Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 06-20-2009, 08:55 PM   #1
spooling impreza
Member#: 161782
Default coolant lines
i am having trouble finding how to hook up coolant lines to my turbo i dont know where to hook up the lines and where to return it to can someone help me thanks
spooling impreza is offline   Reply With Quote
Old 06-20-2009, 09:28 PM   #2
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
http://forums.nasioc.com/forums/show...ht=coolant+tap
Basically you can do either:
1) get a wrx water pump
2) Use heater Lines
3) Use the Throttle body bypass and tap for coolant there
freeride is offline   Reply With Quote
Old 06-20-2009, 09:29 PM   #3
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
There are two heater hose lines that are poking out from behind the motor directly over the steering link on the driver's side. They go into the firewall near the pitch mount. Tap into those two with heater hose T's and use one for return and one for send. It doesn't matter which.
-Brett
ExecNav is offline   Reply With Quote
Old 06-21-2009, 01:19 AM   #4
spooling impreza
Member#: 161782
thanks guys Justin
TD04 WG Actuator, Coolant Lines, Oil Retun Line STI Thermostat BlackFlame Engine/Power/Exhaust 4 11-28-2008 10:50 PM
FS: PA: Forced Performance 20G Turbo w/ SS oil line & aftermarket coolant line wkderf Engine/Power/Exhaust 11 06-16-2008 05:06 PM
FS: PA: Forced Performance 20G Turbo w/ SS oil line & aftermarket coolant line wkderf Tri-State Area Private Classifieds 2 06-07-2008 09:43 AM
used vf30 without oil and coolant lines - can i use stock lines? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-09-2004 10:17 PM
Coolant lines? Ran in parallel from heater lines OK? Kotir Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-29-2004 08:56 AM
