Old 06-23-2009, 12:53 AM   #1
Dave D.
Member#: 130990
06 Red Wagon hta68
MPS tuned JDM 6-speed
Default 06 WRX VF39 258hp/292tq
Finally got everything running right, 3rd time on Kito's dyno. Original pull was a stock baseline, second pull was with a torn inlet hose, finally got it right this time.
Mods:
VF39
STi topmount
Helix catted dp
Step colder iridium plugs
STi catback with flex adaptor into dp
Gimmick inlet hose
The original tune was by Dom, which Kito basically kept intact but smoothed out a touch using a dyno vs Dom's original road tune. The runs were very consistent this time, vs. lower numbers and almost immediate heat soak when the inlet had been ripped.
Stock Sti's run about 230/230 on this particular Mustang, so I was very satisfied with the tuning this car has received.
Old 06-23-2009, 01:02 AM   #2
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
damn thats almost as bad as cobbs heartbreaker. with vf 48 sti tmic and exaust my 06 made 247whp/288wtq at 4500ft asl. what altitude are you at?
06-wrx-tr is offline   Reply With Quote
Old 06-23-2009, 01:08 AM   #3
Dave D.
Member#: 130990
06 Red Wagon hta68
The shop is pretty close to sea level, very close to Puget Sound.
Old 06-23-2009, 01:46 AM   #4
preacher#1
Top Scoob 022
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Why did you use the stock airbox, and 1 step plugs?
Other than that..nice numbers.
preacher#1 is offline   Reply With Quote
Old 06-23-2009, 01:59 AM   #5
Dave D.
Member#: 130990
06 Red Wagon hta68
Both were tuner recommendations. For the plugs I recall it's because of higher cylinder pressures, while the stock airbox is good for quite a bit more than I am putting out.
Old 06-24-2009, 01:35 AM   #6
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
wow that has to read low I made 250whp 290wtq on a tdo4 at 16.5psi
clkoontziii is offline   Reply With Quote
Old 06-24-2009, 07:55 AM   #7
idipskoalmint
Member#: 169716
2005 WRX STi
Wasn't Dom supposed to be getting a dyno put in his new shop?
Looks good
<< Another satisfied DomTune customer
idipskoalmint is offline   Reply With Quote
Old 06-24-2009, 08:12 AM   #8
kh15
Member#: 132400
2004 sti
wrb
i made 245/300 on a td04 on my 06 wrx!
kh15 is offline   Reply With Quote
Old 06-24-2009, 08:23 AM   #9
sen7inel
Member#: 192602
^ + 81hp / 93tq vs baseline on sti catback is awesome
sen7inel is offline   Reply With Quote
Old 06-24-2009, 09:32 AM   #10
blitzmr2
Member#: 101396
2006 WRX
Grip Grey
Ya--+1 for a new exhaust. Nice numbers anyway, though. I bet the car is very quiet and torquey.
blitzmr2 is offline   Reply With Quote
Old 06-24-2009, 10:11 AM   #11
Chris_Lee
Member#: 110667
2006 WRX
These numbers mean nothing without your base line numbers to show your relative gains. Every dyno is different.
Dyno plot looks good. I need to go get mine retuned.
Chris_Lee is offline   Reply With Quote
Old 06-24-2009, 01:39 PM   #12
Dave D.
Member#: 130990
06 Red Wagon hta68
Looks good
Yes he will be soon, but as my baseline was at Kito's, it would show my exact relative gains. I'll definitely take a pull on Dom's once he gets it set up.
Yes, I very much wanted the stealth sound/look. There's a guy in the VF39 registry who ran a 12.9 which a setup much like mine -- except he had a stock WRX catback!
Thanks. Def. +1. Do you TD04 guys have a baseline pull or at least some base WRX or STi numbers from your dynos? I have a hard time seeing an
80hp/90tq gain. Especially the hp gain with the TD04.
Old 06-24-2009, 01:56 PM   #13
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Nice torque bud! good tune , congratulations!
vik_wrx is offline   Reply With Quote
06 WRX VF39 50/50 Meth/Distilled kn0bby8 Proven Power Bragging 17 11-13-2006 12:45 PM
FL: 06 WRX VF39 swap *help* 06blksubwrx South East Region Forum 6 08-28-2006 02:14 AM
Got a Protuned 06 WRX VF39 map? scooby24 AccessPort 3 08-11-2006 11:54 AM
06 WRX + vf39 + AP stage II STI DRNWAGN AccessPort 4 04-12-2006 06:26 AM
06 wrx vf39 cobb stage 3 numbers dodiox Factory 2.5L Turbo Powertrain 13 02-22-2006 02:27 PM
Message Board Statistics All times are GMT -4. The time now is 09:54 PM.
