Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 06-18-2009, 08:50 PM   #1
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Default Fuel tank differences
Disclaimer: Please no newbs and newb comments.
I am trying to find out the difference between a MY00 RS and a MY07 2.5i fuel tank or is the tank the same and it uses a different pickup and surge tank on the pump?
I was driving a 07 2.5i at a resent autocross and it's able to run the fuel level to almost "E" without fuel starving. My RS, I have to run around 3/4 tank to prevent that from happening.
Anyone have a parts break down of the 07 2.5i fuel tank or can show what parts are different.
I am in Solo Street Prepared class and can update/backdate. So if I can upgrade to the same setup as the 07. I can save a bunch of weight.
Thanks in advanced.
Patrick L is offline   Reply With Quote
Old 06-18-2009, 08:56 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Hey Patrick, you can find exploded views with parts lists and #'s from a factory parts catalog... check this one out and see if it helps.
http://opposedforces.com/parts/
BTW, good to know that i can run my car near empty for autox :-)
Old 06-19-2009, 01:50 AM   #3
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
great thx!
fuel tank difference? Illshou Legacy Forum 3 09-29-2008 08:37 PM
2006 Impreza gas tank fill - fuel tank filler neck problems. Psybin Warranty Issues & SOA Problems 11 01-08-2007 09:48 PM
Are WRX fuel tanks interchangable with STi tanks? Amazake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2006 02:57 AM
Oil and fuel starvation in tight turns? Are there baffled oil pans and fuel tanks? Digital_Boy Normally Aspirated Powertrain 6 01-17-2001 08:01 PM
Removing fuel tank & Fuel cell foam dbrown Technical Forum Archive 3 08-13-2000 08:16 AM
