Old 06-19-2009, 01:10 AM   #1
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Default 18x9 35+ G-Force Golds
I have an 03 WRX Impreza and right now i'm running kyb struts and shocks. A lot of people say these tires, the 18x9 35+ offet G-Forces will run fine with spacers and some fender rolling. Anyone doing it this way without any major problems? Please let me know. Any input and advice would be appreciated.
Respectfully,
Dustin
funbutns is offline   Reply With Quote
Old 06-19-2009, 01:40 AM   #2
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
I wouldn't go any wider than 8-8.5". Anything above that is just impractical. And that offset is just too low, nevermind even adding spacers.
Byzantium is offline   Reply With Quote
Old 06-19-2009, 02:11 AM   #3
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Impractical or not, alot of people are doing it....so obviously it's not that bad....
Old 06-19-2009, 02:15 AM   #4
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
It will fit pretty easily to be honest. Just roll the front and rear fenders and pull just a bit of camber and you'll be good.
domestic_abuser is offline   Reply With Quote
Old 06-19-2009, 02:20 AM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Lots of people are doing this too:
Doesn't make it good for the car.
Old 06-19-2009, 02:26 AM   #6
papakiet
Member#: 114693
2006 STi
SGM
adding an intake to your car isn't good .... changing the map isn't good for you car.. changing the suspension isn't good for the car..
is it your car?
If so, do what you would like.
As for performance, I don't see a problem with running 265's on your wheels. if you are doing this for looks.. you probably shouldn't be running that wide of a wheel.. especially if you are going to stretch a 225 or 235 on that wheel!
papakiet is offline   Reply With Quote
Old 06-19-2009, 02:32 AM   #7
carfreak83
Member#: 198761
04 STi
wrb
damn homie i **** you not thats my home boy sea side's car! he gonna be mad trippin when i tell him his ****s on here
carfreak83 is offline   Reply With Quote
Old 06-19-2009, 02:40 AM   #8
Byzantium
Member#: 207826
85k 2002 WRX
He bedda no not 2 b messn wit dem bludz.
It was only a warning. Going with wheels like those will affect how well your suspension works and how long it takes to wear different parts out.
Old 06-19-2009, 03:16 AM   #9
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Why does everyone always have to hate and put in non sense garbage. I'm just curious if anyones running the rims + tires without any major problems...and if so what kind of suspension and other mods are they using...
Old 06-19-2009, 03:49 AM   #10
papakiet
Member#: 114693
2006 STi
SGM
I'm about to run 18 x 9.5 +25. I plan to throw on some 255's. Suspension is going to be JIC coilovers with springs rates of 6k front and 4k rear. I'm not sure of the camber that needs to be set, but I do plan on rolling the fenders.
some wild stuff here: http://www.iwsti.com/forums/gd-tires...nt-thread.html
Old 06-19-2009, 03:50 AM   #11
papakiet
Member#: 114693
2006 STi
SGM
oh..btw this is nasioc...you get flamed for everything you ask..
Old 06-19-2009, 04:05 AM   #12
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Isn't that the truth. I just know it's possible and alot of people are doing it and I got the wheel and tires on the way. Just wanna make sure I have everything needed toget the job done when they arrive, hah.
Old 06-19-2009, 04:35 AM   #13
impreza_punk
Member#: 102900
2005 Impreza STi
I was going to say you may not need the spacers, but yea on second thought I bet they will rub on the struts without. I'd check if I were you to see if you could pull it off as is w/out the spacers, I've never been a big fan of spacers.
I thought in my head "..said the germans" and lol'd
impreza_punk is offline   Reply With Quote
Old 06-19-2009, 06:30 AM   #14
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
is it your car?
Know how I know you and the OP have never replaced wheel bearings on a WRX? I wouldn't start putting "aggressive fit" offsets on an '03, much less with spacers, unless I was planning to replace them soon. Be sure to factor bearing replacement into your wheel purchase. Better yet, go ahead and do it before you screw up the hubs and need to replace those as well.
