Old 06-17-2009, 09:39 AM   #1
WRXTIM
Member#: 213496
09 WRX
Dark Gray
Default Will these BBS LM's fit?
I just picked up a 2009 WRX Premium. I have a rare set of BBS LM wheels with a bolt pattern and dimensions that I believe is pretty rare. They fit perfectly on my 2003 VW, no spacers or adapters were necessary.
Sorry if this is a stupid question, but I know NOTHING when it comes to offsets. I was told that these wheels would fit perfectly on a 2005 STI, but was wondering if I could get them to fit on my car as well. Here are the dimensions:
Fronts- 17x8.5 ET 20
Rears- 17x9.5 ET 32
Yes...they are staggered. I did a search on staggered set-ups on Subarus, and I got lots of conflicting information. So if anyone has some info on that as well, I'd appreciate it.
One more thing I guess I should add- I do not plan on lowering or messing with the suspension at all. So if these wheels fit, they will be on the factory suspension.
WRXTIM is offline   Reply With Quote
Old 06-17-2009, 10:47 AM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
fronts are too aggressive
rears are pretty close to being overly aggressive
on stock suspension it will look like a donk.
bren wrx is offline   Reply With Quote
Old 06-17-2009, 10:50 AM   #3
Blown95ImpalaSS
Member#: 87629
05 6spd LGT
will they fit your hubs? yeah. will you probably have to run a teeny tiny tire and more than -2 degrees of camber with camber bolts and at least rolled rear fenders? yeah.
if you run enough camber it might not look awful but with the stock suspension it will probably look like a monster truck. sweet wheels though, good luck
edit: bren ninja'd me by three minutes.
Blown95ImpalaSS is offline   Reply With Quote
Old 06-17-2009, 10:55 AM   #4
derekman
Member#: 142213
Having different offsets are OK.
Having different wheel widths are the problem.
derekman is online now   Reply With Quote
Old 06-17-2009, 11:49 AM   #5
WRXTIM
Member#: 213496
09 WRX
Dark Gray
Yeah, I didn't think it would work. Oh well. Thanks everybody for the info.
I guess my next question is- Since I plan on staying with the stock suspension, what size wheel & tire combo could I get and with what offsets, that would fill in my fender gap a bit and also sit flush (or at least a little closer) to my fenders?
Old 06-18-2009, 07:30 AM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Smart. Find something that fits. And with stock suspension, you'll always have fender gap.
Old 06-18-2009, 10:18 AM   #7
WRXTIM
Member#: 213496
09 WRX
Dark Gray
That sucks. Especially since there is so much more wheel gap on the front, than there is on the rear. It kind of gives the WRX a reverse rake look in a way.
This car is going to be my daily driver and 85% of the time, I'll have a new-born riding in the backseat (wifey is expecting in December)...So, can anyone recommend a suspension set-up (shock & spring combo..no coilovers), that will eliminate some of the wheel gap, but still ride like stock? Would the STI suspension set-up lower it a bit, but still ride nice?
Old 06-18-2009, 02:23 PM   #8
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
Unless the bolt pattern is dual drilled.. they won't fit.
WRX = 5x100
'05+ STI = 5x114
Old 06-18-2009, 04:16 PM   #9
WRXTIM
Member#: 213496
09 WRX
Dark Gray
WRX = 5x100
'05+ STI = 5x114
Yeah, just noticed I wrote that. Sorry...I actually meant WRX not STI.
Will these STi injectors fit my Leagcy T fiveltretr Legacy Forum 1 02-05-2004 09:08 PM
Will these 3 wheels fit Subaru 4-pot? Nok's WRX Tire & Wheel 4 11-25-2003 10:28 PM
Will These TE-37's Fit? Integra-R STi Forum Archive 2 08-09-2003 02:56 PM
Will these Cusco coilovers fit american WRX? waezsn Brakes, Steering & Suspension 1 12-14-2002 03:00 PM
will these side splats fit over the WRX side skirt? luxcar101 Interior & Exterior Modification 3 05-30-2002 10:53 PM
Message Board Statistics All times are GMT -4. The time now is 03:30 AM.
