lbs at 3600 then dies off quite quickly. HP gets to 318 @ the flywheel and wont go higher. Car is a 05 2.5 Foz XT with STI TMIC, up-pipe, full Milltek TBE and Ecutek Tune.
Tuner says it won't take anymore boost, AFs are 11.5 steady, it won't take anymore timing. It's running 99RON.
I was told to expect slower spool but much more at the top. I've got great spool, 40 ft lbs more but only 17hp more at the crank. I was sort of hoping for 350/360 at the crank or more. Things happen nicely in the first third of throttle movement then stop. More gas or more revs do very little.
The trace is really faint and won't scan. If this should be in the 2.5 Turbo engine section please move it.
ForestRanger is offline   Reply With Quote
Old 06-16-2009, 01:22 PM   #2
Clark Turner
Member#: 178047
02 WRX STI Spec C
stock intake?
Clark Turner is offline   Reply With Quote
Old 06-16-2009, 03:41 PM   #3
GeneralTJI
Member#: 152680
Yea maxing out MAF sensor? injectors maxed? Did he tell you why it won't build more boost? ..because it sounds like he is keeping from building more boost because it may be maxing something else out... (That turbo will flow more air)
GeneralTJI is offline   Reply With Quote
Old 06-16-2009, 04:02 PM   #4
Bullwinkle1983
Member#: 172332
2006 WRX
Stock BCS? What's boost at?
Bullwinkle1983 is offline   Reply With Quote
Old 06-16-2009, 04:16 PM   #5
ForestRanger
Member#: 205781
Stock BCS, intake and injectors (560). Boost is 20 psi peak going down to 16/17. If it's holding 11.5 ish on the AF I'm guessing the injectors aren't flat out and if that were the answer we'd know. The problem seems to be getting any more air into the engine. For whatever reason.
Old 06-16-2009, 04:34 PM   #6
Clark Turner
Member#: 178047
02 WRX STI Spec C
You need a larger diam intake like the APS 70mm intake. This will privide more headroom for the MAF sensor allowing the tuner to map higher. The 560s are not enough and your AFR is to lean now.
Upgrade to a larger cold air intake.
Consider a silcone turbo inlet pipe.
Purchase 850cc injectors.
Retune the car.
Clark
Old 06-16-2009, 04:36 PM   #7
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
I would upgrade all 3 of those and get a new tune. I would get
grimspeed bcs
aps intake
dw 880cc injectors
and then your good if you ever wanna upgrade your snail
borla hush holding me back? woodys77 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 12-04-2008 09:43 PM
With a rotated gt30r, how much will stock headers hold me back? xrocket21 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 08-17-2008 04:50 PM
Gruppe-S header holding me back? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-26-2008 12:35 AM
holding me back? fastwrx006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-23-2005 11:56 PM
stock resonator holding me back? iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-16-2003 07:09 PM
