Old 06-17-2009, 08:50 PM   #1
CThompson58
Member#: 140146
2004 STi
Default 1995 Impreza 2.2 cylinder 2 misfire
I just acquired this car in a trade and took it to Shucks today for Check engine light..
Comes up: Cylinder 2 Misfire and knock sensor failure
Where do I start? I want to put as little money into this car as possible and sell it. But I would like to do what I can to take care of the problem. The only work I know of that was done to car is the previous owner said he replaced spark plugs so I'm going to check wires and make sure plug is installed correctly..
Thanks in advance for any help/advice.
CThompson58 is offline   Reply With Quote
Old 06-17-2009, 09:00 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Is it continuing to misfire, or did it just happen once and the CEL is still on? My '95 EJ22 had a cylinder two misfire every two years or so. Just cleared the CEL and everything was gravy.
Old 06-17-2009, 09:53 PM   #3
CThompson58
Member#: 140146
2004 STi
how do you reset the CEL?
Old 06-18-2009, 03:23 PM   #4
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
...go to autozone and ask to borrow an OBD2 code reader. the shop one will usually be the really good one that will tell you what the code is. just plug it in, read it, then clear it... and deffinitely replace the knock sensor... its cheap and easy
ruckus racing is offline   Reply With Quote
Old 06-18-2009, 10:05 PM   #5
loccomoffo
Member#: 200891
1995 Impreza EJ18
Shabby White
I have a '95 ej18, it has ODBI which uses the black/green connectors under the steering wheel for code reading/reset. OBDII didn't come in till '96.
Look up Subaru OBDI reset, from memory you connect all plugs, black to black, green to green, go for a drive for a few minutes obove 10kmh. Unplug the black/green connectors and all's done.
loccomoffo is offline   Reply With Quote
Old 06-19-2009, 02:45 AM   #6
CThompson58
Member#: 140146
2004 STi
It's a obdII and I'm getting the new knock sensor and getting a o2 from scrap yard cause they're guaranteed to work and I'm just selling car.. I'm also going to check all plugs and wires then reset code as see where I stand thanks for the input guys..
2.2phse 1 to 2.2 phase 2 swap kdub420 Normally Aspirated Powertrain 0 03-12-2008 07:48 AM
2.2 and 2.5 parts from Frankenmotor Not All There Engine/Power/Exhaust 0 02-04-2008 06:55 PM
96 subaru impreza with cylinder one misfire melissa General Community 1 01-20-2005 12:44 PM
Help...96 Outback 2.5 Cylinder 4 Misfire cedata Normally Aspirated Powertrain 4 05-11-2004 02:08 PM
97 2.5 GT Misfire cylinder 2 nightmare?!! jsnspence Legacy Forum 8 02-15-2002 10:32 AM
