Old 06-18-2009, 03:09 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default School me on ringland failure...preventive measures?
So i see they seem to fail alot in the ej257s. what can one do to prevent this. If you use aftermarket rings on the forged sti pistons...does this get rid of the issue?
JDMFLCL is offline   Reply With Quote
Old 06-18-2009, 03:14 AM   #2
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
If your going to crack open the block you might as well just add pistons. From my experience, running high boost leads to ringland failure. You will see alot of guys run gt30's and there motors last a long time on 18psi VS someone like me who had a fp green running around 21psi. My motor lasted until 55xxx miles then the 3rd cylinder went. But to be honest if you just plan on running stage two or a small turbo then your car should last a very long time ASSUMING you do all the regular maintenance.
godfather2112 is online now   Reply With Quote
Old 06-18-2009, 03:27 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The STi pistons (at least USDM, I dunno about others) are not forged. An while I may be off base with this, it's not he rings that have issues on these motors. The failures in ringland are actual cracks in the piston themselves. The rings are fine for the most part.
Old 06-18-2009, 10:26 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Correct, the STi pistons are hyperutectic, not forged, and the part that dies is the ring LAND, not the ring itself. To avoid any ring land problems, make SURE your car isn't detonating...that's about the best you can do.
Old 06-18-2009, 10:58 AM   #5
JDMFLCL
Member#: 180513
Baby Baby C'mon!
ah k good to know, just wanted more info
Old 06-18-2009, 11:11 AM   #6
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
It is also worth mentioning that ring land failures are most common on moderate to heavily modified STI's, or STI blocks that are still using the stock pistons. There are a large number of STI's out there running with OEM pistons that are lightly tuned that have had no issues.
Fundimentally, it comes down to the quality of the tune that you are running, and how hard you want to push your car.
IMO, if you are looking to make more than about 350 whp on an STI block, it is not a bad idea to put in forged pistons.
J. Cooley
Flatirons Tuning Project Car
Flatirons Tuning F.A.Q. Blog
Flatirons Rally Team Blog
FlatironsTuning.com is offline   Reply With Quote
Old 06-18-2009, 11:14 AM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
so 350 whp would be a good basepoint for the hypereuretic pistons then
i'm on a jdm 2.0 with the same forged rods/forged crank/hyper pistons.
hence my inquiry
Old 06-18-2009, 12:36 PM   #8
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
ringland failure-high boost, detonation, knock, bad gas...ect...
stretchedk7 is offline   Reply With Quote
Old 06-18-2009, 01:18 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
^^ bad gas ^^
I filled up at a local reputable station (Chevron). For whatever the reason, the pump moved very very slowly, but I thought nothing of it and I don't know if it had anything to do with it, but 14 miles later I start getting misfire codes and rough rough idle. It all went down hill from there as I discovered a couple of days later that I had lost #4. Was bad gas the cause of blown cylinder #4? I don't know, but the two events sure happened very close to each other... All and all it was a pretty lame way to lose a motor... no good story or anything like my floor boards falling out in a street race or something.
I will be running e85 now to avoid detonation. The more I learn, the more I invest in my car to try to avoid detonation. The AZ heat does not help.
Old 06-18-2009, 01:19 PM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yes e85..very nice.
Old 06-18-2009, 02:01 PM   #11
z&cobb
Member#: 12344
2002 2JC
blue
^^ bad gas ^^
Yesterday's newspaper had a report showing a couple of gas stations in Baltimore had bad gas and a bunch of cars were ruined. They said it had to do with water. I wonder how much water you have to have in ethanol containing gasoline to have that kind of effect?
z&cobb is offline   Reply With Quote
Old 06-18-2009, 06:17 PM   #12
sarcasmo
Member#: 50301
2004 BMW
330i
^^ bad gas ^^
I can relate. I filled up with 92 (best we have over here) and started immediately getting detonation (none whatsoever with my tune up until that point). I was really pissed. That was the last time I ever went to that station.
sarcasmo is offline   Reply With Quote
Old 06-18-2009, 09:33 PM   #13
Got Boost?
Member#: 113096
06 sti
I broke ring lands in my motor at about 12k with only tbe and an ots tune from Cobb. If you are going in to the block, replace the pistons and have the needed machine work done to match. U will be sorry if you dont...
Got Boost? is offline   Reply With Quote
School me on PlayOn, Netflix, Hulu, etc. on PS3 -=C=- Off-Topic 14 03-02-2010 05:38 PM
school me on taxes on money made from real estate.. lotusdrift Off-Topic 32 04-20-2007 04:59 PM
Somebody school me on external wastgates! Dick Fitzwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-18-2003 04:11 AM
School me on RS cat pipes Albert Normally Aspirated Powertrain 6 12-30-2002 04:14 AM
Nano: School me on the S-AFC WRXnFX Alaskan Impreza Club Forum -- AKIC 34 05-24-2002 02:53 PM
