Old 06-20-2009, 06:37 PM   #1
vincent-h
Member#: 59504
2005 Impreza RS
Default Wheel/fender gap question
I noticed that on Subarus the wheel gap (gap between tire and fender) is normally much larger in the front than in the rears.
Is this because the suspension system has to compensate for the heavy front end? I just find that it looks kinda funny with the nose up.
I just installed coilvers and set it to have the front with a larger gap than the back just to follow factory type of specs. 2 finger spacing in the back and 4 in the front.
Though I am now thining of changing that and going with a equal height int he back and front or possile 3 in the back and like 2 in the front for a bit of a more aggressive stance.
I'm really just wondering if it would be deterimental to do so?
Thanks
Vincent
vincent-h is offline   Reply With Quote
Old 06-21-2009, 08:41 PM   #2
vincent-h
Member#: 59504
2005 Impreza RS
bump for some input if possible
thanks again
Old 06-21-2009, 09:48 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The front fenders are cut higher - if you set it so they 'look' even you will actually be raking the car forward - which may be detrimental to the car's handling in itself depending on other factors such as your F/R roll stiffness. You will also need to take into account shock travel and the effect on steering geometry.
Bottom line - unless you only care about looks, don't use looks to set up coilovers.
UkNuck is offline   Reply With Quote
Old 06-22-2009, 04:30 AM   #4
luggernaut
Member#: 206147
'04 WRX Stg 2.5
mmm....for info on height adjustment etc...
http://forums.nasioc.com/forums/show....php?t=1408733
http://forums.nasioc.com/forums/show...hreadid=203801
That might help you out...
luggernaut is offline   Reply With Quote
What do you think? Wheel swap in question! stierzy34 Interior & Exterior Modification 23 06-05-2010 06:01 PM
Fender Gap Question Dewback9 Brakes, Steering & Suspension 6 02-11-2008 01:15 PM
2004 STi Fender gap question Eyefixstuff Brakes, Steering & Suspension 5 07-22-2007 07:22 PM
WRX Lowering, Improving Handling, and reducing the huge wheel to fender gap in front Maniac Brakes, Steering & Suspension 8 12-26-2002 11:00 AM
Tein HA in, fender gap out ColinL Brakes, Steering & Suspension 19 04-15-2001 11:39 PM
Message Board Statistics All times are GMT -4. The time now is 10:20 PM.
