Old 06-20-2009, 09:21 PM   #1
awdturbo04
Member#: 39487
2006 sti
obp
Default my take on a catch can install
So my car has a blow through maf which I have to block off the pcv valve in order to prevent a boost leak. While I was reading up on that I started reading up a bit on crank case ventilation. In my research I decided to make some changes to my catch can hose routing.
Theory- when the car sucks in on the intake thus creating a vacuum that passes through the catch can and into the valve cover. Then since the valve cover and the crank case have tubes that connect them in order to equalize pressure will suck air from the crankcase into the valve cover and into the intake. Then the filter on the crank case will allow for a source of fresh air to be sucked in.
Disclaimer- I truly have no idea if this really works and by no means do I recommend that you should do this to your car.
The sti comes standard with a t fitting that connects both valve covers to the center of the crankcase Iím guessing to assist in equalizing the pressure between the two.
My stock line melted due to contact with the turbo so i replaced it with stainless steel lines.
Here you can almost see where the third fitting attaches to the crank case directly under the throttle body
Then I connected both valve covers to a t that ends at the catch can.
Then I ran a line from the catch can to a vacuum line on the intake. itís the stainless steel line closest to the filter.
Lastly take a crankcase breather filter and insert it over the previous location of the pcv valve on top of the crank case
awdturbo04 is offline   Reply With Quote
Old 06-20-2009, 10:34 PM   #2
aug
Member#: 172080
awesome, but that is one expensive breather system
aug is offline   Reply With Quote
Old 06-20-2009, 11:39 PM   #3
STIBungy
Member#: 51684
Where is your maf sensor?
STIBungy is offline   Reply With Quote
Old 06-21-2009, 02:01 PM   #4
awdturbo04
Member#: 39487
2006 sti
obp
its inside the intercooler piping
Element Catch Can Install on my Built Motor ejh25 Built Motor Discussion 16 06-25-2015 12:10 PM
My Greddy oil catch can install mattjk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 01-07-2007 08:59 PM
Please Help on my Catch Can Install ColesSTi Newbies & FAQs 7 10-27-2006 02:12 PM
my take on cobb SS line install gsgleason Brakes, Steering & Suspension 8 10-19-2006 01:05 AM
Check out my oil catch can install jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 07-30-2002 12:50 PM
