Old 06-19-2009, 12:26 AM   #26
gto7419
Member#: 44256
2002 WRX Wagon
Originally Posted by cribbie View Post
Are there any other methods? if not does this mean it was not balanced?
I am really surprised nobody has made a comment on the picture with the turbo in it
twinscroll 40r?
gto7419 is offline   Reply With Quote
Old 06-19-2009, 12:30 AM   #27
DSM_Outback
Member#: 56345
93 Swapped L
Green
Subarus are neutral balance. No external weight phasing/timing is required.
It means, if you run a piston set whose weight is different than the fuqued up Ross ones you have now, you'll still have a balanced assembly.
DSM_Outback is offline   Reply With Quote
Old 06-19-2009, 12:47 AM   #28
All_talk
Member#: 57843
2007 Spec B
Hardly noticed it, maybe I’ve been jaded by too much engine porn… ya seen one big turbo, ya seen em all.
Gary
All_talk is offline   Reply With Quote
Old 06-19-2009, 12:51 AM   #29
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
AFAIK you have Ross' EJ22T 2.4 "stroker" pistons for use with the 79mm EJ25x crank - as indicated by the 1.161' (29.489mm) compresion height. Ross' replacement EJ22T pistons have a compression height of 1.275' (32.385mm).
Also FYI, Ross' replacement EJ25x pistons have a compression height of 1.192" (30.276mm).
You really have only two options now:
1. send them back (but free replacement depends on who ordered them and what they ordered); or
2. As per maxwell's comment, use a suitable 79mm stroke crank and build a 2.4L stroker.
Leslie
wrxsti.l is offline   Reply With Quote
Old 06-19-2009, 09:10 AM   #30
3MI Racing
Member#: 200987
Leslie
You will note that 32.385mm - 29.489mm = 2.896mm Now that is actually a 79mm stroke (2mm) and 0.896mm left over that would be from a longer use rod or a rediculously crappy quench height.
3MI Racing is offline   Reply With Quote
Old 06-19-2009, 10:19 AM   #31
madmax718
Member#: 172501
no good comments here.. but those old pistons look completely horrid.
madmax718 is offline   Reply With Quote
Old 06-20-2009, 05:02 AM   #32
jamal
Member#: 71875
98 2.5GT
my wheels fit
If it helps I can kick Ian in the ass for you tomorrow.
jamal is offline   Reply With Quote
How do I remove the dash kit on my 1994 landcruiser, to take out my stereo? Nightwing Off-Topic 6 05-17-2010 09:15 PM
Dropped the cash for coatings on my new pistons. Convince me it wasnt a waste of $$ Davenow Built Motor Discussion 11 03-14-2008 03:36 PM
What are the limits of the roof racks on my Rav4? Cjchaps Off-Topic 12 01-27-2007 10:57 AM
Are the spherical bearings on my Perrin end links supposed to be this stiff? dsc Brakes, Steering & Suspension 1 02-21-2003 12:41 AM
My dash guts are out, the headunit is hooked up, but it won't fit in 2k2 Car Audio, Video & Security 3 07-10-2002 10:12 PM
Message Board Statistics All times are GMT -4. The time now is 05:38 AM.
