Old 06-18-2009, 10:37 AM   #1
rs dude
Member#: 200538
2005 impreza 2.5rs
white
Default wheeltek spline lugs?
I bought black g forces with a red lip on wheeldude.com and I am not sure but I think that the wheeltek spline lugs that I ordered serve as wheel locks as well. Is this true or should I buy some wheel locks?
rs dude is offline   Reply With Quote
Old 06-18-2009, 10:50 AM   #2
Crawdads
Member#: 30907
SWP GDB-G
wheel locks are a waste of time.
A spline drive lug is essentially the same thing, just with fewer variations.
In my experience, wheel locks only ever keep the actual owner from removing the wheels. (When they lose or break the key)
Crawdads is offline   Reply With Quote
Old 06-18-2009, 11:01 AM   #3
rs dude
Member#: 200538
2005 impreza 2.5rs
white
what is the main difference between spline lugs and wheel locks?
Old 06-18-2009, 11:50 AM   #4
Crawdads
Member#: 30907
SWP GDB-G
Spline drive lugs take an adapter socket...all lugs of the same brand use the same adapter/key.
Wheel locks come in many variations, so that locks of the same brand take a different 'key' to take the 'lock' off.
Typically a 'lock' is nothing more than an oddly shaped nut.
Old 07-22-2009, 10:51 AM   #5
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
I was wondering the same thing. So basically as long as the person does not know what brand lugs you have they can't get them off in there spline drive.
Dstretch33 is offline   Reply With Quote
Old 07-22-2009, 11:06 AM   #6
Crawdads
Member#: 30907
SWP GDB-G
Depending on the nut, you can almost always get a spline drive nut loose by using a regular hex socket....or by using a slightly undersized hex socket that fits tightly enough over the splines for you to loosen it.
Using an undersize socket is the same technique a thief would use to take off most 'wheel locks'....its very common, and very easy to do. This is why wheel locks are mostly a waste of time. In the real world, they are usually more of a hassle for the actual owner than they are for a thief.
Wheeltek Spline Lugs joec wrx Wheels/Tires 5 03-30-2010 08:05 PM
FS: WheelTek Spline Lugs STIckySTIfee Wheels/Tires 3 01-31-2009 11:12 PM
moteki or wheeltek black spline lugs Stiman1 Wheels/Tires 1 03-05-2008 09:54 PM
DOH!..Sell me a Lug Key 4 Gorilla spline Lugs DriftRS Tri-State Area Forum 2 12-27-2004 02:01 PM
Trade: Blue Gorilla spline lugs for black spline lugs mav1c Mid Atlantic Impreza Club -- MAIC 0 09-17-2003 03:43 PM
