Old 06-19-2009, 12:31 PM   #1
Subarudave09
Member#: 209316
14 XV
Default Hand Tight Oil Filter
Changed My oil today. everything went normal until i cudnt fint my OIL FILTER WRENCH. i have the socket kind. so i oiled up the seal and hand tighten it. turned as hard as i cud.
IS THIS OK KUZ THE HEAT WILL SEAL IT UP ???
GOING TO BUY 1 NOW
Subarudave09 is offline   Reply With Quote
Old 06-19-2009, 12:33 PM   #2
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
I only hand tighten my oil filters. I have never had an issue in the 10 years that I have been doing it. It makes getting them off easier too. No need for a wrench.
jbwrx is offline   Reply With Quote
Old 06-19-2009, 12:33 PM   #3
BlazinYellow
Member#: 127963
So.. wanna ****?
I've always just hand-tightened. Just leave it be.
BlazinYellow is offline   Reply With Quote
Old 06-19-2009, 12:45 PM   #4
Subarudave09
Member#: 209316
14 XV
i got oil all over my hedders and drove it around a saw spots but the filter and the block where BONE dry so No worries??
Old 06-19-2009, 12:50 PM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Never, ever, EVER use a tool to tighten an oil filter.
vision.dynamix is online now   Reply With Quote
Old 06-19-2009, 12:55 PM   #6
08EJ25
Member#: 174022
2008 WRX
Lightning Red
You are fine with the hand tightening. I have only done it that way with a wet seal and been fine.
08EJ25 is offline   Reply With Quote
Old 06-19-2009, 12:58 PM   #7
constantinus
Member#: 153174
constantinus is offline   Reply With Quote
Old 06-19-2009, 01:02 PM   #8
The HACK
Member#: 208707
Why is that? I used a micro-torque wrench (you know, the ones that read in inch-lbs instead of ft-lbs?) with a metal filter wrench cap with 3/8" drive, and torqued it to Subaru specs (8.7 ft-lbs, which is 104 in-lbs as indicated on the torque wrench). Did I do something wrong? Should I drain and replace the filter with a new one and hand-tighten it?
The HACK is offline   Reply With Quote
Old 06-19-2009, 02:53 PM   #9
z&cobb
Member#: 12344
2002 2JC
blue
If you want to use a torque wrench, and its set to subaru specs, you should be OK. That's probably better than letting a Chimp hand tighten the thing.
I just flashed back to the Eastwood movie, where the Chimp opened the car door by tearing it off the hinges.
z&cobb is offline   Reply With Quote
Old 06-19-2009, 02:55 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
GOING TO BUY 1 NOW
where DO these people come from????
Old 06-19-2009, 02:56 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
"Scrap the Caddy, Clyde!"
Old 06-19-2009, 03:04 PM   #12
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
as long as it doesnt leak its fine, hand tight just makes it easier to get if off next time around. the oil filter should have directions on it as well, something like 3/4 turn past touching or something like that.
seanvetter123 is offline   Reply With Quote
Old 06-19-2009, 03:34 PM   #13
Subarudave09
Member#: 209316
14 XV
ive changed oil 1000x in other cars subie my 1st big bitch the hedders were screaming hot and my hands are huge
Old 06-19-2009, 03:39 PM   #14
sgiord86
Member#: 212715
ive never not hand tightened an oil filter. Don't want to risk over tightening it and crushing that seal and causing a leak .
sgiord86 is offline   Reply With Quote
Old 06-19-2009, 04:06 PM   #15
Subarudave09
Member#: 209316
14 XV
im not jacked or anything strenght wise so its on moderatly tight
Old 06-19-2009, 10:04 PM   #16
hoffmanEstates
Member#: 122043
04 wagonier
psm
typicaly hand tight is good enough. unles other wise stated with instructions on the filter
hoffmanEstates is offline   Reply With Quote
Old 06-19-2009, 10:26 PM   #17
magnum2066
Member#: 158586
2009 WRX
Pearl White
I just follow the instructions on the OEM filter.
magnum2066 is offline   Reply With Quote
Old 06-19-2009, 10:27 PM   #18
darksc00by
Member#: 102140
He is probably from SCIC and now lives in NESIC.
darksc00by is offline   Reply With Quote
Old 06-20-2009, 01:17 AM   #19
Niku-Sama
Member#: 212426
1990 Loyale AWD Turb
i hate the people do do their oil change one and would come into where i used to work because they couldnt get them off any more and "let" us take care of it for them.
usually those people we had to stab the filter through the side with a screw driver and use it as a lever and hope we didnt hit the stud when we stabbed it because stabbing it more than once causes it to weaken and possibly tear the top half of the filter off.
for some reason all of our filter wrenches were broken, dont know who kept doing that **** but it got old fast
Niku-Sama is offline   Reply With Quote
Old 06-20-2009, 08:53 PM   #20
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
amazing, just amazing.
RonJitsu is offline   Reply With Quote
Old 06-23-2009, 08:12 PM   #21
The HACK
Member#: 208707
So it IS okay to use a tool, if it's a proper tool and done to specifications. Got it.
Oil filter not staying tight 240c Normally Aspirated Powertrain 37 01-30-2008 02:19 PM
what happen if you twist your oil filter too tight? dawhim Newbies & FAQs 14 09-21-2004 11:59 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
need to know oil filter threads for remote oil filter Gravel-Fun Normally Aspirated Powertrain 2 07-22-2002 05:23 PM
Oil and oil filter? Spark plugs and air filter? TimCat General Forum Archive 5 01-18-2001 11:27 PM
