Old 06-19-2009, 01:57 PM   #1
gt9729b
Member#: 88456
2005 STi
Default Cool Shirt Users?
I apologize if this is in the wrong place, but I thought I'd get the best response out of Motorsports and it didn't seem to fit anywhere else (OT, maybe?). Please move as necessary.
Does anyone have any experience with a cool shirt? As in the one pictured here:
http://www.hmsmotorsport.com/imgView...m-Complete.jpg
I'm looking for something to help combat the heat outside and this would necessarily be used in a motorsports situation as much as a farming one. It would be for my dad. Regardless, does anyone have any thoughts on cool shirts? Do they work? Not worth the money? A suitable alternative maybe?
This would be for a belated Father's Day present for my tractorin', heat hatin' dad. Thanks.
gt9729b is offline   Reply With Quote
Old 06-19-2009, 02:05 PM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I don't personally use one since I'm not in the car long enough to need it but from what I have heard that system works extremely well. Just fill up the cooler with ice water and it should keep him cool for quite awhile. They are widely used in endurance racing in hot conditions.
boost junkie is offline   Reply With Quote
Old 06-19-2009, 02:36 PM   #3
goto_racing
Member#: 69261
They work GREAT. I have been using them for 3 years now, and wondered why I waited.
Get the largest cooler possible. the downside is that even in the big system, the ice is used up after about an hour. you need to refil often I would imagine if you were working all day on a tractor.
goto_racing is offline   Reply With Quote
Old 06-19-2009, 03:38 PM   #4
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
Default cool shirts = cool!
we have used cool shirts for years in our rally cars, they are THe shiznits for hot days in cars w/no AC. you stay fresher longer, don't lose concentration from overheating, and can jump right out of a hot steamin race car and talk to the assembled media hordes lookin your best (yeh, right! )
couple ways to extend cooling time: use block ice with a little bit of water for circulating thru the shirt; put a switch on the pump that's easliy reachable from drivers seat, this way you can just give yourself a blast of coolness without it running all the time (which eats up ice quick) and switch it off much of the time; have also found that the switch really helps when ice n water is fresh and super cold, sometimes running the pump all the time makes you TOO cold.
finally, need to flush the cooling tubes out when it's time for extended storage, don't want no science projects growing in them tubes! we launder the shirts inside out on gentle cycle to avoid damaging tubes. etc etc
seems that everybody learns one thing about cool suits the hard way....to disconnect the coolin tubes before you try to get outa the car!
RB5 Clone is offline   Reply With Quote
Old 06-19-2009, 04:22 PM   #5
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I have no experience with it, but here's a diy that I ran into a while ago.
http://specthismiata.com/2008/08/03/...-shirt-system/
573 is offline   Reply With Quote
Old 06-19-2009, 04:37 PM   #6
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
http://www.pegasusautoracing.com/gro...upID=COOLSHIRT
Best thing for keeping you cool in the heat. I know some flame cutting shops that use them for all there employees.
2superblus is offline   Reply With Quote
Old 06-25-2012, 01:27 PM   #7
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Shirt question
The hose connecters for the shirts the same between the CoolShirt and FAST systems?
Patrick L is offline   Reply With Quote
Old 06-26-2012, 03:04 PM   #8
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
pretty sure both use same tubes & connectors, it's standard grade (ie high-quality) medical stuff.
Old 06-26-2012, 10:28 PM   #9
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
OK thx
Old 06-27-2012, 09:41 AM   #10
JSC Speed
Member#: 75126
They use the same quality of materials but Cool Shirts and FAST shirts are not cross-compatible. The connectors are different, but you can buy and change connectors to make them work together.
For endurance racing we fill the cooler about half-way with water then put two frozen gallon jugs of water into it (with the caps on still). The ice cools the circulating water and melts slowly enough that the water stays cool for almost two hours. Of course it helps to keep the cooler out of the sun and as cool as possible.
Cheers,
[email protected]
JSC Speed is offline   Reply With Quote
Old 06-28-2012, 12:40 AM   #11
555ideways
Member#: 36652
Cheers,
[email protected]
This. Ice cubes don't cut it. You need a big block of ice to go the full distance. A huge cooler is dumb and heavy.
The real smart way is to incorporate dry ice and copper tubing. That's what some ALMS teams were doing many years ago before a bunch of updates and rule changes. That **** will go forever and make the pit stops more efficient.
-Paddy
555ideways is offline   Reply With Quote
Old 06-28-2012, 12:42 AM   #12
555ideways
Member#: 36652
And those connectors are not that high quality. Actually about 50 cents a piece to manufacture and $5 to buy. The O Rings fail and clog the tubing after enough cycles. I'm using a lubricant in the water next time out for the health of the pump and connectors.
-Paddy
Fizz - New Rays Engineering Shirts Available! Fizz Autosports MWSOC Vendor Classifieds 2 06-17-2010 12:39 PM
cool shirt suby_dude Off-Topic 9 04-15-2005 04:57 PM
Found a pretty cool shirt, check it Reckon Vancouver Impreza Club Forum -- VIC 4 10-17-2003 08:47 AM
('93-'01) really cool t-shirts WorldRallyRedneck Impreza Forum 9 10-09-2001 06:55 PM
