Old 06-17-2009, 07:56 PM   #1
rvanbran
Member#: 6687
Default Swapping DOHC heads for SOHC ?
I'm thinking about swapping the DOHC heads for SOHC heads on the EJ25 ('98ish, non turbo) that I have in my Beetle.
Can this be done using the stock ECU ?
Obviously I'd need a new timing belt, but would everything else work fine ? Would I need different Cam Position Sensor ?
The reason I want to do this is that they take up less space, and might allow me to close the engine lid
Thanks,
Rob.
rvanbran is offline   Reply With Quote
Old 08-27-2009, 11:05 AM   #2
sububu97
Member#: 215924
are u selling those dohc heads?
sububu97 is offline   Reply With Quote
Old 08-29-2009, 11:04 AM   #3
rvanbran
Member#: 6687
I haven't swapped them out yet, they are still on the car.
If the swap works I'd be interested in selling them, but the shipping cost would kill you
Rob.
Old 08-29-2009, 02:11 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It would take extensive rewiring of sensors. The ECUs for the DOHC and SOHC engines are completely different - the plugs aren't compatible.
Old 08-29-2009, 06:58 PM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
funny thing is the blocks will bolt up with no issues but head changing can be a nightmare really..sucks either way its better cooling for your bug anyways with it being rear mounted and all...plus you can show off the heart of the car...be like dune buggys expose the engine...
VIsubi is offline   Reply With Quote
Old 09-08-2009, 08:53 PM   #6
m0nkeyballz
Member#: 198411
2001 Subaru RSTI
APEX SILVER
No there not, sensors plug right in. I swapped a ej22 sohc into my g/f's 98 forester that originally had an ej25 dohc. There is only one cam sensor on dohc and sohc!
-David
m0nkeyballz is offline   Reply With Quote
Old 09-08-2009, 11:01 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
You're not comparing apples and oranges. I can guarantee you that you cannot put SOHC heads and intake manifold from an EJ25 into a EJ25 DOHC car and expect it to be plug-and-play. It doesn't work.
That is the question the OP asked, and that is the question I answered.
EJ20 SOHC and DOHC HEADS FOR SALE!!!!!! herbine2001 Engine/Power/Exhaust 6 04-26-2010 11:15 PM
98 dohc heads on sohc block EastsideLegacy Legacy Forum 31 02-27-2006 11:42 PM
Dohc Heads Into Sohc ? s1lentx Subaru Conversions 29 12-06-2005 01:51 PM
DOHC heads with SOHC block limeylight Normally Aspirated Powertrain 8 08-10-2005 03:43 PM
EJ25 DOHC heads on SOHC EJ22 FuJi K Normally Aspirated Powertrain 5 04-22-2004 09:27 PM
