Old 06-20-2009, 02:18 AM   #1
xdarkn3ss
Member#: 180912
2004 WRX
Default Brand new A/F sensor with antiseize on it? Safe to use?
I just received a brand new A/F sensor (front O2 sensor w/e you want to call it) from subaru; first of all there was antiseize already brushed on to the threads but then there was a little plastic sheath or guard that was around the threaded section that had come off during shipping, and a healthy coating of the antiseize was on the inside of that shield and smeared across the sensor itself when it came off. There was none in the little holes on the outside of the sensor just streaks here and there on the flat parts as far as I could see.
In the service manual it specifies quite clearly that you can not get any antiseize on the sensor itself.
Is it safe to use (if I clean it off somehow) or do I have to wait another month to ship it back, verify the damage and wait for a replacement?
on a side note am I the only one who thinks that putting antiseize on anything pre-delivery to the customer is 8/10 on the dum-dum scale?
xdarkn3ss is offline   Reply With Quote
Old 06-20-2009, 10:36 AM   #2
magnum2066
Member#: 158586
2009 WRX
Pearl White
Don't use it, every bit of contamination will affect it's performance.
magnum2066 is offline   Reply With Quote
Old 06-21-2009, 08:19 PM   #3
whateverwrx
Member#: 99653
05 WRX
It'll be fine, almost all denso A/F sensors that screw in have anti-seize on them.
whateverwrx is offline   Reply With Quote
Is it safe to use mineral spirits to clean rotors? In middle of brake job... ImportVenom Brakes, Steering & Suspension 2 04-29-2006 11:11 PM
Is it safe to use no muffler with a Cobb Stage 2 Map? caterpill Engine Management & Tuning 5 01-24-2006 03:27 AM
Is it safe to use someone else’s custom tune? jojo Engine Management & Tuning 11 09-07-2005 01:49 PM
When is it safe to use Mobil 1 on new WRX. kovalov Engine Management & Tuning 2 12-12-2002 02:36 PM
Is it safe to use stock ECU with up-pipe and turbo back exhaust (1 cat)? gtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-11-2001 08:32 AM
