Old 06-18-2009, 12:25 AM   #1
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
Satin Gray Metallic (CGM)
Default Cobb Stage 2 0-90 MPH log - how's it look?
Hey guys,
I'd much appreciate your insight. I went Stage 2 with a SPT intake, Cobb catted DP, and STI cat-back about 400 leisurely miles ago. I did some 0-90 MPH runs tonight in an effort to see how my ECU is learning. This is the last run (rolling start) which also happens to be the one with the highest boost attained:
http://spreadsheets.google.com/pub?k...gQ&output=html
As you can see, I'm not hitting the Stage 2 boost target of 16.5psi by a considerable margin. I'm peaking at 14.8psi in 4th gear at 90 MPH before I hit the breaks and slow down.
I'm not sure if this is simply a matter of letting the ECU keep learning (multiple earlier runs peaked at only 13.8psi) or if there is something wrong with my setup.
Your expertise is much appreciated.
-DW
Drivinwest is offline   Reply With Quote
Old 06-18-2009, 11:30 AM   #2
freetors
Member#: 195982
white
your turbo dynamics is always positive and your WGDC are basically flatlined.You are basically not running enough WGDC to hit target boost. You would probably need about 85% WGDC to hit your target boost
freetors is offline   Reply With Quote
Old 06-18-2009, 11:35 AM   #3
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
Thanks for the reply. I just took the full acceleration section of the spreadsheet at which the TD were always positive - this is normal under WOT, right?
I'm not sure why my WGDC isn't higher. I suppose I'll check the vacuum lines. Anything else?
Thanks again.
Old 06-18-2009, 05:09 PM   #4
freetors
Member#: 195982
white
well you would normally like TD to be a small positive number, your's are well somewhat large. I don't know exactly what the WGDC map for your MY looks like nut it should be similar to the 2002 map and if thats the case, your WGDC's are actuall lower than the target
09 wrx cobb stage 2 0-60 times? devasta Newbies & FAQs 7 05-06-2010 04:57 PM
Cobb Stage 2.5 (VF34) or Stage 2.0+Meth Injection? hampster AccessPort 2 02-14-2007 05:26 PM
finally, im at cobb stage 2.0 with the wrx hotshot172 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-20-2006 11:35 AM
Cobb Stage 2.5 people... How's the newest map... v1.30? snvin Engine Management & Tuning 18 07-13-2005 09:58 AM
Vishnu stage 0 package or Cobb Stage 2 with TXS Stealthback and uppipe. OvRclockR Proven Power Bragging 0 10-02-2003 11:46 PM