Old 06-19-2009, 08:59 AM   #15
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Has anyone heard of the saying..."if you don't have anything nice to say, don't say anything at all" ?
Old 06-19-2009, 11:51 AM   #16
papakiet
Member#: 114693
2006 STi
SGM
That is one thing i have yet to hear about from anyone. Thanks for the info. and if or when my hubs do in fact need to be replaced.. it will serve as a good learning experience.
Old 06-19-2009, 03:53 PM   #17
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
bearings go for 50 bucks, never understood why people's skirts go up when wide wheel fitment gets talked about.
CC4nj is offline   Reply With Quote
Old 06-19-2009, 03:58 PM   #18
Byzantium
Member#: 207826
85k 2002 WRX
Bearings aren't the only thing affected by offset. Your entire suspension geometry is.
Old 06-19-2009, 03:59 PM   #19
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
yeah but the press to put those bearings in cost a hell of a lot more...
fl4tsc is offline   Reply With Quote
Old 06-19-2009, 04:01 PM   #20
fazeracing
Member#: 142564
PM DScamp 4
Cleveland Steamers
Cause teh CFC has to regulate
fazeracing is offline   Reply With Quote
Old 06-19-2009, 04:07 PM   #21
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
my 18x9.5 Grids at 38 offset isnt going to throw the suspension outta wack.
But I forgot, everyones car must be 100% balanced to daily drive.
a vice works pretty good for me...total labor cost $0.00
Old 06-19-2009, 05:14 PM   #22
funbutns
Member#: 139150
2013 STi Sedan
Crystal Black
Thanks for the advice. Im going to do it regardless. I don't think I'll have to many problems. Lots of people are doing it honestly. Why do people get so mad when it comes to large offsets? Sheesh~
Old 06-19-2009, 10:21 PM   #23
papakiet
Member#: 114693
2006 STi
SGM
Don't forget the pics!
Old 06-19-2009, 10:26 PM   #24
vinxH
Member#: 159796
2006 WRX
Have you tried replacing the bearing yourself?
Have you ever got a quote from a shop to see how much they charge for labor to replace the bearings?
Do either one, and then try to come back and say "its only 50 bucks"
but any ways, just like modding your car... there is a trade off for most mods, so i don't see what's the deal about about 'aggressive fitment' wheels. you mod for more power = you reduce the lifespan of your motor and transmission, you run low offset wheels = you reduce your wheel bearings lifespan, etc.
should i start the argument of people taking out their airbags to save weight on their daily driven car? or taking out bumper beams to fit their fmic?
everyone needs to lighten up and live a little lol.
vinxH is offline   Reply With Quote
Old 06-19-2009, 10:40 PM   #25
impreza_punk
Member#: 102900
2005 Impreza STi
Alright since the OP already came to his decision to run them and this thread is far from where it started or what it was made to answer, has anyone confirmed any wheel bearing replacements from the "aggressive" fitment wheels or spacers?
I myself was running a set of +28 and have all intentions of returning within the month to a similar wheel with again the offset of +28 and have had no problems thus far.
Will Rota G-force 18x9 +35 or Rota Torque 18x9.5 +35 fit on my 03 wrx? simon930 Tire & Wheel 9 04-27-2011 11:20 AM
FS (SEMI): 18x9 +35 G-Forces 5x100 Cosmic Blue! Squadom MWSOC Private Classifieds 17 05-11-2010 01:41 PM
FS: 18x9 Rota G-Force - Gold (5x114.3/E30/73) Surfer Steve Wheels/Tires 12 05-11-2010 08:12 AM
WTT: gold rota g-forces 18x9 35 5x100 thinkofone28 SCIC Private Classifieds 21 08-17-2008 12:14 PM
FS VA : Brand New Rota G-Force 18x9 +35 GOLD kcook MAIC Private Classifieds 11 07-11-2008 08:02 AM
