Old 04-26-2002, 12:09 PM   #1
Andrew
Member#: 1170
2005 STi
Arrow I am going to order rods today and I would like some suggestions.
Hey guys, I'm going to order some rods today but I need some quick help. Should I go with Pauter? Crower? My internal n00b is gonna show here... i did a search and i read "X-pattern and H-pattern." whats the difference between X-pattern and H-pattern? which should i get? which can handle the most torque/horsepower? what kind of price difference is there between the two?
Thanks,
Andrew
yes i did a search but i never found a reason to get one over the other, maybe i missed that thread... if so just direct me to it.
oh yeah do i need to know any specifics to give them? stroke? journal sizes? or will they know that stuff already.
Andrew is offline   Reply With Quote
Old 04-26-2002, 12:31 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Carrillo H design -
Crower I design -
You don't necessarily want to find out what is the best horsepower rod, you'll want to know what the best torque handling rod there is. Torque is what bends rods, horsepower is what screws up bearings and breaks bolts (well, as a generalization at least).
What type of horsepower/torque are you looking to run? I don't think it matters much what design you're using unless you're looking to go over the 400 ft.lb./torque mark or so, just so long as the bearings are all capable of withstanding the loads and are tight on tolerances.
Old 04-26-2002, 12:31 PM   #3
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Exclamation
Be careful if you go with pauter. I am not sure if the wiseco pistons or pauter rods were the incorrect length, but one half of the combo was a fraction of an inch too long, and pushed the piston crown above the deck of the block. This was causing the pistons the hit the head on my block. I had to get the pistons machined to correct it.
And don't order from a certain SoCal vendor...
Those are my two pieces of advice.
Regards,
Aaron
AaronB is offline   Reply With Quote
Old 04-26-2002, 12:38 PM   #4
Andrew
Member#: 1170
2005 STi
i would like to push 400 but thats in the future...maybe. im not even sure if i want to go crazy with the engine or not. right now it has bad rings and thats why im opening it up. im also sticking in JE pistons in 100mm and 9:1 and plan to put in a Link2 as well and run 10-12psi. im still wondering if i really NEED rods but id rather shoot for overkill, but am not sure if im shooting too far.
Old 04-26-2002, 12:42 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Out of curiousity, where did you get the pistons and how much (if you don't mind me asking) did you get them for? I've been toying with the idea of building up a block... I just need to get pricing for internals.
Old 04-26-2002, 12:43 PM   #6
Andrew
Member#: 1170
2005 STi
i went to www.jepistons.com and called them up. it was as simple as that. i cant remember the exact price but it was ~700 for rings, pins, pistons.
Old 04-26-2002, 01:26 PM   #7
Happy
Member#: 12115
When you're talking the quality of Carrillo, Crower, Arrow, etc', and circa 400ftlbs, I wouldn't worry about "H", or "I".
I've been told that "I" section are the strongest, and that's what I use. They've seen over 500ftlbs, so I'm happy (np pun intended
Make sure you get the rods/pistons balanced (weighed), as well as the crank, front pully, FW.
If you're building the engine yourself, make sure you check EVERY tollerance, then double check them. DON'T assume that because parts are new, they will be right. Plasti gauge all the barings.
Happy.
Happy is offline   Reply With Quote
Old 04-26-2002, 03:33 PM   #8
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
JE Pistons and Crower rods. Great combo.
Sean
Sean McElderry is offline   Reply With Quote
Old 04-26-2002, 07:38 PM   #9
outback motorsports
Member#: 4084
Default rods
try ours,they're pauter style $525 a set .48 mm we have piston sets also.w/turbo rings
outback motorsports is offline   Reply With Quote
Old 04-26-2002, 08:38 PM   #10
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
i got my je pistons through this place called suby specialties and they were only like 500 i think then another 100 to machine them.
boysetsfire is offline   Reply With Quote
Old 04-26-2002, 08:50 PM   #11
STiTuner
Member#: 5778
09 135i
Jet Black
*coughs
COBB
*cough
Brad
STiTuner is offline   Reply With Quote
Old 04-27-2002, 03:46 AM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
What about Paeco?
Old 04-27-2002, 03:58 AM   #13
Andrew
Member#: 1170
2005 STi
paeco is more expensive than the more major name brands so id rather go with major named brands...
Old 04-27-2002, 12:35 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Wow, I always thought they were cheaper. Damn, I need sponsorship.
Old 04-27-2002, 02:52 PM   #15
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Brad, COBB pistons are just JE's, except you order through them and get exactly what size you need.
They can also do any compression ratio you want.
If I ever get pistons, it'll be through COBB.
Graham
Graham is offline   Reply With Quote
Old 04-27-2002, 03:06 PM   #16
Cobb Tuning
Member#: 4803
FWIW, our pistons ARE made by JE but they are of our own design. If you buy the JE off-the-shelf piston and compare it to ours (which we have JE make for us due to their superb quality and workmanship) they are very much different in critical design aspects.
Either way, you get a good piston.
As for rods, be careful with the Pauter. Not only are they too long for most late model EJ25 engines (+0.025" - 0.035"), they also may create some clearance problems where they hit points internal in the block. They are also very heavy compared to other rods on the market.
I don't want to go on speaking badly about other products. My advice would just to measure everything VERY carefully when you're putting things together. Otherwise, you could end up with a very expensive "bang-rattle-rattle" the first time you turn over your new engine.
Simply because someone has a part available doesn't necessarily mean they've done the research to verify that part really does the job it should. Something that happens ALL too frequently in this industry.
Best of luck,
Trey Cobb
COBB Tuning
www.cobbtuning.com
Old 04-29-2002, 02:18 PM   #17
zaidallas
Member#: 4106
Trey's reputation speaks for itself , also I myself stress on what he said up there , believe me ! If there's waiting list for crower , get on it and save yourself money and trouble.
zaidoun
zaidallas is offline   Reply With Quote
Old 04-29-2002, 04:21 PM   #18
Andrew
Member#: 1170
2005 STi
hey guys, i just said forget it and ordered from cobb. they know their **** so im not worried abotu fitment, etc. it wasnt very cheap but at least my mind will be at peace.
Looking to buy a Forester, would like some suggestions Lesya Tri-State Area Forum 20 10-12-2005 11:44 AM
Going to boston on tuesday and would like some help from the locals. Red04WRX New England Impreza Club Forum -- NESIC 11 04-25-2005 12:50 PM
Breckenridge folks - would like some suggestions cboggess Rocky Mountains Impreza Club Forum -- RMIC 13 08-30-2004 12:09 PM
Buying a new Subaru and I would like some input ColdChillin New England Impreza Club Forum -- NESIC 15 07-01-2004 06:00 PM
ATTN!!! I am going to San Diego TODAY! (Sunday) Jimmy S. Southern California Impreza Club Forum -- SCIC 8 07-22-2002 01:11 PM
